Go Search!!
Home
MSI HQ User to User Forum
09 February 10, 20:54:49 *
News: How do you flash your BIOS, please take part in our poll, thank you! >>How do you flash?<<
Pages: 1 [2] 3  All   Go Down
  Print
Author Topic: Switching to AMD Dual Core CPU without re-installing Windows  (Read 34828 times)
Built2Last
Lord
Offline Offline
« Reply #40 on: 04 February 07, 21:27:11 »
kangi26, What bios ver. are you running?
Main PC:
Case: Antec P180 MB: MSI K8N Neo4 Platinum Bios: MurdoK's 7125XMOD1.D Processor: AMD Opteron 180 dual core c/w Coolermaster Hyper TX OS: Win XP Pro sp2 32bit Optical Drives: 1.NEC 3540 DVD 2. LG 8527B CD RW Graphics Card: Sapphire X800 GTO2 Dual DVI 256mb 16 pipelines Memory: OCZ EL Platinum 2GB Dual Channel CL 2-3-2-5
Hard Drives: 1.2 x Seagate ST3160812AS SATA II NCQ firmware 3.AAE [RAID 0] 2. Seagate ST3250823AS SATA I [storage only  - non RAID] PSU: Enermax Noisetaker EG495P-VE  485 watt
HTPC:
Asus A8R32-MVP Dlx/Opty 165/1GB OCZ Ram/4 x 80 Gig ST3808110AS SATA II NCQ firmware 3.AAE [RAID 0+1 stripe] /Pioneer DVR-111D/Mushkin HP550 psu/BTC 9019URF wireless kb/MS MCE 2005/Silverstone Lascala LC16M c/w VFD
kangi26
Newbie
Offline Offline
« Reply #41 on: 04 February 07, 22:21:35 »
Ah, now if I actually had my head attached to something that resembled intelligence I would have provided that information when I started my questions. I believe I have the current version, being that I am not at my desktop at this time, I cant be positive. I can post that info later though.
kangi26
Newbie
Offline Offline
« Reply #42 on: 05 February 07, 00:25:13 »
Well, this could be more of an issue than I anticipated. According to CPU-Z,
Model: MS-7125  1.0
Chipset: nVidia  nForce4 Rev.A3
BIOS:
Brand: Phoenix Technologies, LTD
Version: 6.00 PG
Date 09/09/2005
kangi26
Newbie
Offline Offline
« Reply #43 on: 05 February 07, 00:48:32 »
BIOS 1.9 09/09/2005. I will try to update the BIOS to the latest rev
kangi26
Newbie
Offline Offline
« Reply #44 on: 05 February 07, 01:32:16 »
Ok, well, the BIOS upgrade seems to fix my issue.
Thanks for the input
Built2Last
Lord
Offline Offline
« Reply #45 on: 05 February 07, 07:30:32 »
kangi26, Glad to hear that you got it sorted out. I was just relating from my own experience and had a hunch that the bios might be the cause.
Main PC:
HTPC:
henrythe9th
MSIHQ Red Rockets Team Member
Lord
Offline Offline
what else are we gona do with all these pc,s
« Reply #46 on: 10 February 07, 20:36:11 »
Hello, I installed my 170 opty and windoz see's the duel core all buy itself I did nothing?? device mang. see mulit processer and under processer tab shows both cores, so does cpu-z!!
do I need to do anything else and I dont know how this happened no hot fix, no changing the DLLs
How did this happen?  Henrythe9th
EDIT ok found  its normal for my xp sp2 OS,  but the real question is Do I need the M$ hot fix really, and although my copies of XP are legit I don't get M$ updates so theres no windows validating tool on my OS and I want to keep it that way..Its a OME copy and I change hardware offen..anyone know of somewhere else to get the hot fix other than M$      Henry
EDIT2  the hot fix really only appies if you use or want to use cool and quiet. I dont use it
« Last Edit: 23 February 07, 21:56:18 by henrythe9th » Logged
msi NEO4 SLI (7100-030)9.3 bios,opty 170@2.4
ASETEK/d-tek watercooled
OCZ 2x1g pc3200gtx 3,3,3,8,1T
Bfg 7950gt pci-e
2x80wd sata raid 1  1&3
sb-audigy 2 zs
infinity mid-case
rosewell rp550-3.3v=30a,5.0v=50a,12v=18a x2
dvd-rw- cd-rw   xp pro,sp2
2nd MSI neo4 plat. opty148@2.6
MSI 7600gt
kingston hyperX pc-4000 4x512
antec full tower /true power 550 PSU
WD sataII 120gig
3RD- DFI UT Expert,opty 170@2.4
water cooled  Kandolf case
2x1G Ocz pc4000GX 3,3,3,7 1t @ddr520
2x evga 8800gts 320ram SLI
wd 160g SataII /wd80g sataII
scsi 73 gig fujistu U160
lite-on combo dvd-cdr
MSI tubrosteam 600w 12v=22a x2
xp pro sp2
baglador
Newbie
Offline Offline
« Reply #47 on: 23 February 07, 06:38:13 »
ooops!
it is a long time i've last visited this forum, seems i have totally missed to support some guys  Undecided
my apologies...
Thanks to Bosskiller for taking care of this thread here  agree  biggthumbsup
Just to make it clear this thread here applies only for people whose computers report as
"Advanced Configuration and Power Interface (ACPI) PC" and had like to switch to
"ACPI Multiprocessor PC" or "ACPI Uniprocessor PC" without re-installing windows.
In any other case no additional action should be taken as windows will automatically detect the new X2 dual core cpu installed in their system.
Take Care,
Markoul
Hope you haven't abandoned this thread, Markoul. Just upgraded from an Athlon 64 3500 to an X2 4400+, and my computer is still being reported as "Standard PC" in the device manager. Also, only one core graph shows up in task manager. You said to only try your method if your computer reports as "ACPI PC". Should I attempt this anyway?
Bas
Chief nut :-)
Administrator
Offline Offline
If it doesn't fit, use a hammer!!!
WWW
« Reply #48 on: 23 February 07, 11:58:49 »
You can try to do it.
But mostly if it's saying standard PC you need to do a repair install.
Bas.
MediaLive
AMD X2 4200 - 2.2GHz - CPU Cooler blowing upwards!
2x 1GB DDR800 El-cheapo
Samsung 160GB Sata-2
Technotrend Skystar 2 DVB-S
Ubuntu 9.10 / Debian (forum-server) / OpenSolaris / MCE2005 (MCE is unable to do proper DVB-S!)
With AMD CPUs use AMD tested MEMORY! Intel tested often fails!!!
Powersupply rule of the dumb: 12V Amps < 3.3V or 5V Amps -----> Unfit for modern systems, REPLACE!!
Please call me a nerd, it's not name-calling, it's an EGO BOOST!! lol_anim
Snipus_Maximus
Full Member
Offline Offline
WEEEEE!!!!
« Reply #49 on: 26 February 07, 08:20:17 »
Well another thing that may be considered is that -- especially with Windows Vista being a totally different kernel (NT 6 baby - XP/2K is NT 5.xx) and not using the NTLDR or boot.ini anymore - u will have to modify the boot manager
But that presents another problem ~~
If you have done any hardware changes after an activation of Windows XP or Vista -- Each hardware is worth a certain amount of 'points' -- depending on H/W type it may be worth more or less -- but I would imagine a CPU would be a huge change and the fact that u are 'adding' a second cpu - I am pretty sure you would hit an Out Of Tolerance issue there and you will need to reactivate - with Vista that's gonna be some fun there goes all of your functionality unless you reactivate or run in safe mode...as for XP...im not too familiar with the activation junk on that...i think that all u lose is the reccomended/optional updates off of M$update and u cant get 'special' M$ junk on its website..
but just as a heads up as to what to expect with the new vista out there...but heres a heads up---if u did a fresh install of Vista (any version) you have 30 days to make ur hardware changes then to activate in that state...so get-er-done
AMD Athlon X2 3800+ - Socket AM2
K9NGM2-FID - Socket AM2 MoBo
Buffalo Select 2GB (4x512MB) DDR2 533 (PC2 4200)
PNY nVidia GeForce 7600GS 512MB GDDR2 PCI-E 16x
LITE-ON 16X DVD±RW /w LightScribe + 5X DVD-RAM Write-Sec Slv
WD 10 GB Pri Master
IBM Deskstar 30GB Pri Slave
Maxtor DiamondMax 9 160GB Sec Mas
Seagate 300GB SATAII - Third Master
3 1/4- in Floppy
Windows Vista Ultimate Edition (Primary OS)
Windows XP Professional (SP2) (Secondary OS)
EchoStar 600 watt Power Supply
Horseman
Offline Offline
« Reply #50 on: 11 March 07, 05:15:52 »
  Im replacing my 3000 Venice with a 3800 X2 this week.  I have updated to the 1D Bios in preparation.
 K8N Neo4 Ver1   (939)
 XP Sp2
  Apparently , XP can either recognize the dual chip without issue, or not.   I'm trying to figure out in advance if I'm going to have a problem or not. Is there some pattern to this or is it random?
  Is there anything else I need to do to prep the system?
  As for patches,  the more I read the more confused I get.   You have the AMD Dual Core patch and this from M$::
http://support.microsoft.com/default.aspx?scid=kb;en-us;896256
  What's the bottom line  Shocked on what you NEED to install to get smooth dual core performance??
« Last Edit: 11 March 07, 05:26:01 by Horseman » Logged
Snipus_Maximus
Full Member
Offline Offline
WEEEEE!!!!
« Reply #51 on: 15 March 07, 15:39:39 »
the best performance: fresh install of windows xp or vista, then fully updated, and then that MS patch that you have listed, then also this patch here from AMD
http://www.amd.com/us-en/assets/content_type/utilities/Setup.exe -- the dual core optimizer
WD 10 GB Pri Master
3 1/4- in Floppy
Bobo9x
Newbie
Offline Offline
« Reply #52 on: 19 March 07, 11:28:06 »
Hi there ,i have gone over the material here and am not sure if the problem i am having with my dual-core upgrade is the same issue. I originally checked in the Device Manager and the Computer is listed as an "ACPI Uniprocessor PC" , so i assumed i could at least just exchange the CPU and change everything else later (Driver , optimizer etc....). The PC booted up and Recognized the CPU correctly, went through the posting and just blanked out when it was time to load Windows.I think i had a blinking "underscore" the first time . I am not new to computers, but am a little out of my league when it comes to diagnosing what to do first in this situation . So, if anyone had an idea in which direction i should go , it would be much appreciated ... Cool.   Thanks
BTW -- the new CPU i want to install is an AMD 4800+ X2  (Toledo Core) and the updated Bios is X2 friendly !!!
AMD A64 3000+ Venice(9x200) w/ XP-90 Thermalright Heatpipe
MSI-K8N Neo 2-F  (MS-7025 S939) V1.CTC Side-effect Bios
2 x 512 Mb OCZ 3200 DDR Dual Ch. Rev 2 Plat. 2-2-2-5  1T
450 watt OCZ Modstream P/S  , WD Caviar SE IDE HD (120 gig)
ATI Radeon X850XT 256 Mb 256 Bit AGP
Windows XP-Pro SP 2
T9246ED,大會編碼器
Offline Offline
Bas (Boss) killed Bosskiller! It's Svet now!
« Reply #53 on: 19 March 07, 11:51:36 »
so you have installed the X2 CPU and can't boot OS with it?
try to boot into Safe mode then update "ACPI Uniprocessor PC" to "ACPI Multiprocessor PC".
if can't boot into safe mode. change HAL to "ACPI Multiprocessor PC" before install the X2 CPU.
    * MSI K8N D-Plus
    * i7 AMD Pentium 7 9200+ ==> http://valid.x86-secret.com/show_oc.php?id=553583
    * Corsair XMS 2GB Kit
    * Corsair TX750W 3.3V/30A 5V/28A 12V/60A
    * MSI 2xN260GTX-OC
Bobo9x
Newbie
Offline Offline
« Reply #54 on: 19 March 07, 19:34:06 »
Yes ,this happened with the new X2 Cpu , I tried a couple of different things in the bios and still would not load windows,so i threw my 3000+ back in and everything functioned fine.
I will try later today to change the HAL over to multiprocessor "before" dual core install and i assume i will need to update the driver and dual core optimizer "after" installing the new dual core .
Thanks for the quick response BossKiller           biggthumbsup
Windows XP-Pro SP 2
T9246ED,大會編碼器
Offline Offline
« Reply #55 on: 19 March 07, 22:22:34 »
you are welcome,
"I will try later today to change the HAL over to multiprocessor "before" dual core install and i assume i will need to update the driver and dual core optimizer "after" installing the new dual core ."
all procedure can be done with single core CPU as well, e.g.:
change/update HAL to "ACPI Multiprocessor PC"
reboot.
install Dual Core HotFix V4 --> http://forum-en.msi.com/index.php?topic=103843.0
reboot.
install Dual Core Optimizer --> http://www.amd.com/us-en/assets/content_type/utilities/Setup.exe
reboot, lets load OS, power down PC and install X2 CPU.
    * MSI K8N D-Plus
    * MSI 2xN260GTX-OC
Bobo9x
Newbie
Offline Offline
« Reply #56 on: 20 March 07, 23:05:08 »
ARRRGGGHHHH  !!!  well , i really did it now . I decided to remove the MS Hotfix and the AMD Dual Core Optimizer at the same time in order to install everything in a different order because with the above mentioned changes, my 4800 X2 did not want to load the OS(again) . I put back in my 3000+ single core and have now screwed it up so that it can't load up the OS as well .  wall
 when i try safe mode , it shows the list of drivers? loading up, but then stops and reboots everytime. Is this actually the boot.ini ? Final question : is there any way of getting through this ,or should i just drag my sorry azz back to the computer and do a repair fix? I do have my kids computer hooked up with XP pro as well ,if there is anyway of taking some files from it to repair my machine .  I'm out ........... bonk
Windows XP-Pro SP 2
T9246ED,大會編碼器
Offline Offline
« Reply #57 on: 21 March 07, 11:21:46 »
"I decided to remove the MS Hotfix and the AMD Dual Core Optimizer at the same time in order to install everything in a different order because with the above mentioned changes, my 4800 X2 did not want to load the OS(again) . I put back in my 3000+ single core and have now screwed it up so that it can't load up the OS as well .  wall  "
why you do that?
"Final question : is there any way of getting through this ,or should i just drag my sorry azz back to the computer and do a repair fix? I do have my kids computer hooked up with XP pro as well ,if there is anyway of taking some files from it to repair my machine .  I'm out ........... bonk"
easy and perhaps fast way to fix it, to perform OS repair.
    * MSI K8N D-Plus
    * MSI 2xN260GTX-OC
Bobo9x
Newbie
Offline Offline
« Reply #58 on: 21 March 07, 20:11:24 »
why you do that?
I thought i may have installed a few things in the wrong order or just had basically become frustrated and tried doing some things i should have left alone . Either i will learn a few things from goofing around with the OS or i will learn to just leave it alone  noidea
  I'll try the OS repair , thanks for taking time on this matter , BossKiller   worship
Windows XP-Pro SP 2
T9246ED,大會編碼器
Offline Offline
« Reply #59 on: 21 March 07, 20:13:49 »
"I'll try the OS repair ,"
yes do that mate yes and let we know how its going
    * MSI K8N D-Plus
    * MSI 2xN260GTX-OC
Snipus_Maximus
Full Member
Offline Offline
WEEEEE!!!!
« Reply #60 on: 21 March 07, 23:09:38 »
its during that time you learn the most, young grasshopper...you learn the most when you broke it, and you apply the lesson when you fix it...
good times
WD 10 GB Pri Master
3 1/4- in Floppy
ASegredo
Junior Member
Offline Offline
« Reply #61 on: 23 March 07, 02:33:56 »
I just upgraded from a Newcastle 3500+ Athlon64 today and had a lot of trouble.
Device Manager shows "ACPI Uniprocessor PC". I tried to change it to "ACPI Multiprocessor PC" but Windows 2000 kept crashing on startup with a BSOD. I just got Uniprocessor back via Safe Mode. Task Manager has only one set of graphs. What do the different CPU ACPI settings mean anyway.
Before the upgrade my Dual Channel memory was doing fine. Immediately on firing up with the new CPU, the memory wouldn't post. I switched positions to Single Channel and the BIOS would post. Next I reconnected the drives and various problems with Windows freezing. Checking the BIOS, the memory was reporting as DDR333 instead of DDR400. I removed the second stick and Windows ran OK, but rather slow as I have gone from 1024Meg Dual Channel to 512Meg Single Channel. I never touched the memory until the PC failed to Post.
Should I try this multiple HAL thing or just leave well enough alone? BTW, the Manchester runs much cooler than the Newcastle at the same 2.0Ghz, but maybe thats the ThermalTake Cooler and Antec (sic) Silver .
-MSI-7025-010 K8N Neo2 Platinum
-Award rev 1.D BIOS
-AMD Athlon64 X2 3800+ (Manchester)
-Corsair TWINX-1024XL
-eVGA.com Geforce FX5200
-Antec SmartPower 350W  21A @+12v
-WD 160JB ATA-100 160Gig partitioned half FAT32 half NTFS
-WD 120JB ATA-100 120 Gig ReiserFS 3.6
-WD 3200YS SATA partitioned NTFS
-Memorex 16X DVD writer on Secondary Master
-Dual Boot Windows 2000 with ActiveX 9.0c and Gentoo Linux SMP kernel 2.6.19
T9246ED,大會編碼器
Offline Offline
« Reply #62 on: 23 March 07, 11:41:30 »
@ASegredo
open a new own thread, read Moan Guide and exlplain the problem there.
your newest CPU is X2 core?
do you use matched pairs memory sticks?
ensure you have used DIMM1(A) and DIMM2(B) mainboard slots.
Clear CMOS Guide then get a copy of Memtest86 and test memory for errors.
    * MSI K8N D-Plus
    * MSI 2xN260GTX-OC
ASegredo
Junior Member
Offline Offline
« Reply #63 on: 27 March 07, 12:15:03 »
Sorry, I've done that. You can remove these posts now.
-Award rev 1.D BIOS
Bas
Chief nut :-)
Administrator
Offline Offline
WWW
« Reply #64 on: 27 March 07, 12:44:39 »
We don't remove posts, as it might help others will the same problem.
Bas.
MediaLive
GmasterG
Offline Offline
« Reply #65 on: 30 March 07, 00:04:17 »
Let me see if I got this right before i change to X2 ... my computer is a ACPI Multiprocessor .... so can I put in the x2 and be ok and rock on or do I have to do something  confused2
MSI  MS-7125 (K8N Neo4-F) Plat
AMD 64 X2 4200+
Western Digital Caviar Internal - 120 GB - EIDE, IDE, DMA/ATA-100 - 65.6 Mbps - 7,200 RPM
Zalman 7700 pure copper 120 mm CPU fan
Zalman VF900 LED VGA Cooler w/ 8 memory heatsinks
Geforce 8600GT 256 mb DDR3 PCI-E
2x ballistix 184pin Pc4000 1gb =2gb-Timing: 3-4-4-8 cas latency= 3
Xion Supernova 600w PS-+3.3V@35A, +5V@53A, +12V1@22A, +12V2@22A, -5V@0.5A, -12V@0.8A, +5VSB@2.5A
SONY Black 16X DVD+R 8X DVD+RW 8X DVD+R Burner
NEC Beige 18X DVD+R 8X DVD+RW  Burner
Antec P-160 performance Case
GmasterG
Offline Offline
« Reply #66 on: 30 March 07, 00:10:01 »
one more thing... does my MOBO support X2?  I checked the MSI specs page and it doesn't mention X2 confused2
AMD 64 X2 4200+
Grayone
Forum God
Offline Offline
« Reply #67 on: 30 March 07, 00:14:50 »
Any dual core amd socket 939 cpu will work in your motherboard.
P6N Diamond
C2D E6600 @3.0Ghz @1.32v
GSkill 2x1gig PC6400 5-5-5-15-1T @1.95v
Hanns-g JW199D 19in. monitor
2 80Gig Maxtor SATA HD    Lite-On DVD-RW
2x 8800GS & 2x 9600GT video cards
Corsair 650TX- 3.3v/24A 5v/30A 12v/52A
Folding@Home 24/7 w/GPU2 & SMP clients
XP Pro w/SP3
K8N Neo4-F (PCB 3.0)
AMD X2 4200+ @ 230x11 @1.38v
GSkill ZX 2x1gig DDR400 @2.5-3-2-5-1T@2.6v
8800GT video card
160gig WD HD - Samsung DVD burner
Corsair VX450- 3.3v@20amp-5v@20amp-12v@33amp
XP Pro w/SP3
GmasterG
Offline Offline
« Reply #68 on: 30 March 07, 01:01:08 »
Cool thanks Greyone... I wont put in the new processor till I figure out the sound problem.  but if you got time to read this thread it's really helpful
AMD 64 X2 4200+
techsan97
Newbie
Offline Offline
« Reply #69 on: 05 April 07, 18:29:35 »
I just upgraded from single core to X2 4400.  I show ACPI multiprocessor after updating the driver but in the task manager I only show one use graph.  Am I running single core still or dual core?  If single, do I need to  change the HAL?  I can put a PC together but all that seemed like more than I am comfortable doing since I didn't know what most of it meant or how to go about doing it.  Is that the only way to avoid doing a new XP install?
T9246ED,大會編碼器
Offline Offline
« Reply #70 on: 05 April 07, 18:40:34 »
hello,
do mainboard detect CPU property?
reboot.
reboot, re-test. (check it from device manager:
    * MSI K8N D-Plus
    * MSI 2xN260GTX-OC
techsan97
Newbie
Offline Offline
« Reply #71 on: 05 April 07, 19:59:07 »
already installed the hot fix. Will try the optimizer.
thanks.
GmasterG
Offline Offline
« Reply #72 on: 20 April 07, 04:29:40 »
Ok, so I am just flat out confused after reading through this thread.... I looked and in my computer manager it shows "ACPI Uniproccessor"  I took out my amd 3200 + and stuck in the X2 and everything booted perfectly and started windows like normal, now I do not know exactly how to check to see if both cores are running....can someone post a screeny of what the task manager should look like if they are running?  If they are not I am just going to do a fresh XP install ...my external HD makes doing this fairly easy.  THen once OS is fresh install what things do I need to download and install after that or do I have to do any?  Please help my head hurts after reading this whole thread....aye everyone has different solututions I don;t know what to do...i'm not dumb just burnt out ofter working 8-12 hours a day in the office  sleep  rolleyes_anim
AMD 64 X2 4200+
GmasterG
Offline Offline
« Reply #73 on: 20 April 07, 04:54:34 »
Also do I need a BIOS update?  I have never updated BIOS before so I don't how to do that ...i'm learning bear  with me   Undecided
AMD 64 X2 4200+
GmasterG
Offline Offline
« Reply #74 on: 20 April 07, 08:15:34 »
Ok this is weird ... I just checked my Computer in hardware manager and it now says ACPI multiprocessor computer after installing the X2 chip is it ok or do I have to do more stuff?
AMD 64 X2 4200+
T9246ED,大會編碼器
Offline Offline
« Reply #75 on: 20 April 07, 08:17:55 »
all you need is here:
http://forum-en.msi.com/index.php?topic=101539.msg794341#msg794341
(can install dual core optimizer from the link)
seem fine to me.
    * MSI K8N D-Plus
    * MSI 2xN260GTX-OC
greig2000_uk
Full Member
Offline Offline
« Reply #76 on: 08 May 07, 23:27:58 »
Im confused by this whole thread!
I installed my new Opty 175, It recognised OK in my system. ACPI MultiProcessor PC with both cores reported under CPU in Device manager, Task Manager showing 2 graphs for both cores, all looks good so far.
Installed the MS Hotfix (never done the PerfEnablePackageIdle registry edit, is this maybe a problem?) then the AMD Optimiser, everything still looking good.
reboot.
This is the order I installed the fixes, as per BOSSMANS instructions.
I cant see the MS hotfix KB896256 in ADD/REMOVE programs??
AMD fix is there though.
My Problem is the same as mremulator's described in this thread http://forum-en.msi.com/index.php?topic=101922.0
No No No, the dual core optimiser and MS Hotfix are NOT compatible.
I made the mistake of installing the two and Windows XP would reboot at desktop. AMD have confirmed this.
I have the desktop reboot problem, though not all the time. Seems to be when I've been in the BIOS (no changes made) or recently I ran Memtest for 16 passes (no errors) and rebooted to the reboot cycle again.
I was thinking of just doing a re-install but after reading the above thread it looks like I will have the same problem after installing both dual core fixes?
I have a Ghost Image of my upgrade before the Dual Core fixes where installed and was thinking of going back to this to try again to fix the reboot cycle problem, will this be a good Idea?
Also, any ideas as to whay the MS Hotfix doesnt show in ADD/REMOVE programs? (show updates is ticked)
Can someone please give me a clear route to Installing the fixes (if they are applicable), and if the registry edit for the MS Hotfix is needed???
Any help (and Patience) is much appreciated Smiley
g2k.
MSI Neo2 Platinum BIOS 1.D0
AMD Opteron 64 175, Socket 939, (Denmark Core, 2x 2.2GHz, 2MB Cache cooled with Zalman 7000B)
2Ghz Corsair twinx XMS (2.3.3.6 1T)
550W Antec True Power
MSI 6600GT GPU (AGP)
XP+SP2
Wester Digital 74GB Raptor (C:)
2X Seagate Baracuda SATA 300GB in RAID0
2X 120GB 7K2 IDE HDD
GmasterG
Offline Offline
« Reply #77 on: 09 May 07, 05:04:04 »
ok so I have been having a problem... I recently installed my Duel Core 4200 x2 939 and everything was good did a fresh install of Windows XP I installed the windows hotfix and then the AMD dual core optimizer and it seemed to slow me down a little so I re installed windows again and decided not to install the windows hotfix nor the AMD optimizer.....so the problem I am facing is when I power on the computer shows the Platinum start up Picture then goes to next screen but before it gets to the Windows XP splash/loading screen it it Pitch black for 4/5 minutes each time(timed it) .... what is causing this?
AMD 64 X2 4200+
rakesh27
Junior Member
Offline Offline
« Reply #78 on: 15 October 07, 23:12:33 »
Guys,
I own a MSI K8N Neo2 Plat bios v1d mobo and currently using a AMD64 FX55 skt939 single core, shortly i will upgrade to a AMD64 FX60 Dual Core.
Question is should i do the fix copy the files and change my boot.ini or could i just swap the cpus and power up and hopefully windows will detect the dual core.
Please reply asap
Thanks
gvguy39
Offline Offline
« Reply #79 on: 13 March 08, 00:48:28 »
Maybe I have missed it, but does this apply to Windows Vista (64bit), or will it detect a dual core when installed when a single core was present when operating system was initially installed?  Currently, it reads in device manager ACPI x64-based PC
MSI K9N Neo F vsn3 Bios 2.6
MSI 9500 GT 512Gb
AMD Athlon 64 X2 5600+ Windsor 2.8GHz
4x1 GB G Skill DDR II 800MHz
2x WD 640Gb SATA Raid 0
Lite-On 20x DVD burner
Antec NeoPower 650w Blue
Windows 7 RC (64bit)
Pages: 1 [2] 3  All   Go Up
  Print
Jump to:
Page created in 0.276 seconds with 19 queries.
