Author Topic: Help. error: realtek rtl8110s/8169s gigabit boot agent  (Read 2528 times)
TreeMaker
« on: 16-October-06, 20:44:15 »
Hi everyone.
I have recently built an AMD system and im experiencing some problems so i wondered if anyone here can help. It will be much appriciated.
The system works perfectly apart from when i am reseting. Then it hangs and gives me the error message:
'NVIDIA RAID IDE ROM BIOS 4.81 Copyright (c) 2004 NVIDIA Corp.
Detecting array...
Realtek RTL8110s/8169s Gigabit Boot Agent
Press shift - F10 to configure....'
Now when this happens, the keyboard is not working and therefor i cant do much.
Even if i try top log into BIOS, after reseting, the keyboard is not working. I have tried a different keyboard with not much luck.
I have cleared the Cmos and dissabled the RAID, but I still get the same error when ever i restart.
The only way to avoid the error screen is to use the on and off button.
My system is:  AMD Sempron 2000
                    K8N Neo v2.0, nVidia nForce3 250 Chipset Based
Any help will be much appriciated.
thanks
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
Re: Help. error: realtek rtl8110s/8169s gigabit boot agent
« Reply #1 on: 16-October-06, 20:50:42 »
remove power cord from the PSU before clear BIOS.
enter in BIOS and disable Onboard LAN ROM.
disable Boot from LAN, and setup property/correct boot device (example: 1st boot HDD-0)
