Go Search!!
Home
MSI HQ User to User Forum
09 February 10, 19:58:26 *
News: Do NOT use M-FLash for BIOS flashing! It kills boards!
>>USE THE FORUM FLASHER INSTEAD!! It's 100% safe!! Click me to get there!!<<
Pages: 1 ... 3 [4]  All   Go Down
  Print
Author Topic: HOW TO switch from IDE to AHCI mode without having to reinstall Win XP (GUIDE)  (Read 122382 times)
0 Members and 5 Guests are viewing this topic.
trimarky
Junior Member
Offline Offline
« Reply #120 on: 18 December 08, 06:53:11 »
Worked very good in my system P45Platinum with Samsung HD502IJ and boot a little bit  slowly but the programs run more faster than IDE, nice guide thx man
MSI P45 Platinum, E8400 @3.00Ghz,
KHX8500D2K2/2G @ 1066
MSI HD4850, Hp w2207
Corsair TX650w
Creative X-Fi Platinum, Inspire p7800
Logitech G5/G15
CryTek
Offline Offline
« Reply #121 on: 27 December 08, 01:23:51 »
Thanx  Hat-tip
Vista Ultimate 64bit
Desktop PC
Intel®Core i7™ 920
MSI X58 pro-e  Bios 8.5
3x2GB tripple Channel
twinMOS DDR3 1333
2xATI® Radeon™ HD4870 1GB GDDR5 CrossfireX
Maxtor 500GB@7200RPM
Creative Audigy2 ZS
LG M228WA 22" LCD
Gigabyte Superb720W PSU
queequeg
Newbie
Offline Offline
« Reply #122 on: 29 April 09, 01:58:24 »
I'm looking to do this, but have an nvidia motherboard.  Has anybody have the correct .reg settings for the nvidia (nforce) AHCI/RAID controller instead of the intel one?
Jack t.N.
MSIHQ Red Rockets Team Member
Offline Offline
汉语?
« Reply #123 on: 29 April 09, 02:31:50 »
I have not came upon a reg file for NVIDIA Chipsets.  Reinstalling the OS will probably cost you less time than piecing a proper reg file together.
Current System:
E6600 @3.6 GHz, EIST enabl./C1E=enabl., VCore=1.33V -- P45 Platinum, BIOS v1.7b4 -- 2Gb Kingston HyperX KHX8500D2K2/2G @1067 MHz, 2V, 5-5-5-18 -- MSI N295GTX-M2D1792 -- Corsair VX-550W, 41A@12V
bratboy
Newbie
Offline Offline
« Reply #124 on: 12 July 09, 03:52:24 »
A bit back I decided to give ACHI a shot on my Win7 system. While things worked I really didn't see any real improvement so was wanting to switch back to SATA mode. To do this I had to change a single key in the registry, reboot into the bios and then switch that from SATA to ACHI and reboot into Win 7 which then installed the needed drivers.
Is it a simple thing ie just change the setting in the Bios from ACHI to SATA and rebooting into Win7 or do I need to make a change in the registry file to go back to SATA?
Jack t.N.
Offline Offline
汉语?
« Reply #125 on: 16 July 09, 10:00:29 »
What board/chipset are you talking about?
AHCI is a native SATA Mode.  There is not necessarely a major performance difference between IDE/Legacy Mode and AHCI Mode.
Current System:
Hell Racer
Newbie
Offline Offline
« Reply #126 on: 31 October 09, 11:25:17 »
Hi! Awesome guide! Smiley
Do you know is it possible to switch from AHCI (or RAID non-member) to IDE without reinstalling, if Windows was installed in AHCI mode (using slipstreamed drivers)?
Jack t.N.
Offline Offline
汉语?
« Reply #127 on: 31 October 09, 11:58:18 »
The switch back to IDE Mode is usually no problem (not even for XP).  Usually, no further adjustments are necessary.
Current System:
Hell Racer
Newbie
Offline Offline
« Reply #128 on: 31 October 09, 12:28:08 »
Right now I have Windows XP SP3 installed in RAID non-member mode, and switching to IDE causes BSOD Sad.
faber
Newbie
Offline Offline
« Reply #129 on: 06 November 09, 20:10:12 »
For ICH9M the correct registry file is
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\CriticalDeviceDatabase\pci#ven_8086&dev_2929&cc_0106]
"Service"="iaStor"
"ClassGUID"="{4D36E96A-E325-11CE-BFC1-08002BE10318}"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor]
"Type"=dword:00000001
"Start"=dword:00000000
"Group"="SCSI miniport"
"ErrorControl"=dword:00000001
"ImagePath"="system32\\drivers\\iaStor.sys"
"tag"=dword:00000019
"DisplayName"="Intel AHCI Controller"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters]
"queuePriorityEnable"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Enum]
"0"="PCI\\VEN_8086&DEV_2929&SUBSYS_B0051458&REV_02\\3&13c0b0c5&0&FA"
"Count"=dword:00000001
"NextInstance"=dword:00000001
I tested in ACER Extensa 5230E and i've success.
Sorry for my English
higado2
Newbie
Offline Offline
« Reply #130 on: 01 December 09, 01:45:26 »
I just registered so that I can thank Jack the Newbie for this most useful thread and to thank DJ Ramses and straddy for their suggestion to use an "alterlative method" that doesn't involve tinkering with the registry (thank god!). I personally ran into this problem when downgrading to Windows XP SP3 on an Acer Aspire 5735-6649 laptop. The Cd I used had the latest Intel SATA AHCI textmode drivers slipstreamed correctly into it, and yet still I would get that dreaded BSOD when I switched to AHCI mode in the BIOS when I tried to install Windows XP, so I had to use IDE mode. I tried the registry method after the install, but I guess since this laptop uses ICH9M, it didn't work.
Here are the instructions again so that others who keep getting the BSOD can get AHCI working on their computer running Windows XP (SP3 hopefully!):
* Extract the SATA AHCI drivers from IATAxxENU.exe by doing the following (xx is whatever the current version of that file is now. Mine was 89):
 - copy IATAxxENU.exe to C:\
 - go to Start > Run
 - type the following in the box that appears then press enter:
   cmd
 - now type this then press enter:
   cd..
 - now type the following then press enter:
   IATAxxENU.exe -a -a
 - Relax! nothing is getting installed! eventhough it looks like it. All that is happening is that the driver files are being copied to C:\Program Files\Intel\IntelStor or something similar
 - remember this location as you will be needing it later
* Go to Device Manager > IDE ATA/ATAPI Controllers
* Right click on the first "Intel (some number like ICH9M) SATA IDE Controller" you find (the one that can't be disabled), then click "Update Driver..."
* Make a note of that ICHxx number as you will be needing it later. For example, like "ICH9M" mentioned above
* Now cancel the "search on the web" window, then select "Install from a list or specific location (Advanced)" then click next
* Now select the bottom choice "Don't Search. I will choose the driver to install" then click next
* Now uncheck the "Show compatible hardware" box, then click the "Have Disk..." button
* Now click browse and locate the folder with the drivers made earlier, find "iaAHCI" then click Open, then OK
* Now select the driver that most closely matches your controller number, in this example we will be using the one that has ICH9M then click ok
* You will be given a strong warning .... ignore it and click ok and continue
* Once windows is done it will ask you to reboot. So do that. BUT be ready to enter your computer's bios as soon as you reboot!
* Go to your BIOS and change your controller from IDE mode to AHCI. Save and exit.
* WOW! Windows didn't crash! Once windows finishes installing the correct controller it will ask for a restart and you reboot, you will be running AHCI in Windows XP! YEEEEEEEEEEEAAAAAAAAAAAHHHHHHHH!!!  lol_anim
And this is how I got AHCI working on an Acer Asperi 5735-6694 laptop. I know that this forum is for MSI motherboards, but my search for help on this subject on Google brought me to this thread so I hope that others who run into this problem will be able to benefit from it in the future .... well, at least until Windows XP becomes obsolete! hehehe. Again, many thanks to Jack the Newbie for this making this thread and to DJ Ramses and straddy for discovering the best method to solve this problem!  biggthumbsup
monographix
Full Member
Offline Offline
« Reply #131 on: 18 December 09, 23:48:04 »
Hello
- Is out there maybe some similar registry edit for the P55 chipset?
- What actually is the sata chipset in P55 boards ? (is there no southbridge anymore? ICHXX ?)
Jack, maybe should add to the original guide-post the ICH9M reglines provided here as well? Smiley
« Last Edit: 19 December 09, 01:19:30 by monographix » Logged
Q6600 @ 3 :: 2x1Gb Transcend Axeram 800 @ 1066 5-5-5-15 2.10v:: 8800GT @ 700/1000
MSI P35 Neo2-FR :: Hiper 480 Type-R :: Raptor 36 :: WD2500YS
monographix
Full Member
Offline Offline
« Reply #132 on: 20 December 09, 02:49:46 »
is it maybe ICH10(R) the sata controller in P55 boards?
warlocklw
Newbie
Offline Offline
« Reply #133 on: 01 February 10, 06:25:10 »
Register here to say thanks. It works.
Thanks to Jack t.N.
Most thanks to higado2 because the steps solve my problem.
Pages: 1 ... 3 [4]  All   Go Up
  Print
Jump to:
Page created in 0.15 seconds with 19 queries.
