Go Search!!
Home
MSI HQ User to User Forum
09 February 10, 20:59:52 *
News: How do you flash your BIOS, please take part in our poll, thank you! >>How do you flash?<<
Pages: 1 2 [3] 4  All   Go Down
  Print
Author Topic: HOW TO switch from IDE to AHCI mode without having to reinstall Win XP (GUIDE)  (Read 122407 times)
0 Members and 8 Guests are viewing this topic.
wonderwrench
Double Ace
Offline Offline
« Reply #80 on: 14 February 08, 01:06:28 »
I wonder why I can't get it to work. The guide is so simple and easy to follow. Copy reg text to text file, change .txt extension to .reg, double click reg file, say yes to prompt. Copy iastor.sys to windows\system32\drivers folder. Reboot change to AHCI mode, save and exit bios, blue screen!
C2D E6400 @ 3 Ghz*MSI P35 Neo2-FR bios 1.8*2X 2 gig Corsair DDR2 800 XMS2 ram*Evga 8800GT SSC *Seagate 7200.10 320 gig SATA HD*LiteOn sohw-1693s*Plextor PX 716a*Teac Floppy*SB Audigy 1 Gamer*FSP AX450-PN PSU* Rosewill R6AR6-BK case*XP pro sp2 32 bit
Good judgment comes from experience, and often experience comes from bad judgment.
Jack t.N.
MSIHQ Red Rockets Team Member
Offline Offline
汉语?
« Reply #81 on: 14 February 08, 09:39:35 »
Hello wonderwrench,
which content did you use for your reg-file?
Have you tried the code provided my monographix?
http://forum-en.msi.com/index.php?topic=106575.msg844741#msg844741
Current System:
E6600 @3.6 GHz, EIST enabl./C1E=enabl., VCore=1.33V -- P45 Platinum, BIOS v1.7b4 -- 2Gb Kingston HyperX KHX8500D2K2/2G @1067 MHz, 2V, 5-5-5-18 -- MSI N295GTX-M2D1792 -- Corsair VX-550W, 41A@12V
wonderwrench
Double Ace
Offline Offline
« Reply #82 on: 20 February 08, 18:51:40 »
Hello wonderwrench,
That did it! Using the correct reg-file worked. Things work better when you pay attention to what you are doing.
Could the original post be updated so the different reg-files for the different chipsets easily accessible? Giving monographix credit of course.
Some quick testing shows no performance gain by enabling AHCI mode. I did not think it would. Just wanted to see the outcome.
« Last Edit: 20 February 08, 18:54:25 by wonderwrench » Logged
Jack t.N.
Offline Offline
汉语?
« Reply #83 on: 20 February 08, 19:17:19 »
That did it!
 biggthumbsup
Not a bad idea actually.  Maybe I get to it on the weekend.
Current System:
belkin
Junior Member
Offline Offline
« Reply #84 on: 20 March 08, 15:00:19 »
Is there a guide for Windows Vista SP1?
MSI P35 Platinum edition Core Due 2 Extreme
vernonion
MSI HQ Red Rockets Team Member
King
Offline Offline
« Reply #85 on: 20 March 08, 15:21:41 »
Yes, Vista nativly supports AHCI and does not require any additional drivers. Simply change one registry switch then go into bios and turn on AHCI mode. Vista only enables AHCI on Install if the hardware requires it.
« Last Edit: 22 June 08, 19:26:49 by vernonion » Logged
MSI K7N2 Delta 2 Platinum  (Storage)
Athlon XP 2600 Mobile @ 198 x 11.5 Pvt = 2.3 GHZ
Tt Pipe 101/Zalman120
OCZ 512 x 2 PC 3500 Performance Dual channel 3,3,3,11
PNY GForce FX5700 Personal Cinema
PSU Roswill 450 3.3v/30a 5v/45a 12v/17a,16a
WD PATA 120 Gig HD
Win XP Pro SP2
Compaq 15" CRT
Apex 'Elvis' case
HTPC (Storage)
MSI K8NGM2-FID,Bios 3.6
AMD64 4400 X2, 2.37 Ghz
Thermaltake Blue Orb
GSkill DDR 3200, 1024 x 2, 2.5-3-3-6-1T
EVGA 8800GTS/640
Seagate 320 Sata, WinXP MCE / Vista Home Premium
Samsung DVDRW SH-S183L
PSU Antec Smart Power 500  3.3v/32a 5v/35a 12v/17a,19a (Temp)
Antec NSK 2400
TV Wonder Elite
LG L1920PQ LCD
mike1555
Junior Member
Offline Offline
« Reply #86 on: 19 May 08, 19:41:56 »
Thanks  Jack the Newbie ,this tutorial solved one (major) problem in 3 minutes ! Great !
Mike
fraggle
Double Ace
Offline Offline
« Reply #87 on: 24 May 08, 20:02:13 »
It works great for me and my P35 Neo2-FR. Very good guide.
THX Jack Hat-tip
sashabe
Newbie
Offline Offline
« Reply #88 on: 06 June 08, 10:18:32 »
Thanks! Worked beatifully on Asus P5B-E.
Phatkat
Newbie
Offline Offline
« Reply #89 on: 18 June 08, 09:11:35 »
Hi i am using an AMD 780G mobo - how can i switch to AHCI mode? Thanks in advance to any help rendered  agree
Del UK
Del UK
Forum God
Offline Offline
WWW
« Reply #90 on: 18 June 08, 10:32:30 »
You will probably be better off, asking in the AMD part of the forum....... yes
http://forum-en.msi.com/index.php?board=24.0  <--------Link to AMD Forum
Main system
MSI P45 FR3 V1, E8400 with Arctic Cooling Alpine 7, Corsair VX 550, ATI 5770, 8Gb DDR2 Corsair XMS2, onboard NIC/Audio, WD 160 & 500 RE drives, Opti DVD, Enermax batwing 120's. Win 7 64bit
2nd System
Duo2 E6600 @ 3.2, Thermalright SI-128 with Enermax Batwing 120mm Fan
MSI P965 Plat 1.6bios,XMS2 PC5300 4x1GB, Corsiar VX 650, Nvidia 9800GT, XP Pro SP3 / Suse 10.3 64bit
3rd System
E6750 @ 2.8 Arctic Cooling Alphine 7
MSI P35 Neo2 FR 1.9bios, XMS2 PC6400 4x2Gb, Corsair VX550, Nvidia MSI 9800GT, Sata ONLY. Suse 10.3 64Bit / XP pro 32Bit
Sukhoi
Offline Offline
« Reply #91 on: 21 June 08, 04:30:51 »
sorry if you has answered that problem a lot of times yet, but its difficult to me understand that (and the English too  Tongue ).
I have the MSI P35 neo2-FR (ich9r) / e4400 / Win XP SP3. You can say me if the steps which I do are ok?
1- Make the .reg file as the first post explain.
2- Download last version of Intel Matrix Storage from http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&ProductID=2101&DwnldID=16012&strOSs=&OSFullName=&lang=spa . It download the file iata82_cd.exe but when I have to install it? now?
If I do it:
3- I suposse it crate the folder \Program Files\Intel\Intel Matrix Storage Manager\Driver . Then I can find the file iaStor.sys there, and I have to copy it to "Windows\System32\Drivers"
4- Reboot and select in bios AHCI mode.
Those are ok? I have to change anything y the reg file?
thankyou so much
MSI P35 Neo2-FR | e4400 @3.2 Ghz + Kingwin Revolution RVT-12025 | 2x1Gb SuperTalent 667@960mhz 5-5-5-15 | XFX 8600GT XXX
VTB Col55-B-PFC 550W | WD Caviar 160Gb 8Mb + Maxtor 40Gb IDE | Samsung 20" 206NW
Del UK
Del UK
Forum God
Offline Offline
WWW
« Reply #92 on: 21 June 08, 11:04:15 »
Open Notepad.
Highlight and copy the text below.
For ICH9
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\CriticalDeviceDatabase\pci#ven_8086&dev_2922&cc_0106]
"Service"="iaStor"
"ClassGUID"="{4D36E96A-E325-11CE-BFC1-08002BE10318}"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor]
"Type"=dword:00000001
"Start"=dword:00000000
"Group"="SCSI miniport"
"ErrorControl"=dword:00000001
"ImagePath"="system32\\drivers\\iaStor.sys"
"tag"=dword:00000019
"DisplayName"="Intel AHCI Controller"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters]
"queuePriorityEnable"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Enum]
"0"="PCI\\VEN_8086&DEV_2922&SUBSYS_B0051458&REV_02\\3&13c0b0c5&0&FA"
"Count"=dword:00000001
"NextInstance"=dword:00000001
Now, save as achi.reg
You have to register the files with the operating system, because you are changing the way the disks are read & written to.
If you follow the instructions on page one of this thread, it will take about 15 minutes to complete.
Main system
2nd System
3rd System
Jack t.N.
Offline Offline
汉语?
« Reply #93 on: 21 June 08, 11:40:54 »
If I do it:
You cannot simply execute iata82_cd.exe.  If you do that, it will give you an error message saying that your hardware is not supported (AHCI or RAID mode need to be enabled for the Intel Matrix Storage Manager to be able to be installed). What you have to do before you restart your system and switch to AHCI mode is to extract the actual driver files.  I explained that in my first post as well:
Second Step:
Copy the iaStor.sys-File into the \Windows\System32\Drivers\-Folder if it isn't in there already.
The file is part of the of the Intel Matrix Storage Manager-Packet (IATA621_CD.EXE) and can be retrieved manually:
\START\Run --> IATA621_CD.EXE -a -a [or in your case: iata82_cd.exe -a -a ]
After entering this command the file should be in the following folder:
...\Program Files\Intel\Intel Matrix Storage Manager\Driver
...and ready to be copied.
Current System:
Sukhoi
Offline Offline
« Reply #94 on: 21 June 08, 20:04:43 »
yessss.. finally I could!. But following anothers steps: I get the "iaStor.sys" file from another forum and copied it to windows/...../drivers. Then I ran the reg file. Reboot and install iata82_cd.exe..
It worked good, my time boot is much faster than before:
IDE Mode:
AHCI Mode:
Although the boot is quickly, it lose several seconds before the windows screen appear, just waiting something with a "dash" in the up left corner of the screen.
Cheking BIOS I found that option:
what's the meaning of "AHCI CD/DVD boot time out"? Does this relate to what I said above?
Thankyou, that forum is really good
Del UK
Del UK
Forum God
Offline Offline
WWW
« Reply #95 on: 21 June 08, 22:05:31 »
IDE Mode:
AHCI Mode:
That's great news.
Leave the CD/DVD timeout........ biggthumbsup
The delay, is just the drivers loading for multi - read/write. Nothing to be worried about.
Main system
2nd System
3rd System
Killer344
Newbie
Offline Offline
« Reply #96 on: 28 July 08, 01:17:34 »
Well, first, thanks jack, you showed me the path O.O , and second, here´s the reg file needed for the ich10r (the driver is also included).
http://rapidshare.com/files/132943510/Ahci_on_Xp.rar.html
I´ve just tested and it works fine.
« Last Edit: 28 July 08, 01:19:46 by Killer344 » Logged
bohdank
Junior Member
Offline Offline
« Reply #97 on: 28 July 08, 03:08:24 »
What would be the process for enabling RAID ? I want to, eventually, run RAID 1 on a second and third drive.
MSI P35 Neo2-FR Motherboard  1.08
Intel Core 2 Duo E8400
OCZ Platinum Revision-2 2048MB PC6400 DDR2 800MHz Dual Channel Memory (2 x 1024MB)
PNY GeForce 8500 GT / 512MB DDR2
ThermalTake / PurePower W0100RU / 500-Watt
Seagate Barracuda 7200.10 2 x 250GB Hard Drive - 7200, 8MB, Serial ATA-300, OEM (RAID1)
Engenius EPI-3601S Wireless G Network Adapter - 108Mbps, 802.11g, PCI, Long Range
OldMSguy
Newbie
Offline Offline
« Reply #98 on: 05 August 08, 22:51:51 »
Has anyone successfully accomplished the switch for the P45 and ICH10R?
I just built a system with the P45 Neo 3 (MS-7514)
Getting the hot swap capability would make working with my data archive hard drives a lot easier.
Any help with the registry tweaks would be greatly appreciated
Jack t.N.
Offline Offline
汉语?
« Reply #99 on: 06 August 08, 12:46:09 »
Hello OldMSguy,
the procedure is basically the same as for the other Intel Chipsets (see my first post).  The only difference should be a small variation within the reg-file you have to create. Unfortunately, I do not have the content for ICH10, but for ICH10R only.  I will provide you with the link to a ready-made reg-file that you can try. It may work for ICH10 as well, but I have no way to test it yet, as I do not have an ICH10-Board here:
Direct link to REG-File:  http://www.jzelectronic.de/jz2/Download2/ICH10R-AHCI.reg
Original Context: http://62.109.81.232/cgi-bin/sbb/sbb.cgi?&a=show&forum=1&show=7578&start=0#1
THX @ JZ
Content:
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\CriticalDeviceDatabase\pci#ven_8086&dev_3A22&cc_0106]
"Service"="iaStor"
"BusType"=dword:00000003
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port0]
"AN"=dword:00000000
"LPM"=dword:00000001
"LPMSTATE"=dword:00000000
"LPMDSTATE"=dword:00000001
"GTF"=dword:00000000
"DIPM"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port1]
"AN"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port2]
"AN"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port3]
"AN"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port4]
"AN"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port5]
"AN"=dword:00000000
"0"="PCI\\VEN_8086&DEV_3A22&SUBSYS_B0051458&REV_01\\3&13c0b0c5&0&FA"
If that does not work for ICH10 please say so.  Maybe we only have to change the vendor ID slightly.
Current System:
OldMSguy
Newbie
Offline Offline
« Reply #100 on: 07 August 08, 08:11:49 »
Thanks for the reply Jack.
I do have the ICH10R southbridge, and I followed your guide.
I can't get the AICH to work, and it has nothing to do with your solution, I have another problem.
If I can get past this new problem, I am sure your solution will solve the rest.
There is something not working right with the BIOS and/or CMOS settings.
Anyways, I changed the onboard SATA setting from IDE to AICH, and only had one 60gig SATA drive, attached to port 1 of the
onboard SATA. The JMicron SATA is set to IDE, any other setting, and the machine cannot see my CD/DVD drives on the IDE
Channel. I have tried various combinations of settings involving 1.)boot sequence 2.) onboard SATA, and 3.) the JMicron SATA.
The system sees the 60gig drive at boot, but at the time that it goes to the boot menu, I get this message:
"Reboot and select a proper boot device or insert bootl media in the selected device."
If I reboot, and go back into the CMOS, and change back to IDE for the onboard SATA, Windows XP (SP3 and fully updated, with the registry changes
and driver copy in place, per your guide) boots right up. By the way I'm using "iata82_enu.exe", from the Intel website.
I checked the reviews for the board at Newegg, where I bought it, and it seems that the ver 1.3 BIOS might be problematic.
I have read about that in other forums. I will probably flash back to 1.2 (there were no reviews when I bought the board)
I realize that my problem has nothing to do with directly with this thread, or my initial problem.
However, if anyone following this thread has had a similar issue, or can point me to a source for a detailed explanation of the
AMI BIOS CMOS settings, I might be able to get past this stumbling block.
Once again Jack, thanks for your help, and for staying on top of this thread.
I am sure you have been a great help to a lot of puzzled and frustrated system builders.
jlodvo
Offline Offline
« Reply #101 on: 09 August 08, 07:28:42 »
is thier a guide for p45 platinum and windows xp 64bit?
jlodvo
Offline Offline
« Reply #102 on: 09 August 08, 08:24:27 »
i tried the ich10r reg file now it works but i have something wierd, before i always count the bar flashing left to right when windows starts with then windows logo, my p45 ide mode before was max 4 bars flashing then it loads to windows now when i did this achi mode i get upto 10 flash, its kinda long anyone know why?
and i have doen the achi to ide reg b4 in my other p35 system it has a max of 3.5 flash either in ide mode or in achi
im just wondering why it takes more then twice now to finish the flashing (running bar from left to right) so it basically longer for me now to boot
jlodvo
Offline Offline
« Reply #103 on: 09 August 08, 08:41:40 »
here a little quick test i tried using the windows boot timer
achi mode 52 seconds
ide mode 47.640 seconds
so for me i get faster boot time with ide mode dont know why
DJRamses
Offline Offline
« Reply #104 on: 13 August 08, 12:34:35 »
perhaps i have a other way:
Now go to your Device Manager. Klick on your IDE/ATAPI Controller. Right click on intel(R) XXXXX Bus Master Ide Controller. Klick on Driver update. Let Windows not search!
Klick on Search Driver manually from  a list!... Klick on Drive... search. Go to the place where you the IAstore.inf have placed.
klick OK. Remove the Check at "kompatible Hardware".Now in the List right, chose the right driver. On my (X48C Platinium) it was Intel(R) ICH9R/DO/DH SATA AHCI Controller.
Klick all ok. Ignore possibly warnings incompatible Hardware. Install the Driver. Make a Reboot and jump into Bios.
On integated Peripherals--->On-Chip ATA Devices chose AHCI. Save and exit the Bios and reboot.
Perhaps to make a check that Your Harddrive where the OS is installed, has the first Boot priority.
If necessary re enter Bios and change it.
I have make this way anymore. It works fine.
« Last Edit: 13 August 08, 13:22:26 by DJRamses » Logged
|MSI X48C Platinium 3.0 Bios7.31T
|Intel Core 2 Duo E8500 3,16GHz@4,2Ghz            |2024MB Ram(2x2048MB) DDR2 1066 OCZ Reaper HPC 5-5-5-13
|Cooling:Themaltake Big Water 745
|MSI N9800GTX+ T2D 512 OC
|Super Flow Pyramid 850Watt Power supply
Jack t.N.
Offline Offline
汉语?
« Reply #105 on: 13 August 08, 12:50:03 »
 lol_anim
Damn, that works like a charm.  Works perfectly on a P45 Platinum as well.  Windows XP bootet without problem.   biggthumbsup
I wonder why nobody ever thought of that.  Simple and effective.  That once again proves that the simplest solutions are usually the best.  agree
Current System:
straddy
Newbie
Offline Offline
« Reply #106 on: 20 August 08, 21:19:34 »
Ok I followed all the instructions carefully and did everything but I still get BSoD on boot.
Here's what I did:
I created the reg file (I have ICH8 and used the first set of code for ICH8). Double clicked reg file to install to registry.
I extracted the latest iata86_enu.exe, saved iaStor.sys in system32/drivers/
BIOS change from ATA to AHCI.
Boot, BSoD.
I've tried the ICH9 code with no luck.
Note that I have Windows XP on partition E:\, Vista boots on C:\ and is marked as the boot partition. I boot to XP via bootloader.
Jack t.N.
Offline Offline
汉语?
« Reply #107 on: 20 August 08, 21:22:01 »
What board do you have? What BIOS Version?
Current System:
straddy
Newbie
Offline Offline
« Reply #108 on: 20 August 08, 21:29:27 »
Hey, I figured it out.
Jack, your guide is missing a CRITICAL STEP, please update the first page with the following.
Once the intel drivers are extracted you have to do this:
Go to This Computer-> Properties -> Hardware -> Device manager.
Under IDE ATA/ATAPI-Controllers, right-click the first INTEL(R) Controller, and update the driver.
Manually install the driver!! Make sure in every step you choose yourself what drivers to install!!
Browse to the folder where you extracted the intel drivers and install the matching chipset driver.
I think this works for a broader range of boards than simply copying iaStor.sys to drivers.
Thanks!
Btw, I'm on an intel GM965 express chipset. Dell bios A06 :P Boots into Mac OS X Leopard with AHCI lol
« Last Edit: 20 August 08, 21:33:56 by straddy » Logged
Jack t.N.
Offline Offline
汉语?
« Reply #109 on: 20 August 08, 21:33:38 »
Actually, it is not.  The step you described is actually part of a different procedure.  This one:
http://forum-en.msi.com/index.php?topic=106575.msg899229#msg899229
Current System:
straddy
Newbie
Offline Offline
« Reply #110 on: 20 August 08, 21:38:47 »
Ah ok. I missed it though, which means other readers would probably miss it too. I think the method should be mentioned in the first post for newbies like me.
Jack t.N.
Offline Offline
汉语?
« Reply #111 on: 20 August 08, 21:41:38 »
I will include a link to that method as soon as I find the time.  biggthumbsup
[BTW:  The registry patch method only works if the registry code contains the proper Vendor ID of the Controller.  ICH8R and ICH9R use different vendor IDs than ICH8.  That could be the reason why you still got BSODs.]
Current System:
steve04
Newbie
Offline Offline
« Reply #112 on: 23 October 08, 04:37:25 »
Ok I have tried everything and this does not work.  I made the registry file (ICH10R) and ran it but I have no idea where this iaStor.sys is.  I searched my whole computer (and my XP cd) and it is on neither.  I also went to http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2101&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go! and downloaded those drivers.  When I install them it says my system does not meet the minimum requirements.  I also did a search for IATA621_CD.EXE and when I ran it , it also says I don't meet the requirements.  My specs are as follows...
Intel Core2Duo E8400 @ 3.0 GHZ
Asus P5Q Pro Mobo
GEForce 9600 GT Video Card
Western Digital Caviar SE16 WD7500AAKS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive
Maxtor 500 GB SATA II drive
Any help would be greatly appreciated!
Jack t.N.
Offline Offline
汉语?
« Reply #113 on: 23 October 08, 11:07:23 »
Please read my first post again and pay more attention to the part labeled "Second Step".  It explains how to extract the file you need without running the installer in the regular sense.
Asus P5Q Pro Mobo
Note that this is an MSI Forum that is concerned with MSI Products (not Asus products).  Please consult the Asus forum instead as you have an Asus mainboard.  That is what the Asus forum is there for.  Any further post regarding problems with procedures on your Asus board will be removed without notice; either by me or by another moderator.  Sorry.
Current System:
Jack t.N.
Offline Offline
汉语?
« Reply #114 on: 25 October 08, 12:09:39 »
@Wernox, this is an MSI-Forum concerned with MSI Products.  We do not offer support and help for non-MSI  Products.  That is why I removed your post.
But to answer your question very quickly as it is an easy one:  The Intel ICH6 Chipsatz does not support AHCI to begin with, so there is no point in trying to make it operate in AHCI mode.
You have a PM!
Current System:
Radical_53
Lord
Offline Offline
« Reply #115 on: 14 November 08, 11:33:02 »
Thanks alot, absolutely great guide. It wasn't enough that I had to re-activate Windows by phone because I forgot to set time and date at the first boot, I also forgot to set the ICH to AHCI. Now it works as supposed again, great help! Smiley
Intel i5-750 | MSI P55-GD65 | 4x2048MB G.Skill PC16000 Ripwjawz
Zotac GeForce GTX 285 | LianLi PC-60F
Enermax Modu82+ 625W (12V: 3x25A / 5V: 24A / 3.3V: 24A)
RonNielson
Newbie
Offline Offline
« Reply #116 on: 21 November 08, 05:09:59 »
When the update method described in DJ Ramses post #104 is used, is it still necessary to do the Reg update?  I am not clear about this.
Jack t.N.
Offline Offline
汉语?
« Reply #117 on: 21 November 08, 10:24:00 »
Just try without and see what happens.  That is the best way to find out.
Current System:
RonNielson
Newbie
Offline Offline
« Reply #118 on: 21 November 08, 19:41:33 »
Let me re-phrase the question - When YOU did this and it worked just fine, did YOU to the REG update? Is the REG update a part of the normal driver installation process that will happen automatically?
No need to create a problem if I don't need to.
Jack t.N.
Offline Offline
汉语?
« Reply #119 on: 21 November 08, 22:00:15 »
No, i did not have to.  If it does not work in your case, try with the reg file.  If you have further questions, please be so kind an provide more info about your system (Board/Southbridge and operating system are the most important things that you should mention in this case).
Current System:
Pages: 1 2 [3] 4  All   Go Up
  Print
Jump to:
Page created in 0.288 seconds with 19 queries.
