Gladiator
Newbie
Offline
« on: 08 August 07, 23:31:04 » |
hi! I have bought the notebook MSI GX700X with mainboard MS-1719x vers.1.000 and BIOS Build Date 06/15/2007 BIOS Version 080014 (as the programm MSI InfoView XP shows it). MSI Live Utility presents the same BIOS as being BIOS Version 1.0. Anyway, this BIOS seems to be only for Windows Vista. I have problems in installing the Windows XP SP2. Some drivers are reported incorrectly by Windows and especially the driver for the videocard (NVIDIA 8600) cannot be installed at all. I would like to ask you help me with the following info:
Is it possible to install on this notebook Windows XP SP2? If it is, how? ..where can I found BIOS for WIN XP?
thanks for HELP!!
Henry
MSI HQ Red Rockets Team Member
Offline
Carson City, NV, USA
« Reply #2 on: 09 August 07, 00:48:10 » |
There is a 3.0G BIOS shown for XP but all of the drivers are for Vista on the MSI website for GX700. I can only assume the GX700X is the Extreme Edition as it does not show a GX700X as such just Extreme & Performance Editions.
P45 Platinum/BIOS 1.6, Q6600 B3@3.0GHz, CM Hyper TX HSF A DATA 2x1GB PC6400 DDR2 800, XP Home/SP3 & W7 RC Corsair TX650W +12V~52A, MSI N260GTX 2D896 OCSPIBM 14GB PATA HDD, 2 Maxtor 80GB SATA HDD's SONY 52x24x52x burner Cooler Master Elite 330 (f@h rig) Sony Media Center PC P 560J 3.6GHz, XP Pro SP3, Intel MB of some kind MSI RX1950PRO-T2D256E, Corsair VX450W +12V~33A WD2500 250GB SATA, Sony DVD ROM, I/O Magic CD/DVD combo burner w/LightScribe
Gladiator
Newbie
Offline
« Reply #3 on: 09 August 07, 01:05:16 » |
Serial ATA's AHCI/RAID interface ...it's ok I use a FDD-USB
I still have problem with NVIDIA 8600M GT cannot install the driver !!
thanks a lot, will try it..all ...what you said...
Aaron
« Reply #4 on: 09 August 07, 02:46:03 » |
He was giving it as an example. I've looked every where I can think of, there is no driver for 8600M GT, except for MSI's one for Vista.
46" Samsung LED TV. Xbox 360. Modern Warfare 2... Honestly, who gives a damn about PC hardware anymore? As in a FO3 Nuka-Cola Quantum contaminated VGA?
Henry
Offline
« Reply #5 on: 09 August 07, 06:28:40 » |
AaronYuri, what about THIS Forceware 165.01 XP To me it looks like for XP and 8600M GT is in the list, your opinion please or anyone else for that matter.
« Last Edit: 09 August 07, 06:30:50 by HenryW »
Gerard
« Reply #6 on: 09 August 07, 10:28:37 » |
The X stands for OSLESS which means the notebook was not supplied with a OS by MSI.
If its Extreme the name would be, GX700E and for Performance its either GX700 or GX700P
Anyway, XP drivers are not yet WHQL certified so thats why they are not on the website. I think the driver from HenryW should work. If not, lemme know, i have a GX700 here and i can test it if you want.
longo213
« Reply #7 on: 09 August 07, 11:40:22 » |
I still have problem with NVIDIA 8600M GT cannot install the driver !! You're kidding me? The 8600M GT are supported in LaptopVideo2GO's modified INF files, so it means your card is supported as well! Look, if you didn't understand what I mentioned in the other threads, try to read this guide. Then go to NVIDIA support page, download the latest official WHQL ForceWare 162.18, unzip'em, replace the INF file as mentioned in the guide and you should be all set.
« Last Edit: 09 August 07, 14:00:35 by longo213 »
