Author Topic: Big Problem !! Missing XP Drivers for OEM Fujitsu Board  (Read 4951 times)
jeffryvr
Hi All,
Ive got a major issue.
Just bought 56 Fujitsu Siemens systems ( BAT:NL-P7PXM1-001  /  Scaleo Ji 1603/P4 630 512MB 160GB Vista )
I need to downgrade these systems to XP PRO because i need XPP to use it in my network.
Fujitsu gives no support on XPP drivers.
According to the information on the Fujitsu website they used an  MSI mainboard  ( MS-7275 VB  )
I just spoke to someone on the support desk of MSI Holland en he told me this mainboard MS-7275 VB  is an OEM mainboard.
Well i hope someone here can help me to get some XPP drivers?
  • Lightning!
    • event.msi.com/vga/lightning/
Re: Big Problem !! Missing XP Drivers for OEM Fujitsu Board
« Reply #1 on: 13-August-07, 12:51:53 »
Normaly we don't take care of oem boards but as you just want drivers...
Your MS-7225 uses ATI Radeon Xpress 200 chipset I guess so you need this:
http://ati.amd.com/support/drivers/xp/integrated-xp.html  (Catalyst Software Suite)
MSI Z87 MPOWER MAX (MS-7815) Bios 1.7B4
Core i7 4770K (C0) @ 4300.54 MHz, 1.216V
2*4GB ADATA AX3U2000GC4G9B-2G (1:8) 1066.8 MHz (DDR3-2133) @ 10-11-11-28-2T 1.54v
2*MSI GTX 780Ti GAMING 3G @ 1210/3500 (SLI)
256GB Samsung 830 SSD + 250GB Samsung 840 EVO
Corsair HX1050 +12V: 87.5A • +3.3V: 30A • +5V: 30A
Windows 8.1 Pro
RemusM
  • Memory Expert
  • Marshall
    • Necromanthus
« Reply #2 on: 13-August-07, 13:08:11 »
Quote from: jeffryvr
I don't remember the MS-7275 mainboard, but try these drivers:
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1185
They should work on your chipset.
Mainboard: HC85
Processor: Zilog Z80 3.5MHz
System RAM: 48KB
PSU: 5V/3A
OS: BASIC Spectrum Sinclair
note: NO overclocking!
Kankantrie
« Reply #3 on: 13-August-07, 13:54:30 »
Hi There,
I just tried the link you specified, from the first 3 drivers, the middle one wasn't any success. I'm now downloading the 180MB driver ati_system_drive_mb.zip. Hope that this one helps. I'm working together with jeffry on this issue.
I'll keep you posted, but the download speed for the large file is 8kb so it will take about 6 hours  :wall: :wall:
Kankantrie
« Reply #4 on: 13-August-07, 13:55:31 »
I tried this software package already, but no success. Thanks anyway.
RemusM
  • Memory Expert
  • Marshall
    • Necromanthus
« Reply #5 on: 13-August-07, 14:11:17 »
Quote from: Kankantrie
Hi There,
So the Realtek High Definition Audio Driver and the ATI System Drivers are installed now.
For the second one (Realtek ALC Series AC97 Audio Driver) try this one:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false#1
note: your sound chip should be ALC880.
Mainboard: HC85
System RAM: 48KB
PSU: 5V/3A
Kankantrie
« Reply #6 on: 13-August-07, 14:37:27 »
First of all, I think that I didn't explain it correct. At this moment. The on-board sound, a pci device and the SM Buscontroller aren't recognized. The only things recognized by XP (standard) and all the software I installed, are the LAN and VGA. Both on board. I just finished the installation of the 176MB file and this didn't help anything.
I think it has something to do with the chipset. This I say because there are yellow questionmarks for the audio, but if you go to control panel and lok at the installed audio, there is nothing there and it produces no sound.
Hope you all can help me.
By the way the link didn't show any drivers. I get an empty screen with nothing to select....
Thanks
« Last Edit: 13-August-07, 14:39:42 by Kankantrie »
RemusM
  • Memory Expert
  • Marshall
    • Necromanthus
« Reply #7 on: 13-August-07, 14:43:26 »
1) Be sure that AC97 Audio is enabled in BIOS.
2) If you cannot access the last link, download the AC'97 Audio Codecs from here: http://www.realtek.com.tw/downloads/
good luck.
Mainboard: HC85
System RAM: 48KB
PSU: 5V/3A
  • Lightning!
« Reply #8 on: 13-August-07, 14:47:23 »
Hmm, Msi also calls a nforce 430 oem board MS-7225 then you would need this: http://us.download.nvidia.com/Windows/nForce/standalone/430_410/8.26_11.09_nforce_winxp_english.exe
But as you state to use P4 in the scaleo you must have XPress200. So the ATI drivers would be right: First you need south bridge driver http://global.msi.com.tw/index.php?func=driverfile&dno=2427&i=0
then http://global.msi.com.tw/index.php?func=driverfile&dno=2344&i=0
First means install first!
Windows 8.1 Pro
Ex Forum User 3
  • Hawk
« Reply #9 on: 13-August-07, 15:45:29 »
Sorry you have to look at Fujitsu for drivers.
That's an OEM system, so drivers and layout can differ.
We can't help OEM systems here, sorry.
