Author Topic: Vista X64 MSI motherboard support  (Read 1849 times)
sameen
  • Neo
« on: 18-January-08, 13:10:06 »
tell me which  MSI motherboard supports Vista X64.any links .and il buy MSI board that supports AMD only (i am not confirmed about Nvidia or ATI)
Russ_xp
  • Big Bang
  • Folding 24/7
Re: Vista X64 MSI motherboard support
« Reply #1 on: 18-January-08, 13:29:55 »
« Last Edit: 18-January-08, 13:37:38 by Russ_xp »
MSI K9A2 Neo (1.7), Phenom 9850 Black 0811BPMW DD-MCTDX
8Gb (4x2) Corsair Dominator PC2-8500 5-5-5-15-2T, HD4870 EK-FC4870
Hitachi 160Gb SATA2, HP 1070i DVDRW, PCP&C 750w 60A
CM Centurion, XSPC 2xRS120, Bay Res, MCP655, Windows Server 2008 x64 Hyper-V, FAH_SMP+GPU
MSI K9A2 CFv1 (1.7), Phenom 9600 B2 0743APMW DD-MCTDX
4Gb (4x1) A-Data PC2-6400 5-5-5-18-2T, HD3870 XSPC Razor & HD3850 512Mb EK-FC3850
Hitachi 160Gb SATA2 & 2x160Gb SATA-RAID, NEC ND3520 DVDRW, PCP&C 750w 60A
CM Stacker, XSPC RS240, Bay Res, Eheim 1048, Windows Server 2008 x86, FAH_SMP+2xGPU
Belkin UPS 1500VA, Belkin Switch2 KVM, Acer X222Wd, SC101 400Gb zSAN, 10Mbps Cable BB, Safe@Office500w
PlayStation 3 - F@H 24/7
Richard
  • nForce & GeForce Guru
  • Hawk
« Reply #2 on: 18-January-08, 14:32:24 »
sameen,
If you want an nVidia Chipset for your mobo, go to the nVidia Website and see what Chipsets they have X64 Drivers for.
If you want an Intel Chipset for your mobo, go to the Intel Website and see what Chipsets they have X64 Drivers for.
If you want an Via Chipset for your mobo, go to the Via Website and see what Chipsets they have X64 Drivers for.
If you want an ATI Chipset for your mobo, go to the ATI Website and see what Chipsets they have X64 Drivers for.
If you want an AMD Chipset for your mobo, go to the AMD Website and see what Chipsets they have X64 Drivers for.
etc, etc, etc.
Now when you have the chipset you want, go to the MSI Website and get a mobo with that chipset. It is that simple.
Take Care,
Richard
Richard J. Gentil, Pres.
Custom Computers of Naples, Inc.
LANPARTY nF4 SLI-DR
Athlon64 3700+ Sandy
(o/c'd 2.8Ghz)
Zalman CNPS9500LED
2-1Gb Mushkin Extreme PC-4000 (Slots 2 & 4)
(o/c'd 510Mhz)
2 x MSI NX6800GT-T2D256 (o/c'd Stock)
X-Mystique 7.1 GOLD - Dolby Digital Live
2-WD Raptors Raid 0
(16k Stripe)
NEC 16 Dual Layer DVD+/-RW
Logitech Z-680 500W Dolby Digital DTS THX 5.1
Logitech MX1000 Laser Mouse
Saitek Eclipse Keyboard
sameen
  • Neo
« Reply #3 on: 20-January-08, 06:32:45 »
my question is still unanswered.
i simply want to know whether K92A Platinum and K92A C CF supports Vista x64 or not??
Ex Forum Mod
  • Hawk
« Reply #4 on: 20-January-08, 07:03:00 »
 You're question was too vague. Just about any of them can run Vista x64 but most people will tell you to use XP x64 instead of Vista x64. As far as ATI or nVidea I think Richard and Russ thought you meant chipset not video card. For the video card what ever you prefer will work. If you like nVidea better than ATI there is no problem using it on the K9A2 MB you have chosen.
Stu
  • Hawk
  • Online Online
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #5 on: 20-January-08, 17:27:28 »
That wasn't your original question. Did you click on the links provided? If there are drivers available for Vista 32/64, then it is supported
Richard
  • Hawk
« Reply #6 on: 21-January-08, 03:01:39 »
sameen,
etc, etc, etc.
Take Care,
Richard
Damn, I thought I had covered all the bases with that reply and by reading the post, you would have had the links to check GeForce as well as Radeon Vid Cards too.
I guess my post was too vague and was missed by sameen.
Richard
LANPARTY nF4 SLI-DR
(o/c'd 2.8Ghz)
Zalman CNPS9500LED
(o/c'd 510Mhz)
2-WD Raptors Raid 0
(16k Stripe)
Fredrik
  • Hawk
  • There's always a risk.
« Reply #7 on: 21-January-08, 14:09:13 »
And you made quite an effort, too, Richard!  :biggthumbsup: That list should come handy on many an occassion. Perhaps you should make the tags a bit more easy to see.
Totally off: 'Easy-to-see' reminds me of eavesdropping. We have a somewhat identical Swedish dialect word for it, öfsadropp or öfsadröpp meaning the same. Do you all know the originsof the word? I do! Could make an off the chart Grousey.  :smile:
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #8 on: 21-January-08, 19:34:49 »
The tags? Oh! the hotlinks! I often will flank mine with > marks, >>link<<, or make it red. Sometimes I've found the default color the forum assigns to links hard to discern.
#2:
MSI Wind U100
