Author Topic: My boot order keeps changing!!!  (Read 7830 times)
Keizer
  • Military Class
« on: 02-April-08, 17:21:33 »
 :wall: I am running a P6N SLI platinum mobo, and lately my boot order keeps changing. The other day I was restoring from an image with True image, and noticed that TI reported my "D storage drive" as "C", and my C drive as "D". I looked at my boot order in the bios, and my storage drive was set in the boot order ahead of my operating system drive. Then, this morning my system would not boot at all. So, I go into my bios, and my card reader was 1st in the boot order. I don't even want my card reader in the boot order PERIOD!!! Once I removed it from the boot order, my PC booted fine again. I also have "boot from other devices" set to "No". Why is this happening??
By the way, I am running the original bios v1.1 that my board came with from a year ago.
Thanks for any help!!!
MSI P45 Platinum
Core 2 Duo E8500 Wolfdale 3.16GHz
EVGA GTX 260
CORSAIR CMPSU-1000HX 1000W PSU
Two SATA WD 500 gig, 7200 RPM, 32 MB cache Caviar Black OS drive in RAID0
SATA WD 1 TB, 7200 RPM, 32 MB cache Caviar Black Storage drive
X-fi Sound card
Zalman 9900 CPU cooler
Eight gigs Corsair DDR2 8500 1066 RAM/Running 5 5 5 18/800/1.8v
Win 7 Home premium 64
DaLoona
  • Trinergy
  • Certified nutcase since 1974
Re: My boot order keeps changing!!!
« Reply #1 on: 02-April-08, 17:39:43 »
Was the image made from a D drive?
When I was installing xp64, with xp32 already on it, xp64  changed the bootorder too once it was installed, also in BIOS.
Strange but true  X-((
My c was my d and vice versa.
But by setting boot from other device,to no, now it functions normallly, or does it keep on happening?
« Last Edit: 02-April-08, 17:43:29 by DaLoona »
MSI Z68A-GD55(G3)//i5 2500K @4.5GHz, //Zalman CNPS10X Extreme
Gigabyte GV-N670OC-2GD, 1241/7008/MHz//8GB G.Skill 1600MHz@1866MHz 10-10-10-24-1T, 1.5V
Corsair Force3 120GB SSD, OS//1*WD1TB SATAIII HDD, storage//Samsung dvd burner
Seasonic M12II 750W +12V 62A//Silverstone RV02-BW v1.8 + USB 3.0 module
HP x23LED @1920x1080//Windows 7 x64
http://valid.canardpc.com/9h1u8n
http://www.techpowerup.com/gpuz/b52u5/
Keizer
  • Military Class
« Reply #2 on: 02-April-08, 17:56:38 »
The image file was created with the TI. It was an image file of my C drive, stored on my D drive. I would like to keep the imaging topic out of this as to avoid confusion. I only mentioned it, because that is how I discovered that my storage drive was set to boot before my operating system drive.
And, the problem is still happening with the "boot from other devices" set to "No".
Why can't I set my boot order the way I want it, and then have an option to lock it in that order? The mobo takes it upon itself to change the boot order anytime it feels like it.
MSI P45 Platinum
EVGA GTX 260
X-fi Sound card
DaLoona
  • Trinergy
« Reply #3 on: 02-April-08, 18:06:52 »
Ok sorry for the misunderstanding, but I'm only trying to help :hat tip:
You can change your boot setting in your bios, second menu from top, enter, then choose boot order, enter, set in order you want with enter en cursorkeys, save with F10
How old is it, maybe your battery is slowly dying.
Please post all your specs as in my sig, so when can be more helpful, thanks in advance  :hat tip:
Or maybe your bios needs updating?
Are you familiar with bios flashing, or is that to complicated for you, cause I dont know if you build it yourself or your a good amateur, pro, whatever, with pC's
Otherwise read here:
http://forum-en.msi.com/index.php?topic=113295.0
and here:
http://www.biosflash.com/e/bios-boot-cd.htm
But remember, flashing is at YOUR own risk and us forumusers can not be held responsible for faulty flashing and ended up dead hardware!!!!
So do it only as last resort and if you know what your doing.
But as said, please post specs in your sig next, including detailed info over psu, cause those are nasty troublemakers if you've got a bad one  :biggthumbsup:
« Last Edit: 02-April-08, 18:55:56 by DaLoona »
Keizer
  • Military Class
« Reply #4 on: 02-April-08, 18:32:10 »
Yes, I built the system myself about a year ago. And yes I have done bios flashing on one of my other home built PC's.  I have never updated the bios on this home built, because I have never really had any serious problems. I have had my boot order change occasionally, but now it seems to do it more often.....three times in the last two days.
Here's my specs:
P6N SLI platinum mobo, BIOS Version 1.1
Dual channel DDR2-800 SDRAM 5-5-5-12
Nvidia 8800 GTS graphics card 640 mb ram
WD 74 gig Raptor HD
120 gig Maxtor 7200 rpm storage drive
Creative X-fi sound card
Corsair power supply 620 WT
« Last Edit: 02-April-08, 18:36:14 by Keizer »
MSI P45 Platinum
EVGA GTX 260
X-fi Sound card
DaLoona
  • Trinergy
« Reply #5 on: 02-April-08, 18:55:16 »
Is that ram set to vendor settings or did you tweak that?
I've never seen 5-5-5-12, only 4-4-4-12, 4-4-4-15 and 5-5-5-15
Nevermind found it already.
try 5-5-5-15 and see what it does then
I'll be back   :hat tip:
« Last Edit: 02-April-08, 19:25:57 by DaLoona »
Keizer
  • Military Class
« Reply #6 on: 02-April-08, 19:03:39 »
Nevermind found it already?
5-5-5-12 is the vendor settings.
MSI P45 Platinum
EVGA GTX 260
X-fi Sound card
DaLoona
  • Trinergy
« Reply #7 on: 02-April-08, 19:26:06 »
Scan your HD's on faults, maybe you've got a dying HD. and is the bootsector damaged.
Or flash BIOS, cause you said it already did it from the start, might be flacky BIOS  :hat tip:
But dont point at me if it goes wrong, be sure of what you do, succes and keep us posted  :biggthumbsup:
« Last Edit: 02-April-08, 19:28:10 by DaLoona »
Keizer
  • Military Class
« Reply #8 on: 02-April-08, 19:42:40 »
Yeah, I have been thinking that all along. I went ahead and flashed my bios to the latest version on the MSI website. Thanks for the link on using a USB flash drive!!!  It worked great!!!  I went ahead and re-set my boot order, and made sure "boot from other devices" was set to "No".  We will see what happens.
I forgot to mention this. I have two USB 2 connections on the top of my case. I had to wire these from the mobo. It is these two USB connection points that cause the boot order trouble. For example, everything is fine with nothing plugged into those USB connections on the top of the case. Now, if I plug my card reader in, the mobo adds the reader to the boot order list, and sometimes re-arranges my boot order, and has the card reader set to be the first in line to boot. I am not sure, but I think I was having the same issue when I plugged my reader directly into the USB 2 ports on the back of the mobo/case as well.
« Last Edit: 02-April-08, 19:51:35 by Keizer »
MSI P45 Platinum
EVGA GTX 260
X-fi Sound card
DaLoona
  • Trinergy
« Reply #9 on: 02-April-08, 20:10:40 »
Your wellcome  :hat tip:
Do the ports on the back hace still that issue, gotta check that out first, otherwise unplug cardreader, might be conlicting with something and plug in when windows is loaded.  :)
Edit:
try disabling USB legacy support in BIOS, I think that's it ( I hope  :rolleyes: )
« Last Edit: 02-April-08, 20:29:39 by DaLoona »
Keizer
  • Military Class
« Reply #10 on: 02-April-08, 20:23:48 »
Edit:
Wouldn't that mess up my USB support within the operating system? I use a USB card reader, flash stick, and external hard drive.
MSI P45 Platinum
EVGA GTX 260
X-fi Sound card
DaLoona
  • Trinergy
« Reply #11 on: 02-April-08, 20:25:39 »
Yep was reading about it right now, stupid me  :bonk:
If the problem persists I think it's your cardreader then or front ports misconnected since your backports work  :undecided:
« Last Edit: 02-April-08, 20:30:30 by DaLoona »
Keizer
  • Military Class
« Reply #12 on: 03-April-08, 03:43:48 »
If I plug in my card reader, and then go directly into the bios, and set the card reader to boot last, the settings will stick, as long as I keep the card reader plugged in. As soon as I disconnect it, and plug it back in, the card reader goes to the top of the list in the boot order. Once again I have to go in the bios and change the boot order. Same holds true with my USB thumb drive. The bios update did not change this behavior.
MSI P45 Platinum
EVGA GTX 260
X-fi Sound card
DaLoona
  • Trinergy
« Reply #13 on: 03-April-08, 11:58:40 »
Are both your usb controllers on in bios, USB and USB2.0?
Especially USB 2.0 cause that one isnt in manual, but it is there in the BIOS  :think:
You can also try to set standby to [S3], if you don't have that already and enable resume from [S3] by USB ans see if that changes anything.
If you've already setup like that, disable wake up from [S3] by USB.
I dont know if it helps, but it won't hurt your pc, but those are the only usb options left in the bios  :undecided:
Keep us up to date  :hat tip: and succes :biggthumbsup:
Edit:
Do you see when your windows is loaded a red x or yellow questionmark in devicemanager, cause then you have something that's not working right or a conflict on an IRQ adress or so.
Be sure IOPAC is enabled too in BIOS.
« Last Edit: 03-April-08, 12:30:06 by DaLoona »
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
« Reply #14 on: 03-April-08, 16:02:18 »
Just adjust your boot priority properly.
Connect all kind of devices which you got then adjust HDD boot priority too by your choice.
Keizer
  • Military Class
« Reply #15 on: 04-April-08, 01:02:08 »
I see nothing about USB 2 in the bios. There is an option to enable or disable the USB controller, as well as legacy support.
MSI P45 Platinum
EVGA GTX 260
X-fi Sound card
Keizer
  • Military Class
« Reply #16 on: 04-April-08, 17:36:59 »
By the way, this worked perfect. I just assumed that the bios would put any new plugged in items at the end of the boot order. That's how my other PC works. So, I just plugged in my card reader, and thumb drive, and then set them at the end of the boot order. The boot order stays that way even if I disconnect the reader, and plug it in later.
Thanks!
MSI P45 Platinum
EVGA GTX 260
X-fi Sound card
  • Administrator
« Reply #17 on: 04-April-08, 17:43:10 »
you are done well :)
DaLoona
  • Trinergy
« Reply #18 on: 05-April-08, 13:14:06 »
Already had said it but apparently wouldnt listen   X-((
samperkins
  • Neo
« Reply #19 on: 25-May-08, 06:46:23 »
Hello.
I have an MSI P6N Platinum with BIOS version 1.5 (Current as of the time/date of this post).  The rest of the system specs are below.
My problem is that every time I insert some kind of drive, either SD card, external Hard Drive, new CD-ROM drive, internal Hard Drive, or anything else, the boot order resets to start from the new device. This wouldn't be a problem, except that if the BIOS detects an empty CD, or a hard drive without a boot partition, the system will hang, and have to be restarted, the boot order re-changed manually to have my RAID-0 Striped array be the 1st boot device, to get back into Windows.
Any ideas on how to keep the boot order from changing every time I add a new drive?
Thanks.
System:
Windows Vista Home Basic x64 SP-1
MSI P6N Platinum BIOS version 1.5 (From CPUID)
Intel Core 2 Quad Q6600 G0 Stepping - OC'ed to 2700Mhz
OCZ Gold PC2-6400 4x1GB Dual Channel - OC'ed to 2x428MHz
EVGA 8800GT 512MB
WD 74GB Raptor x 2 - RAID-0 <Main Boot Drive
Patriot 8GB Flash Drive <Readyboost Drive
Samsung Spinpoint 750GB Drive
WD 250GB UATA x 2
Lite-On 20x DVD-DL 204
Scythe Floppy/Flash Reader
Cooler Master 690c <All fans used
Cooler Master Realpower 650W
Intel Q6600 G0 @ 2700MHz
8GB OCZ Gold @2.1v, 799MHz (4x2GB)
EVGA 8800GT 512MB 512-P3-N801-AR
WD Raptor 74GB x2 (NVIDIA RAID 0)
MSI P6N Platinum w/NB fan on
Scythe 3.5"/Flash Card reader (SDHC)
CoolerMaster 690
CoolerMaster RealPower 650W
CoolerMaster GeminII w/2x120mm Rosewill fans
5x140mm medium Yate Loon fans
2x120mm CoolerMaster fans
1x80mmx15mm fan
Sunbeam 5.25" 5-Fan Controller
Logitech G9 Mouse
Logitech OfficePro Keyboard
Logitech x51 Speakers
Epson R280 Printer
Canon LiDE90 Scanner
Jack
  • Ex Forum moderator
  • Power Edition
« Reply #20 on: 26-May-08, 11:49:32 »
samperkins, when I replied to your first post of the topic you opened, I pointed you to a specific part of this thread that already contains suggestions that might help you solve your problem.  I did not want you to repeat here what you already said elsewhere.
Have you read this thread and tried the suggestion that helped Keizer? If not read it again and test!
http://forum-en.msi.com/index.php?topic=115930.msg872213#msg872213
http://forum-en.msi.com/index.php?topic=115930.msg872482#msg872482
Thanks!
samperkins
  • Neo
« Reply #21 on: 30-May-08, 05:31:25 »
Thanks. I actually read that part, but it did not help, as I am constantly putting flash cards from cameras/mp3 players into my computer. I was hoping there was some setting to actually prevent the boot order from automatically switching (as it makes less computer-literate members of my household pretty much unable to use the computer any time I accidentally forget to leave the card, or another flash drive in the computer, the computer essentially won't boot).
Judging by this thread, and your response, there is apparently no solution at this time.
Again, thanks for the response.
CoolerMaster 690
1x80mmx15mm fan
Logitech G9 Mouse
Epson R280 Printer
Reichner
  • Neo
« Reply #22 on: 03-August-08, 22:07:07 »
I have a similar problem.  My bios boot device priority does not change (CD ROM, hard drive, floppy, etc), but under the hard drive sub-menu in bios the priority order keeps changing.  This list contains my primary hard drive with the boot sector and operating system, a secondary storage HD an external USB hard drive. I first noticed a problem when I restarted the computer and it wouldn't boot stating that "NTLDR is missing" - I assumed the primary drive was going bad but then I realized that bios was trying to boot the secondary storage HD because it was placed at the top of the list and not moving down the list if the drive was not recognized as bootable.  Sometimes the External USB hard drive is moved to the top of the list.   Usually my primary boot HD is moved to the bottom of the list.  Every time I rearrange the list and reboot - the order changes again.   If I disconnect the USB drive and the secondary drive everything works fine - the primary drive boots up first.
Do you have any updates for your problem?
« Last Edit: 03-August-08, 22:11:16 by Reichner »
  • Administrator
« Reply #23 on: 04-August-08, 09:09:27 »
@Reichner
Read >>Posting Guide<< then open new own topic if you have some issue.
