Author Topic: US70SE corrupting my downloaded files..  (Read 5417 times)
mcculloch
  • Neo
« on: 08-June-08, 18:48:41 »
Hi All,
just wondering if anyone has had a problem like this before.
I have just purchased a US70SE 801.11n wireless USB adaptor for my home computer.  I have used the software from the box that it came in and had many problems trying to activate the network.  HOwever after finding the software for US60SE , this works perfectly and connects fine.  I am using Vista 32bit and my router (which works fine through wireless for my laptop)
Basically I have found that any files that I download with the wireless adaptor US70SE , it corrupts and Vista cannot use it.. It gives me an error saying that it isnt a Win32 application , or the 'program'.exe stopped working... When i disable wireless and connect the PC directly to the router with a cable , it works fine with the same file and I can use the exe file..
There seems to be some setting on the US70SE that is corrupting everything , maybe even encrypting..??
Hope someone can help as I need to use this computer for work...
Ben
Ex Forum User 3
  • Hawk
Re: US70SE corrupting my downloaded files..
« Reply #1 on: 09-June-08, 12:21:51 »
I can't find any info on the MSI website.
Where does it come from?
Jack
  • Ex Forum moderator
  • Power Edition
« Reply #2 on: 09-June-08, 12:41:46 »
Look like the US70SE is not sold in all parts of the world.  It appears on the German MSI-Website:
http://msi-technology.de/index.php?func=proddesc&prod_no=10005&maincat_no=131&cat2_no=&cat3_no=
Ex Forum User 3
  • Hawk
« Reply #3 on: 09-June-08, 15:10:47 »
Sorry, no idea, can't even find anything at MSI Europe.
Look at the drivers on the disc, normaly the .inf file would tell you a lot more what chip is used.
mcculloch
  • Neo
« Reply #4 on: 09-June-08, 16:15:29 »
Hi Guys ,
Thanks for your help, seems like I got a little eager to get some new technology. I will try ringing them instead.  The internet works fine through it .. i have found that it has alot of CRC errors on the receiving packets counter..
Weird.  I might take it back and just go for a plain USB 801.11g adaptor..  n adaptors might be alittle new for now.
thanks again,
Ben
