Author Topic: How to install Windows without a CD drive  (Read 94029 times)
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
« on: 04-October-08, 21:16:36 »
Windows XP / 2000
Use the WinSetupfromUSB tool found here:
http://forum-en.msi.com/index.php?topic=125750.0
Note: You'll need a USB flash drive, preferably a 1gb (or higher) which will leave you room to copy drivers and additional programs too, and you'll still need an original Windows XP CD to copy the files from. And of course you need a valid product key for it to be legal! :hat tip:
Windows Vista / 7
You need basically:
  • a USB flash drive at least 4GB in size
  • a Windows Vista DVD
To sum up:
  • Format your USB drive, with the NTFS filesystem
  • Open Command Prompt as an administrator, and run the Bootsect.exe program off the Windows Vista DVD to make the USB drive bootable
  • Copy the contents of the Windows Vista DVD to the USB drive
  • Restart your PC, press F11 (or whichever key it is) to access the Boot menu, and select your USB drive to boot from
Full guide here:
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
« Last Edit: 06-June-09, 16:59:33 by Stu »
asmar10
  • Platinum
Re: How to install Windows XP without a CD drive
« Reply #1 on: 08-October-08, 22:37:59 »
Installing windows from a USB Drive.  Interesting.
Current Build:
MSI Eclipse SLI
Core i7 950 with Thermalright Ultra-120 Extreme CPU Cooler and Scythe S-Flex 120mm Ultra QuietFan
Corsair 6GB XMS3 Dominator
HIS ATI 4870 with Thermalright HR-03-GT VGA Cooler
PC Power & Cooling Silencer 750 (+3.3v=24A, +5v=30A, +12v=60A, -12v=0.8A, -5v=3A)
Primary drive: OCZ VERTEX LE 100GB SSD
Secondary drive: 300GB Velociraptor
Lian-Li PC-B25B
Old Machine:
MSI K9N Neo V3
AMD Athlon 64 X2 6000+ 3.1GHz (Recently upgraded from 4600)
OCZ 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400
Enermax 3 in 1 - 24P VER 1.2 ( 3.3v-36A 5V-36A 12V-36A)
Samsung 500GB SATAII
MSI 8800GT 512MB GDDR3 Graphics Card
Creative CD-RW and Sony DVD-RW
Windows XPSP3
Zorro ATX Case
Ex Forum User 3
  • Hawk
« Reply #2 on: 09-October-08, 13:05:14 »
Well you have to if you use a Wind, as they have no cdrom or floppy.
asamkipas
  • Platinum
    • My blog !!!
« Reply #3 on: 05-January-09, 04:24:07 »
Well another option is that to take out the 2.5 inch HD and reformat the HD using an ide/sata converter to USB. After that..put the HD in any laptops/notebooks with an optical drive and install any OS you want. Using Stu's suggestion is good for netbooks with onboard SSD storage drives.
 :hat tip:
# Intel Pentium Dual Core E5200 @ 2.50Ghz
# MSI P45-Neo2 Fr
# Deepcool Killer Whale Downdraft Cooler
# Corsair Dominator DDR2 PC10000 1200 MHz @ 2.1 v
# PALIT 9600GT 256bit 512MB DDR3
# Seagate 250GB SATA-II
# Windows Vista Ultimate SP1
# Corsair TX650W PSU +12 ~52A
# Cooler Master Casing - Elite Series
 ~ =( Sold my P45 zilent =( ~
---> My humble blog <---
http://zawari-e7200.blogspot.com/
ExTaCy1337
  • Cyclone
  • Trying to stay alive!
    • Ecstasy Website
« Reply #4 on: 05-June-09, 19:13:11 »
I used this
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=MTX-UNITY-I23839&jumpid=reg_R1002_USEN
HP Driver Key Bot Utility
I installed it all ok made my usb bootable
then added all windows files
but I boot it and I get on a screen with commands
what commands should I use for set?:S
Its a DOS
and I think it said something about linux in there, any help on how to install?
I want to install Windows XP Professional x64 ..
Processor: Intel Core 2 Duo E6550 / 2.33GHz
Motherboard: MSI 945GCM5-F V2 (FSB 1333)
RAM Memory:2GB Adata 667Ghz (x2)
Graphics Card: Sapphire HD4650 512MB 64BIT LITE Version
HDD: Seagate Barracuda 7200.10 500630 / 500 GB SATA II
Other:Wireless LAN 802.11g 54Mbit.
Realtek RTL8168B/8111B Ethernet.
OS: Microsoft Windows 7 Ultimate X64
PSU: Allied AL-8460BTX 450W +3.3v~22A +5v~15A +12v1~14A +12V2 16A
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #5 on: 05-June-09, 20:03:33 »
Use the tool that Bas attached to this topic here:
I've used this myself on a couple of occasions since, and it is much easier to use! :biggthumbsup:
ExTaCy1337
  • Cyclone
    • Ecstasy Website
« Reply #6 on: 06-June-09, 03:13:12 »
Thanks I made it work ;) ;) ;) finally after some years ;)
Corporal
  • Neo
Re: How to install Windows without a CD drive
« Reply #7 on: 24-October-10, 15:57:20 »
Greetings!
I have downloaded an XP edition, x86 (32bit) and have tried it on a friend of mine's MSI Wind U100. A problem occurs after the restart, when I have to start the second installation - a missing "hal.dll" file is said to be the problem. I will be eternally thankful to any one of you if you can help me solve this.
P.S> I have a bootable USB drive, 1GB , via WinSetupFromUSB application.
Regards,
Alex
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
« Reply #8 on: 24-October-10, 16:02:02 »
Greetings!
Regards,
Alex
choose the 1st option
Corporal
  • Neo
« Reply #9 on: 24-October-10, 16:05:28 »
Ok, I chose the 1st option again, but the installation starts again from the very beginning. After the first reboot of the system, when copying of the files is complete, I have to restart. And then the problem arises - what follows next ?
P.s> Sorry for the impertinence but this is my first time installing Windows to a non-CD-ROM computer.
  • Administrator
« Reply #10 on: 24-October-10, 16:08:41 »
After 1st restart, boot from HDD, then there 2 options will appear.
One will give HAL dll error, the other one will not.
When installation is done, you can manual remove the unnecessary boot choose entry
Corporal
  • Neo
« Reply #11 on: 24-October-10, 16:12:43 »
Once again I'll have to apologize, but when I change the first booting device to Hard Disk, a problem occurs - "Windows could not start because of a computer disk hardware configuration problem." I have fears that the hard disk may have been damaged to some extend ...
  • Administrator
« Reply #12 on: 24-October-10, 16:14:07 »
have you turned off the AHCI in BIOS Setup?
Corporal
  • Neo
« Reply #13 on: 24-October-10, 16:15:38 »
It is disabled, by default I suppose, because I didn't make any amendments in the BIOS section.
Should I enable it>?
  • Administrator
« Reply #14 on: 24-October-10, 16:16:43 »
Nope, go check it and keep it disabled
Corporal
  • Neo
« Reply #15 on: 24-October-10, 16:18:19 »
It IS disabled, and the problem continues.
  • Administrator
« Reply #16 on: 24-October-10, 16:20:39 »
Wipe entire HDD with HDD's manufacturer Tool,
then try again
Ex Forum User 3
  • Hawk
« Reply #17 on: 24-October-10, 21:36:36 »
Simple way to install XP without CD (AHCI must be disabled!).
1 create a bootable USB-stick with DOS on it.
2 copy the i386 directory onto your USB-stick.
3 start DOS on the USB stick and format the harddisk of the drive with format c: /s (makes it a FAT32 partition and bootable)
If not, then run fdisk first and delete all partitions on the harddisk and create a new one, then reboot and retry the previous line)
4 copy the i386 partition to the harddisk: <md c:\i386> <copy \i386 c:\i386> (between <> are the commands needed)
5 reboot the machine and let it boot the harddisk (remove USB stick!).
6 <cd i386> <winnt.exe> (I thought it was that one, there are a few exes in it)
7 after installation and drivers, goto command-prompt in XP, <convert c: /fs:ntfs> to make the drive NTFS.
Voila, you are set and installed XP without a CDrom. ;-))
harun-cuk17
  • Neo
« Reply #18 on: 12-August-11, 09:52:25 »
Hello there STU,
I have download this tool from this link:  http://forum-en.msi.com/index.php?topic=125750.0
But I could not find some guide to help me how will I format the MSI U100.
Could you send me the guide so that I could read it step by step?
Many Thanks,
Harun-cuk17
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #19 on: 12-August-11, 20:00:02 »
Formatting the disks is done in Windows setup, create your bootable USB flash drive using that tool, then boot from it, and follow the instructions that Windows Setup gives.
nestea69
  • Neo
« Reply #20 on: 12-February-13, 21:26:26 »
i have been installing from USB only for the past 4 years, and the best tool to 'prep' the drive is the Windows USB Boot utility software. Very easy to work with and it does the job EVERY time
