Author Topic: Windows 7 Realtek HD Audio Drivers  (Read 59874 times)
doooly
  • Easy OC
« on: 14-January-09, 01:03:51 »
Hi
I was wondering if anyone has got the drivers to work for Realtek HD audio, codec is ALC888 the MB i have is MSI P7N Platinum. I am using the vista 64 bit drivers that MSI providers.
Here is the message i got in the device manager.
(Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
If anyone found a solution to this i would be greatful.
Stu
  • Hawk
  • Online Online
  • Birmingham, UK
    • StuOnline.co.uk
Re: Windows 7 Realtek HD Audio Drivers
« Reply #1 on: 14-January-09, 01:36:10 »
Is your audio working? If so, don't worry about it, it is not a 'problem' ;-))
doooly
  • Easy OC
« Reply #2 on: 14-January-09, 04:03:04 »
Thanks for the reply but you don't need to be a smart ass !
asamkipas
  • Platinum
    • My blog !!!
« Reply #3 on: 14-January-09, 05:10:25 »
Chill dude ! I am using Win 7 too, yes in the installation it stated that the OS is not supported, but as long as the hardware is working and we can listen to songs,who cares ?
# Intel Pentium Dual Core E5200 @ 2.50Ghz
# MSI P45-Neo2 Fr
# Deepcool Killer Whale Downdraft Cooler
# Corsair Dominator DDR2 PC10000 1200 MHz @ 2.1 v
# PALIT 9600GT 256bit 512MB DDR3
# Seagate 250GB SATA-II
# Windows Vista Ultimate SP1
# Corsair TX650W PSU +12 ~52A
# Cooler Master Casing - Elite Series
 ~ =( Sold my P45 zilent =( ~
---> My humble blog <---
http://zawari-e7200.blogspot.com/
doooly
  • Easy OC
« Reply #4 on: 14-January-09, 05:58:43 »
Sorry if i was nasty but there is no sound, just wondering are you guys running the 64bit and are you using the realtek oboard and do you have sound ?
« Last Edit: 14-January-09, 06:02:51 by doooly »
asamkipas
  • Platinum
    • My blog !!!
« Reply #5 on: 14-January-09, 09:04:38 »
Yes, I am using the on board Realtek HD audio too, but as far as I am concerned..all sounds are working. Have you tried checking in device manager?does it detect any errors?
# MSI P45-Neo2 Fr
Stu
  • Hawk
  • Online Online
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #6 on: 14-January-09, 19:42:36 »
Well you failed to mention that fact in your first post :hat tip:
Try installing the latest Realtek HD Audio drivers for Vista 64bit from here and see if they work:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
billith
  • Neo
« Reply #7 on: 15-January-09, 00:56:31 »
I got mine to install by disableing driver signing.
Restart the computer
after the post start hitting "F8" like it's going out of style
you should get a start menu
the last options should be "disable driver signing" select it and press enter
I had to do this for most of my drivers but it worked to a point
My realtek still won't play during Bioshock game play, but windows sounds do play.  The audio control panel detects plugging in devices but won't show speakers, nor will it play the test sound ( put I can push Play  ??? )
If you find any info on this, please let me know.
Hope that helps!
imdriven
  • Neo
« Reply #8 on: 17-January-09, 00:56:21 »
Windows 7 Realtek HD Audio Driver can be found here
http://mytopfiles.com/programs/file/Vista_R213/299265.htm
OR
Search for (Vista_R213)
It works 100%
Stu
  • Hawk
  • Online Online
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #9 on: 17-January-09, 12:19:22 »
OR
It works 100%
The drivers I already linked to at Realtek's website are the latest R214 Vista drivers.
imdriven
  • Neo
« Reply #10 on: 17-January-09, 17:32:11 »
R214 vista driver will not work with ALC888 in windows 7. You need to use Vista_R213. I posted the link yesterday. Here it is again.
 :sleep:
ashrack
  • Afterburner
« Reply #11 on: 20-January-09, 23:13:03 »
imdriven
For me the R214 works great.
Corsair VX-450W * MSI K9a2 CF * Phenom II x3 720
2x2GB 800MHz Super Talent * PowerColor 5770 1GB * Windows 7 x64
1x SSD, 2 x HDD and 1 x DVD RW
drutman
  • Winki
Re: Windows 7 Realtek HD Audio Drivers Major Gaming Issue
« Reply #12 on: 08-February-09, 16:55:39 »
Dear All:
I like Win 7 but I cannot get one game to run under these drivers.  Bioshock and Call of Duty 4 crash and the error comes back sound driver issue.  I researched it extensively and tried all fixes with no success. I was going to buy a ATI X2 card but if the games do not work it is a waste of money.  I imagine realtek losing business fast if this issue is not solved ASAP.  Any comments?  I am satisfied with MSI but why use realtek as a OEM if it is difficult?  Vista users have the same issues, BTW WinXP works fine.  The future of the hardware depends on plug and play gaming.
Dan
Stu
  • Hawk
  • Online Online
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #13 on: 08-February-09, 17:19:05 »
Windows 7 is currently a :beta:. If you want a stable OS to play games on, use Windows XP.
IMHO I have no complaints about the Realtek audio, its come on most boards I've used in recent years. Certainly not as difficult as Creative :laugh:
jackal12
  • Afterburner
  • have a nice day
« Reply #14 on: 13-February-09, 14:51:14 »
this might be somthin or nothin BUT in a an erlier post i mentioned that FARCRY2 had a problem and win7  asked if i  to find a solution so ok its beta lets give it a shot and it asked me to try again so i did crash no.2 same again do you want me to find a solution YES this hapened 4 times but it DID find a solution all on its own.so has anyone else had the same success in letting windows 7 solve its own problems :hat tip:
msi p67a-gd55-b3
intel i5-2500k cpu
crucial-m4-128gb sata3 and western digital 500gb sat3
asus 560 ti 1g  graffics card
creative sb xfi-go usb card
16 gig crucial xms3 1333mhz ram
1 lg22 sata dvd and 1 samsung tssw sh-s223b
>psu 850watt
windows 8 pro 64 bit
acer p225hq hdmi monitor
jackal12
  • Afterburner
  • have a nice day
« Reply #15 on: 13-February-09, 21:16:13 »
r215 is out now over at guru3d.com theses may resolve issues for some
msi p67a-gd55-b3
intel i5-2500k cpu
>psu 850watt
banger696
  • Afterburner
  • Intel Core 2 Duo E8400
« Reply #16 on: 14-February-09, 06:58:15 »
Looking at the History for R2.15 it only shows a fix to the uninstallation for Windows 7. Not sure if other fixes are included.  :confused2:
Intel E8400 Core 2 Duo 3.0 Ghz Wolfdale
MSI P35 Neo F BIOS V1.A0
4x AENEON 1Gb DDR2
MSI Geforce 9500GT 1gb PCI-E
2x Seagate 80gb ATA100
Microsoft Windows XP Pro Edition SP3
Hiper 530W PSU 12v1 18A 12v2 18A 5v 34A 3v3 28A
Thermaltake Tsunami Case (Silver)
jackal12
  • Afterburner
  • have a nice day
« Reply #17 on: 19-February-09, 21:53:38 »
r2.16 are out on guru3d.com hope this will be of help
msi p67a-gd55-b3
intel i5-2500k cpu
>psu 850watt
atolica
  • Neo
« Reply #18 on: 27-April-09, 03:12:19 »
Hi
I think I have found a solution to this.
I recently had problems my self.
First you have to install this, from Intel: http://downloadcenter.intel.com/detail_desc.aspx?agr=N&DwnldID=7525&ProductID=1861
Second, install the latest drivers from Realtek, R2.22. I uploaded the zip file to filefront, as their ftp server is running by mouse power. http://files.filefront.com/Vista+R222zip/;13661269;/fileinfo.html
I hope it will work. for you. I had a lot of trouble finding the solution. Everything has to do with Intel's high definition codec that for some reason Realtek choose not to include in their driver packages.
Greets
Let me know how it goes!
Marco Pogo
  • Neo
« Reply #19 on: 10-July-10, 20:12:48 »
I was having similar problems, and Atolica's solution worked for me! Thank you!
