Author Topic: MS-7050 Motherboard  (Read 31289 times)
mmichielin
  • Neo
MS-7050 Motherboard
« on: 04-February-09, 23:44:26 »
I'd like to upgrade the CPU of my MS-7050 motherboard (I have a HP DX5150 minitower) but I'm unable to find any decent documentation about this motherboard (I deeply browsed MSI website). So my questions are:
- which is the "commercial" name for this motherboard?
- where can I find detailed manuals for this motherboard?
- does this motherboard support any kind of socket 939 athlon 64 dual core?
- for example, is Athlon 64 X2 4800+ ["Toledo" (E6, 90 nm)] supported?
- or, is Athlon 64 FX-60 ["Toledo" (E6, 90 nm)] supported?
Anybody can help me?
Thanks in advance
Michele
Ex Forum Mod
  • Hawk
Re: MS-7050 Motherboard
« Reply #1 on: 05-February-09, 00:29:19 »
 Sorry, can't help you since it's OEM and I don't think there is a comparable MSI retail version. Best I can say is look through the s939 MBs and see if any of them are similar to yours. You need to check with HP/Compaq help you out with your questions.
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #2 on: 05-February-09, 04:25:37 »
You'll need to contact HP as we can only offer support for MSI retail products.
#2:
MSI Wind U100
