Hi there,
I'm trying to update my P45 Platinum to version 1.6 with my USB boot drive. After I type in afud4281.exe a7512ims.160 and hit enter the command hangs. I hit Enter, it drops down to a blank line and sits there. I let it go for 10 minutes or so while I watched tv, came back and it was still at the same spot. CTRL + C does nothing, Caps lock doesn't work, but strangely num lock does. I end up having to reboot and I get into my OS just fine. I tried typing in afud4281.exe and hitting enter, but it does the same thing. I downloaded a new copy of the afud4281.exe file and a copy of the afud4234.exe from an older update and when I type in just the filenames and hit enter, they do the same thing as above. I've also tried it from a bootable DVD and the same issue occurs.
Using an E8400 @ 3.0GHz while trying to update BIOS
4GB 1066 GSkill DDR2 RAM
Any help would be greatly appreciated. I'm having trouble finding anyone with the same issue and I've been looking through this forum and Google for a good couple of hours.
Thanks
