BIOS is 1.3 or higher?
Have you checked the manual for dual-channel config?
Is Ganged-mode set correctly? Try the other mode.
Bios is update to v1.8 - it's ok
I've checked the manual for dual channel config. it's OK.
I try ganged mode and unganged mode... but the system not run...
Only in single channel the computer runs...
It is a very strange problem ...
there is some inconsistency for this micro processor?
I also had the same problem with K9N2 SLI Platinum ....
I think the problems is the micro....
C -you!
