Go Search!!
Home
MSI HQ User to User Forum
09 February 10, 20:46:39 *
News: Do NOT use M-FLash for BIOS flashing! It kills boards!
>>USE THE FORUM FLASHER INSTEAD!! It's 100% safe!! Click me to get there!!<<
  Print
Author Topic: MicroStar 945GCM478-L starts at midnight.  (Read 1114 times)
Bas
Chief nut :-)
Administrator
Offline Offline
If it doesn't fit, use a hammer!!!
WWW
« on: 19 May 09, 15:54:19 »
Hi there,
MSI gave me a BIOS to fix this problem.
If your board starts at midnight, please use this BIOS to solve the matter.
>>Use the MSI HQ Forum USB flasher<<
Bas.
MediaLive
AMD X2 4200 - 2.2GHz - CPU Cooler blowing upwards!
2x 1GB DDR800 El-cheapo
Samsung 160GB Sata-2
Technotrend Skystar 2 DVB-S
Ubuntu 9.10 / Debian (forum-server) / OpenSolaris / MCE2005 (MCE is unable to do proper DVB-S!)
With AMD CPUs use AMD tested MEMORY! Intel tested often fails!!!
Powersupply rule of the dumb: 12V Amps < 3.3V or 5V Amps -----> Unfit for modern systems, REPLACE!!
Please call me a nerd, it's not name-calling, it's an EGO BOOST!! lol_anim
Vales
Newbie
Offline Offline
« Reply #1 on: 28 May 09, 19:11:39 »
You must be very lucky that MSI gave you attention and gave you support on your problem, I have same board here 2 days now and this board and all my attempts to install win xp hope was zero, so much fault errors, I sent them message at MSI Support Online but nothing happened
w
Junior Member
Offline Offline
« Reply #2 on: 26 June 09, 06:46:36 »
I'm thinking of going for this board, but is it still waking up at every midnight?  I think this is not good for our green planet.
w
Junior Member
Offline Offline
« Reply #3 on: 28 June 09, 07:07:31 »
Bas, going by the enthusiastic responses, there are a number of links to beta bios, I presume yours is the latest one?
j9toby
Newbie
Offline Offline
« Reply #4 on: 16 October 09, 14:22:11 »
I've had the same problem...... keeps falling over on the xp install, whether on a SATA hdd or old ATA hdd on the IDE lead.
SURFa
Newbie
Offline Offline
« Reply #5 on: 05 December 09, 03:18:58 »
Actually a 've seen 2 issues Started Linux Install and it hang up on USB controller detection, so I turned USB off and got it allright idea
Yesterday I saw some kind of bug After Installing Win2kPro and a SATA 1,5 PCI controller the system just turns off whhen I stop do something. I checked this issue two times So both times my MOBO just  :shocked_anim:goes to standby after USB keyboard/mouse So it seems like an USB bug// Today will  try to flash it after some PCMArk Score Measurements  bonk
  Print
Jump to:
Page created in 0.12 seconds with 18 queries.
