Go Search!!
Home
MSI HQ User to User Forum
09 February 10, 19:24:41 *
News: How do you flash your BIOS, please take part in our poll, thank you! >>How do you flash?<<
  Print
Author Topic: Memory issue.  (Read 170 times)
lexie_1
Junior Member
Offline Offline
« on: 25 June 09, 12:09:56 »
Hi all,
First: below are my specs.
I'm having trouble running my memory at 1066 Mhz.
The memory i use CAN run at 1066 Mhz. But i need to know how to set it up.
When i run it at 800Mhz no problems..... when i run at 1066 Mhz i get memory errors using a memory test program.
Can anyone tell me the correct settings for the bios?
And also how can i adjust the voltage settings in the bios? (they are grey and not accesable)
Alex
AMD Phenom II X4 940 Black 3.0GHz HT 8MB AM2 Box
Corsair 2x2GB DDR2 SDRAM PC8500 CL5.0 DHX Dom.
Logitech MX400 Laser Mouse
Microsoft Comfort Curve Keyboard 2000 Retail (zwart)
nVidia GeForce 8800 GTS 320MB
MSI DKA790GX Platinum
Sweex Card Reader CR005V2
Corsair Powersupply CMPSU-650TXEU 650W
Trust  Ultra Small Bluetooth 2.1, 25m
Cooler master Centurion 5
Hans
Official Q-Tec Alert Specialist // 正式Q技术机敏的专家
Online Online
Hello.... Is it me you're looking for?
« Reply #1 on: 25 June 09, 12:28:52 »
Read!
http://forum-en.msi.com/index.php?topic=123860.0
You have a Q-Tec Power Supply? Change that first and come back later...
* MSI 790FX-GD70, bios 1.4
* AMD Phenom II X4 965 (stock)
* 2x 1024MB Crucial Ballistix @ 1600MHz (7-7-7-24, 2T)
* MSI RX4850 512MB
* Western Digital Raptor 74GB (OS and apps)
* Western Digital Caviar Green 1TB (storage)
* 2x DVD Rewriter (NEC, Optiarc)
* PC Power & Cooling Silencer 750W
* Cooler Master Stacker CM101
* Dell Ultrasharp 2209AW 22" (e-IPS) monitor
* Windows Vista Ultimate SP1 NL (no problems)
MSI MediaLive: AMD Athlon X2 4800+, 2x1GB Crucial PC-4200, Seagate 160GB, Pioneer DVD-burner, Hauppauge PWR150 TV Tunercard, Windows Vista Home Premium NL, SP1.
Backup: Thecus N5200Pro NAS with 5x WD Caviar Green in RAID 5
lexie_1
Junior Member
Offline Offline
« Reply #2 on: 26 June 09, 12:15:59 »
Thanks for the support.
But can anyone tell me if there is a bios guide?
I still cannot find any way to change the voltage settings in my bios.
Hans
Online Online
« Reply #3 on: 26 June 09, 13:54:28 »
Again, read.... this info is all over the place.
use page-up/down or keypad +/-.
* MSI RX4850 512MB
Mike
aka Frankenputer 備份管理員 Backup Dude
Administrator
Offline Offline
Virginia, USA
« Reply #4 on: 26 June 09, 15:50:53 »
It's even at the bottom of the bios screens.
MSI X38 Diamond/Bios 1.5; Core2Duo E8400 3.0Ghz; Thermalright Ultima-90HS/120 fan; 2X1GB DDR3 CorsairTWIN3X2048-1333C9DHXG; PIONEER|DVR-215DBK SATA DVD-DL & Lite-on DVD-ROM PATA; FDD; MSI 260GTX-T2D896; 190.62; Seagate 320GB  & WD 500GB SATA HDDs; PC P&C Silencer 750 +3.3V/24A~+5V/30A~+12V/60A; X-FI Xtreme PCIe; Antec P182 Case; XP PRO SP3
#2:
MSI Wind U100
  Print
Jump to:
Page created in 0.11 seconds with 18 queries.
