Author Topic: Wind U123 built-in microphone problem  (Read 8005 times)
slimjim
  • Neo
« on: 11-August-09, 23:56:15 »
New owner of a MSI Wind U123 and quite happy about it. However, there is one (unfortunately major) problem:
The built-in microphone does not work well.
I thought it is faulty in my machine at first, but then when I crank up the microphone volume to max., I can barely hear my own voice (eg. using Windows sound recorder). Skype and chat is impossible without a plug-in microphone (which works fine).
I searched through reviews and notice several reviewers also reported that the sound volume of the built-in microphone is very low. The volume and sound quality of the speakers is also rather weak, but at least it is easily audible.
I looked through the MSI and Realtek websites for driver update. Apparently they are the same as the one preloaded and on the installation disk, but I downloaded and installed it anyway. There is no improvement.
Is there anything I can do or is it just crappy hardware?
Thank you.
Warner
  • MSI Tech-support
  • Online Online
  • City of Industry, CA
    • MSI
Re: Wind U123 built-in microphone problem
« Reply #1 on: 12-August-09, 01:08:10 »
Try enable Mic Boost.
1. Control Panel -> Sound and Audio Devices Properties -> Advanced, this will bring up the Volume Control.
2. Go to Options -> Properties, change Mixer Device from Realtek HD Audio Output to Realtek HD Audio Input, and then click on OK to close.
3. Go to Options -> Advanced. Once Advanced is checked, then click on Advanced Button below the Mic slider control. Check the Mic Boost box.
4. Make sure Mic volume is also all the way up.
It should look similar like the image below.
FAE, MSI USA
Welcome to MSI user-to-user support forum! For official support, please contact us directly.
MSI USA service & support contact info:
Email: ususersupport@msi.com
Phone#:
+1.626.271.1004 (MB/VGA)
+1.888.447.6564 (Notebook/AIO)
Online Tech Support:
http://service.msicomputer.com/msi_user/ts_form.aspx
RMA request (USA/Canada only):
http://service.msicomputer.com/msi_user/rma_form_new.aspx
FAQ:
http://service.msicomputer.com/msi_user/techfaq.aspx
slimjim
  • Neo
« Reply #2 on: 12-August-09, 05:12:22 »
I got Control panel -> Sounds and audio devices -> Advanced -> Options -> Properties -> change output to input
When I click back on Options - the "Advanced controls" selection is not active
I also go back to the Realtek audio control panel and look for similar function - there is none
No luck!
Warner
  • MSI Tech-support
  • Online Online
    • MSI
« Reply #3 on: 12-August-09, 06:28:09 »
Uninstall Realtek driver, make sure to reboot the system after the uninstall.
Then download this driver below,
ftp://WebUser:DAx7h9V@66.104.77.130/pc/audio/WDM_R230.exe
Install, then reboot again.
Check those settings again.
No luck!
FAE, MSI USA
Phone#:
FAQ:
slimjim
  • Neo
« Reply #4 on: 12-August-09, 15:59:17 »
Done that before I posted here - WDM_R320 is the driver I got from Realtek website. Tried that already.
Warner
  • MSI Tech-support
  • Online Online
    • MSI
« Reply #5 on: 12-August-09, 19:35:41 »
My bad, there is no such option for the Realtek IC.
Try to reduce the distance between the internal mic and your sound source short.
But the best way is to use an external mic, thanks.
FAE, MSI USA
Phone#:
FAQ:
slimjim
  • Neo
« Reply #6 on: 14-August-09, 08:15:28 »
= crappy hardware!
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #7 on: 14-August-09, 08:42:16 »
#2:
MSI Wind U100
slimjim
  • Neo
« Reply #8 on: 22-August-09, 09:04:06 »
!!  MY BAD  !!
I found the microphone boost function!
Double-click Realtek audio systray icon to show audio manager -> Mixer -> "Playback" click right arrow button to show "Mic Volume"
Click the tiny ".." button beside the "mute / unmute" button -> enable "microphone boost"
I never thought this is hidden under "Playback" function!
Now the built-in microphone picks up much better, TY
Ex Forum User 3
  • Hawk
« Reply #9 on: 22-August-09, 12:34:36 »
Yep, fooled me several times too, as it's a really stupid place to hide the mic-boost. :lol_anim:
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #10 on: 22-August-09, 16:13:34 »
Yeah, the interface design is not the most intuitive for finding the mic boost.
#2:
MSI Wind U100
klemlyn
  • Neo
« Reply #11 on: 08-January-10, 19:08:43 »
thanks for this info Slimjim. What skill finding the mcirophone boost. Now I too have it working. Problem is the speakers have boosted at the same time and I have to turn them way down and still get a lot of echoing and poorer quality than before. Any thoughts?? Klemlyn
Ex Forum User 3
  • Hawk
« Reply #12 on: 08-January-10, 20:12:19 »
The speakers are not boosted at the same time.
The MIC boost only applies to the microphone INPUT nothing else.
