Go Search!!
Home
MSI HQ User to User Forum
09 February 10, 19:14:44 *
News: Do NOT use M-FLash for BIOS flashing! It kills boards!
>>USE THE FORUM FLASHER INSTEAD!! It's 100% safe!! Click me to get there!!<<
  Print
Author Topic: Eclipse SLI sound card - unable to record  (Read 397 times)
ypsylon
Newbie
Offline Offline
« on: 10 September 09, 15:51:20 »
OK, it is my main (yes even ignoring rubbish NB heatsink) concern regarding Eclipse SLI MB - enclosed sound card. When I put MSI/Creative audio everything working well except recording. [I switched card between PCI-Ex x1 & x4]
I can't record sound from it. crying Even basic Windows (7) sound recorder doesn't work. Whenever I try to record something I get message like (depending on software): "Unable to create device at x0030a". One thing straight - it is not exact message just to give you general idea. I installed both software from CD and from Creative. No difference. When my old PCI audio is in, I have "What U Hear" device under recording tab, but when using MSI Audio I have only Microphone and SPDIF. I understand that for most it is not a big deal, but I recording a looooot of live radio every week and it is big deal for me.
For the moment I using my old audio - SB X-fi Gamer on PCI and this one working perfectly well. But I want to create SLI system in the near future and I would like to remove PCI card to put there extra cooler to remove hot air from space between 2 VGAs.
I'm really disappointed with this MSI audio. Really, really  biggthumbsdown One of the reasons why I bought this MB was good external sound card based on PCI-Ex. I bet most of users is sick and tired of built-in AC'97 garbage. You just wonder why MB manufacturers put such rubbish on high-end MoBos? 99% of users disabling them right away from the start.
I can't guarantee to put all suggestions into use straight away. I don't have much time to toy with hardware during the week.
Basic specs: i7 920 (no OC), Eclipse SLI, 3*2GB 1333 Kingston (no OC), EVGA 8800 GTS640 (no OC), Win7 64-b.
NovJoe
Offline Offline
~DeSTinY~ Destined 2 Be HeRe ^^
« Reply #1 on: 10 September 09, 15:59:34 »
Have you tried the driver from MSI website yet?
HTPC - DVI to HDMI for Panasonic 42" Plasma
512MB x 2 Kingston 333MHz, 250GB Seagate
MSI Wind with Love U100 Netbook
Intel Atom 1.6GHz, 2GB RAMs, 80GB HDD, 6 cells battery, WinXP SP3
HP Compaq V3136 Laptop - VGA to Sharp 32" LCD
Intel C2D 1.66GHz, 2GB RAMs, 80GB HDD, 3 cells battery, WinXP Media Centre SP3
Speakers:
Gigaworks S750, 7.1 Theater Surrond
Altec Lansing XA3501, 5.1 Gaming
MSI HQ Forum USB flasher
Jack t.N.
MSIHQ Red Rockets Team Member
Offline Offline
汉语?
« Reply #2 on: 10 September 09, 16:02:45 »
Okay, first of all, this is a Creative Audio card, that has all the features (and limitations) of the OEM Version of the X-Fi Extreme Audio.
Secondly, please have a look here:
http://en.wikipedia.org/wiki/Sound_Blaster_X-Fi#X-Fi_Xtreme_Audio
On top of the Xtreme Audio's rear sound problem in games, the PCI Express version of the X-Fi Xtreme Audio suffers from the inability to record from a Microphone while simultaneously recording "What U Hear", which is possible in all other cards. The reason for this is unknown, but the issue is that the Windows audio Playback Control panel doesn't allow you to view the Mic channel when looking at your Playback Control sliders (activated by double-clicking the Windows Volume Control button). In the Windows audio Playback Control panel, the Mic can only be viewed in Recording Control, and there is no Mute/Unmute checkbox associated with it. The Creative Mixer shares the problem in a different way: you can unmute the Mic, but it becomes muted again once you switch to "What U Hear" as your recording source. Thus, on the PCI Express version of the Xtreme Audio (only) it is impossible to record your Mic and "What U Hear" at the same time, because you cannot get the Mic to output to the speakers while "What U Hear" is enabled.
... can you make the "What you hear" thing visible in Windows 7 when you do something similar to this?
http://www.driverheaven.net/audio-general-technical-discussion/130879-windows-vista-recoding-what-you-hear-how.html
Current System:
E6600 @3.6 GHz, EIST enabl./C1E=enabl., VCore=1.33V -- P45 Platinum, BIOS v1.7b4 -- 2Gb Kingston HyperX KHX8500D2K2/2G @1067 MHz, 2V, 5-5-5-18 -- MSI N295GTX-M2D1792 -- Corsair VX-550W, 41A@12V
ypsylon
Newbie
Offline Offline
« Reply #3 on: 10 September 09, 18:22:29 »
Okay, first of all, this is a Creative Audio card.
I know, and please don't take it as a attack on MSI. I was simply stating the fact, that this card is sold under MSI brand which is not like Creative which ignoring requests from users to fix bugs in theirs soft/hardware. I still have my old MSI 7800 AGP VGA which working beautifully after all these years in my small PC. Good stuff biggthumbsup
Hmm... I read that Wiki article and it explained quite a lot, but honestly when buying this I did not expected that there was such article! It only proves my point from above that - yet again - Creative released half-finished hardware and for 3 years refused to do anything about it.
Unfortunately answer to your question is negative. I don't have "WUH" under Recording tab. I have Show Disabled/Disconnected Devices turned on, so I see everything what system installed. I Disabled Microphone (I never used Mic as long as I have PC), still no "WUH". But thanks guys for the input. Now at least I know 'I don't see things' because it is "normal" behaviour for this sound card. When I have some more time on my hands I will try to crack this thing. For now I will stick to my old and trusted PCI X-Fi Gamer. Too much hassle with this X-Fi Extreme Audio. Looks like "they" (IT boofins) predicted death of good old PCI architecture far to soon. Long live PCI!  happy
HU16E
Emperor
Offline Offline
Air Cooled @ 4.85
« Reply #4 on: 10 September 09, 23:32:58 »
Just for testing purposes, I installed the OEM Creative X-Fi card supplied with the E. Plus. It should be the same as yours. I tried every conceavable way to enable WUH feature, & it is 'not' even offered as an option with the OEM card. Maybe, & it's a big maybe, Creative will supply MSI with a driver or software to enable such features.
Long live PCI!
Agree! I won't buy a board without at least one PCI slot. The Creative X-Fi Elite Pro is just too good a card to be without.
MSI X58 Eclipse Plus-GTX 295-X-Fi Elite Pro-Thermaltake XT 850W +3.3V 30A +5V 30A +12V 62A-Lian Li PC-7BPlusII W-i7 975 @ 4.85-Zalman 9900-Corsair TR3X6G2000C8GT-3X WD 300G VRaptor's-LG GGW-H20L-Lite-On iHAS424-Samsung T220-W7 64
Forum Record Holder Intel #1 OC @ 4.854.78 (Conventional Air Cooling)
If Your Not The Lead Mule...The View Is All The Same
Mike
aka Frankenputer 備份管理員 Backup Dude
Administrator
Offline Offline
Virginia, USA
« Reply #5 on: 10 September 09, 23:36:53 »
Hmm, my XFi OEM card comes with the ability to choose what u hear.  Of course, I have an older version of the card.
MSI X38 Diamond/Bios 1.5; Core2Duo E8400 3.0Ghz; Thermalright Ultima-90HS/120 fan; 2X1GB DDR3 CorsairTWIN3X2048-1333C9DHXG; PIONEER|DVR-215DBK SATA DVD-DL & Lite-on DVD-ROM PATA; FDD; MSI 260GTX-T2D896; 190.62; Seagate 320GB  & WD 500GB SATA HDDs; PC P&C Silencer 750 +3.3V/24A~+5V/30A~+12V/60A; X-FI Xtreme PCIe; Antec P182 Case; XP PRO SP3
#2:
MSI Wind U100
HU16E
Emperor
Offline Offline
Air Cooled @ 4.85
« Reply #6 on: 10 September 09, 23:46:15 »
My OEM is a CA0110 Audio Chip. Same?
Added: The supplied Console Panel is 'no way' even close to the one you are showing. It has Mic & Mic FP 'only'. My Pro Console Panel however, has all the stuff yours is showing plus some.
« Last Edit: 11 September 09, 00:15:19 by HU16E » Logged
Jack t.N.
Offline Offline
汉语?
« Reply #7 on: 11 September 09, 12:34:19 »
Ah, I never tried that.  And this actually works on my MS-4132 as well.  ypsylon, did you try that as well?
Current System:
ypsylon
Newbie
Offline Offline
« Reply #8 on: 11 September 09, 15:51:09 »
I never tried this, because I installed only drivers. I'm not interested in installing software which I never ever even try. I'm allergic to Creative soft since SB Live. In the future I will try to install whole bundle, but it is not normal. To install xxx MB of software only to activate (probably) some minor function which should have been active from the start in the first place.
Anyway, I remember I read article on one of many IT sites. Can't recall the location now, but conclusion was simple. Microsoft greatly reduced ability to record sound via WUH-kind of device under Vista (and also W7 because same drivers are in use). RIAA "influenced" M$ and most of sound card manufacturers to remove WUH/Stereo Mix part from drivers. With many sound cards WUH is impossible to run - to reduce piracy. bonk It could be even worst in the near future with next gen sound cards.
Jack t.N.
Offline Offline
汉语?
« Reply #9 on: 11 September 09, 15:54:30 »
Well, as the software (which is actually part of the driver package) will obviously solve your problem, the cause of the problem is now no longer the driver or the card, but your decision not to install the software provided by the manufacturer to be able to access all its functions.  Smiley Grin
[Problem is not "unable to record" but "how to record without the supplied software"...]
Current System:
HU16E
Emperor
Offline Offline
Air Cooled @ 4.85
« Reply #10 on: 12 September 09, 01:16:12 »
It's not part of the driver package that came with the E. Plus's that I bought, retail version or the 'refurb'.  Creative restored this feature with some retail units with their latest driver, but not for the OEM. This can be confirmed at their website support page.
ypsylon
Newbie
Offline Offline
« Reply #11 on: 12 September 09, 08:45:51 »
Look, Jack. X-Fi Gamer PCI working perfectly well with only standard drivers and I won't be pushed to install tons of garbage because X-Fi Extreme Audio is another half-finished product on the market (and there is no guarantee that installing everything will solve the problem). Why I don't need manufacturer software with X-Fi Gamer? Why MSI/Creative give me choice to download/install drivers alone when it comes to X-Fi Ex Audio? Why installed drivers supporting everything except recording via WUH? You've got part of the answer in my previous post. It is RIAA doing. Just type 'RIAA What U Hear recording' and enjoy reading. There are people which can't activate WUH with my X-Fi Gamer for example. Also Dell removed WUH/Stereo Mix from every sound driver on theirs laptops.
Sorry but your reasoning is deeply flawed. It is a bit like saying that you should install Unix/Linux just in case Windows stop responding. And then for 5 years never actually running it even if Windows was reinstalled 10 times in the meantime. BTW: X-Fi Ex Audio recording working perfectly well under Linux with standard drivers in my distribution, unfortunately system is not designed for multimedia (low performance), but I tried this.
Have fun everybody. Smiley
NovJoe
Offline Offline
« Reply #12 on: 12 September 09, 10:07:45 »
ypsylon,
I hope that you understand that Jack, Mike, Hu16E are all trying to help you with the problem.  smile
To sum it all up, it still boils down to software and drivers of creative which has to be installed for your needs. If one choose not to install, we can't force the person's will. The end results will be a probable running issue on certain functions.
An analogy likewise will be a man bought a theater system with a subwoofer provided, but does not want to install the subwoofer as it took out another floorspace, and in the end complains about the bass quality produced from the theater system during movies.  Hat-tip
Maybe, you should try out installing everything provided for once and see how it goes. It may or may not work.  Wink
Speakers:
HU16E
Emperor
Offline Offline
Air Cooled @ 4.85
« Reply #13 on: 12 September 09, 10:08:53 »
It won't solve it. Tried both cards with both sets of install discs, & neither have WUH function. Not MSI's fault. Since I don't plan on using them, no big deal. Chalk it up as our bad luck, as Mike's does work. Welcome to the world of SecuROM, DRM, Starforce, & whatever else is out there.
Added: NovJoe is right. All we really want to do is help if we can. I can't get WUH to work with either OEM, but yours might. If it doesn't, you can always do an uninstall. smile
« Last Edit: 12 September 09, 10:50:42 by HU16E » Logged
  Print
Jump to:
Page created in 0.177 seconds with 19 queries.
