Author Topic: Vista Wants To Format SD Card  (Read 4883 times)
curlin
  • Easy OC
« on: 19-September-09, 06:00:20 »
   Plugged my mobile via usb cable into my new ex630 running vista32. I want to copy over the 400 songs on the phone's 2gb micro sd card to my computer. However, vista wants to format the card  :shocked: It shows my phone in "my computer" but wants to format when i access it. Tried multiple usb ports but same result and my wireless mouse works fine. Any ideas?
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
Re: Vista Wants To Format SD Card
« Reply #1 on: 19-September-09, 06:48:10 »
Have you tried taking the SD card out of the phone and putting it in an SD card reader?
#2:
MSI Wind U100
curlin
  • Easy OC
« Reply #2 on: 19-September-09, 07:49:14 »
No, i can't seem to find the card adapter for the reader that came with it when i bought it.
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #3 on: 19-September-09, 21:56:08 »
Does it work in other computers, or do they want to format the card too?  Borrow a card reader or buy another one to test the SD card alone.  Many notebooks and netbooks come with built-in card readers, you can test the SD card there as well.  We need to test outside of the phone using a card reader to isolate the issue.  Also, in what format are these songs?  Are you sure the songs are on the SD card or the phones own internal memory?
#2:
MSI Wind U100
curlin
  • Easy OC
« Reply #4 on: 19-September-09, 22:15:50 »
Hey Mike, thanks 4 the help so far. i've hooked up my mobile the same way to alot of different computers in internet shops with never an issue. However, they all ran XP not vista. They are mp3. I've already bluetoothed over a few but it will forever to do them all lol.
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #5 on: 19-September-09, 22:49:28 »
Hmm,  I still would like to see you test the SD card alone in a USB card reader.  You could always use another computer and put the files on a flash drive or burn to a disc and move them that way(just a work-around for the moment).  Does the computer have issues with other usb devices?
#2:
MSI Wind U100
Hans
  • Official Q-Tec Alert Specialist // 正式Q技术机敏的专家
  • Xpower
  • If I fix it, it will never need fixing again!
« Reply #6 on: 20-September-09, 12:37:27 »
What mobile phone is that?
You have a Q-Tec Power Supply? Change that first and come back later...
* MSI P55-GD85, bios 1.3
* Intel Core i7 860 (stock @ 2.8GHz)
* 2x 2048MB TakeMS @ 1333MHz (8-8-8-24, 1T)
* Club3D HD5770 1024MB
* OCZ Vertex 2 120GB (OS and apps)
* 5x Western Digital Caviar Green 500GB in RaID5 (storage)
* 2x DVD Rewriter (LG, Optiarc)
* PC Power & Cooling Silencer 750W
* Cooler Master Stacker CM101
* Dell Ultrasharp 2209AW 22\\\" (e-IPS) monitor
* Windows 7 Professional NL
MSI MediaLive: AMD Athlon X2 4800+, 2x1GB Crucial PC-4200, Seagate 160GB, Pioneer DVD-burner, Hauppauge PWR150 TV Tunercard, Windows 7 Home Premium NL.
MSI X-Slim X620 :like: :like:
Backup: Thecus N5200Pro NAS
curlin
  • Easy OC
« Reply #7 on: 20-September-09, 16:41:01 »
   It is the Samsung m510
Hans
  • Xpower
« Reply #8 on: 20-September-09, 18:59:11 »
Is there some driver you need to install on Vista for this to work?
curlin
  • Easy OC
« Reply #9 on: 21-September-09, 02:21:27 »
     No luck. Downloaded all updates from microsoft and also the newest drivers from samsung. Thinking vista doesn't see the way my samsung formatted the card.
Aaron
  • HydroGen
  • BOOST!
« Reply #10 on: 21-September-09, 05:47:55 »
You should be able to connect your phone via USB and copy the files to the memory card that way.
Refrain from having to solve most of your problems by not creating them in the first place.
DDR3 Memory Standards: Blurry Lines
Integrated Memory Controllers (IMC)
Intel EIST and Processor C-states
Overclock Database 2.0
curlin
  • Easy OC
« Reply #11 on: 21-September-09, 06:21:03 »
   That's what i'm trying to do but copy the mp3's from my phone to the laptop.
Aaron
  • HydroGen
  • BOOST!
« Reply #12 on: 21-September-09, 06:48:34 »
Connect via USB and copy from the memory card to the phone then.
curlin
  • Easy OC
« Reply #13 on: 21-September-09, 16:07:17 »
Please read my initial post.
Hans
  • Xpower
« Reply #14 on: 21-September-09, 19:08:03 »
Aaron, read the first post.... he's trying to do just that.
My suggestion would be as follows: get the data of the card onto some other pc and plug your phone into the laptop. Let Vista format the card and see if it works okay now on the phone. Connect to the pc where you left the data, copy it back and then put your mp3's on the phone's card.
I think the same as you did: Vista has some problem reading the card, probably because of the way it's formatted. (Stupid Vista...  :biggthumbsdown: )
Aaron
  • HydroGen
  • BOOST!
« Reply #15 on: 21-September-09, 19:10:45 »
Ah, skim reading FTL. :biggthumbsdown:  I thought he was plugging the card in a card reader. :lol_anim:
Hans
  • Xpower
« Reply #16 on: 21-September-09, 21:32:04 »
Well, it's an idea to solve the problem, so you made a very nice contribution...  ;-)) :biggthumbsup:
curlin
  • Easy OC
« Reply #17 on: 22-September-09, 04:13:57 »
    Yes i agree that looks like the only option left. I'll let you know what happens. Thanks for the effort.
curlin
  • Easy OC
« Reply #18 on: 23-September-09, 03:14:26 »
     sorry for the double post
  So i tried the agreed upon solution but ran into another problem  :( Went to the internet shop and plugged phone into the XP computer and was able to access the sd card just fine as usual. Moving almost 2 gigs of music was going to take too long so i picked out 30 songs to copy to the xp machine and was gonna let vista format the rest. Plugged into my laptop and of course vista wants to format so i say go ahead. But now the size of the 2 gig card after formatting will only be 968 megabytes Huh  :shocked: So i canceled the format and am ready to just give up  :bonk: hahaha.
Hans
  • Xpower
« Reply #19 on: 23-September-09, 21:53:32 »
Is there more than one partition on that card? maybe a hidden partition with some phone software on it?
curlin
  • Easy OC
« Reply #20 on: 24-September-09, 00:03:24 »
    No there isn't. it showed as a 2 gig card when i first put it in the phone. I tried it in a laptop running win7 and same results as vista :shocked_anim: Works fine in XP though. I'm just going to get another sd card and see where things go from there.
curlin
  • Easy OC
« Reply #21 on: 29-September-09, 23:44:39 »
     Again - sorry about double post but have an update to share:
  I found my micro sd card adapter for the card reader in my laptop and once inserted, was able to access everything on my card  :biggthumbsup: So obviously, the problem is reading through the usb cable in vista and not the card itself. But works fine on XP.
Aaron
  • HydroGen
  • BOOST!
« Reply #22 on: 30-September-09, 13:17:10 »
Sounds like a driver issue, curlin.
curlin
  • Easy OC
« Reply #23 on: 01-October-09, 05:03:14 »
   Do you know what in device manager that i should uninstall for this issue and what new drivers i should use? Thanks!.
