Author Topic: 790FX-GD70: Unlock CPU Core missing  (Read 2815 times)
kazso
  • Easy OC
« on: 11-November-09, 16:51:01 »
I just saw the advertisement about the "unlock CPU core" on the MSI website.
I thought i would try that out, since i have a Phenom II X3 720 Black Edition processor.
The website and even the new bios description says, that the newest bios (v1.6) for my motherboard (790FX-GD70) supports CPU core unlocking.
Ok, i updated my bios from v1.5 to v1.6.
Then i entered the bios... and there is no "unlock CPU core" option in the Cell Menu :think:
Do i miss something here? Do i need to enable/disable other options to access CPU core unlocking?
Or is this feature limited to some CPU types?
I'm not overclocking my system, so the settings in the Cell Menu are on default.
MSI 790FX-GD70 / Phenom II X3 720 (Zalman CNPS-9900) / 2x2GB Kingmax DDR3-1600 / Sapphire Vapor-X HD5870 / Enermax Modu82+ 625W / Cooler Master HAF-932 / Intel 160GB SSD / Intel 80GB SSD / 4xSamsung F1 750GB 32MB Raid5
Ex Forum User 3
  • Hawk
Re: 790FX-GD70: Unlock CPU Core missing
« Reply #1 on: 11-November-09, 18:04:39 »
On the BIOS page it states this: The success of unlocking AMD CPU may still vary according to the AMD CPU use.
Could be the option is missing because your CPU hasn't got a 4th core?
I don't know, just guessing.
DaLoona
  • Trinergy
  • Certified nutcase since 1974
« Reply #2 on: 12-November-09, 14:04:20 »
Im not sure either, but there are reports outthere that say that AMD is lasercutting the extra cores on the X2/X3 range, because of the unlocking of them.
So they physically remove any connections to other cores or the core itself and thus you cant unlock it, cause they rendered it useless and/or its not there anymore.
This has to do with the fact that most of the cores that are disabled are flawed.
Dunno if thats the case with your for sure though, you might get lucky and get the extra core to run, but there is NO guarantee it will work flawlessly.
 :hat tip:
« Last Edit: 12-November-09, 17:34:42 by DaLoona »
MSI Z68A-GD55(G3)//i5 2500K @4.5GHz, stock voltage//Zalman CNPS10X Extreme
Gigabyte GV-N670OC-2GD, 1080-1241/7008/MHz//8GB G.Skill @1866MHz 10-11-10-30-1T, 1.5V
Corsair Force3 120GB SSD, OS//1*WD1TB SATAIII HDD, storage//Samsung dvd burner
Seasonic M12II 750W +12V 62A//Silverstone RV02-BW v1.8 + USB 3.0 module
HP x23LED @1920x1080//Windows 7 x64
http://www.techpowerup.com/gpuz/b52u5/
http://valid.canardpc.com/show_oc.php?id=2596999
kazso
  • Easy OC
« Reply #3 on: 13-November-09, 18:36:16 »
Flashed the newest, v1.7 bios today and now i have the "Unlock CPU Core" option in the Cell Menu ;-))
Ofc i tried to unlock my CPU right away :smiley:
The unlocked CPU has been identified as "AMD Phenom II X4 20" (from AMD Phenom II X3 720).
Running Prime95 25.9 x64 (ftp://mersenne.org/gimps/) for 2 hours now without any errors  :biggthumbsup:
Are there any other programs i should use for testing?
nt650_999
  • Afterburner
« Reply #4 on: 14-November-09, 01:52:16 »
I have four cores so I can't tell for sure but if you end up flashing back to 1.6 for any reason, look under "Core Control" in the cell menu.  That's where cores are enabled and disabled.
-790FX-GD70; BIOS rev. 1.6.
-Phenom II X4 945 3.0 GHz.
-Corsair Dominator 2x 2GB DDR3 1600 @1600 9-9-9-24 1T.
-BFG 9800 GTX+.
-Corsair TX750 - single 12v+ rail @60+ amps.
-Raptor SATA 140 GB internal for OS, data on external.
-Pioneer external/USB CD/DVD multi.
-Vista Business, all available updates.
Antec 800 case.
