Chris Nicola
« on: 14 November 09, 18:41:25 » |
I recently installed the OnOne Photo Essentials plug in for Photoshop Elements 8 and noticed that launching one of the programmes causes PSE8 to crash. OnOne support have informed me that to solve this issue I will need to install a GL supported video card. At the moment I have NVIDIA Geforce FX5200 with the latest driver for XP which evidently is not GL supported.
Does anyone know if a GL supported graphics card will fit or work on this board? (MSI 865PE-Neo2 Mainboard) Any suggestions on a cheap one that will work?
Has anyone else experienced programme crashes with a non GL supported card and are there any work arounds instead of replacing the card?
Kind Regards Chris
Motherboard 865PE/G Neo2-P MS-6728(v2.2) ATX Bios type and revision - V3.7 - 20thMay04 CPU P4 Prescot - 3.06 GHz No Over Clocking Memory- Dram Master DDR 3000 Mbt (2x 512 + 2x 1024) Video-GeForce4 FX 5200 Driver 5.6.6.3 -29thFeb04 Power-Antec Neo Power 480W. +5V-38A/+12V1-18A/+12V2-15A/+3.3V-30A/-12V-1A/+5Vsb-2A UPS-Lantech 500W Cooling-CPU Fan + 3 fans (2 Rear out + Front Fan in) HD1-Seagate SATA 300Gbt (3 partitions) DVD Samsung TSST corp CDDVDW SH-S202N DVD Samsung TSST corp CDDVDW SH-S202N OS XP SP3
go_for
Double Ace
Offline
« Reply #1 on: 14 November 09, 19:39:29 » |
Need to ask, is the GL you refer to same as OpenGL? If so, the problem might be elsewhere, as FX5200 does support OpenGL and quite good it looks like, from reading on the web. Some reports of less compatibility depending on nvidia's driver version, sorry can't help more. e.g like http://forums.nvidia.com/index.php?showtopic=59291&mode=threaded&pid=324964
MSI K8N Neo2 Platinum, bios 1.D0RXZ(2 boards) Opteron 146@2500MHz 2048MB Nanya (2x1GB) 3-3-3-8@1T HPC-420-302DF(LC6550G&Tagan 480W-U01 kicked the bucket) Hitachi 2 x T7K500 SATA RAID-0 Inno3D FX5500/128MB Benq DW1620 Pro DVD-RW MSI digivox miniII v3.0 USB DVB-T Buffalo WHR3-G54 wireless AP&Router neovo F-419 R12 DVI
Henry
MSI HQ Red Rockets Team Member
Offline
Carson City, NV, USA
« Reply #2 on: 15 November 09, 01:16:35 » |
An entry level FX5200 is far from the best for Photoshop work but it certainly does support OpenGL. Try it without the mixed RAM you have installed, remove the 2x512 for a test.
P45 Platinum/BIOS 1.6, Q6600 B3@3.0GHz, CM Hyper TX HSF A DATA 2x1GB PC6400 DDR2 800, XP Home/SP3 & W7 RC Corsair TX650W +12V~52A, MSI N260GTX 2D896 OCSPIBM 14GB PATA HDD, 2 Maxtor 80GB SATA HDD's SONY 52x24x52x burner Cooler Master Elite 330 (f@h rig) Sony Media Center PC P 560J 3.6GHz, XP Pro SP3, Intel MB of some kind MSI RX1950PRO-T2D256E, Corsair VX450W +12V~33A WD2500 250GB SATA, Sony DVD ROM, I/O Magic CD/DVD combo burner w/LightScribe
Chris Nicola
« Reply #3 on: 16 November 09, 17:07:34 » |
I checked the report from OnOne software and evidently I need a card that supports Open GL 2.0 to stop the crash. Does my FX 5200 support Open GL 2.0 or will I have to replace the card? I am using thelatest driver 175.19. How can I Know if Open GL2 is working?
OnOne essentials 3 is the only programme on my system that has a problem with this card. I don't know if there are any other work arounds.
Kind Regards Chris
« Last Edit: 16 November 09, 17:59:11 by Chris Nicola »
Henry
Offline
« Reply #4 on: 17 November 09, 03:34:44 » |
I don't know what year OpenGL 2.0 came out but I do know the FX5200 has been around since about April 2003. Best I can find is that FX 5200 supports OpenGL 1.5 and earlier. This info is from NVIDIA website. It looks like you need a newer graphics card for what you are doing. http://www.nvidia.com/page/pg_20040109440047.htm
Chris Nicola
« Reply #5 on: 17 November 09, 16:42:53 » |
Thanks for the help. I found a NX6200AX-TD256H AGP card TV/DVI (256 Ram) in a shop locally and am looking into thepossibility. Out of interest will a better graphics card improve the performance of Photoshop Elements? I ask because it is a still image programme.
Kind Regards
Chris
Henry
Offline
« Reply #6 on: 18 November 09, 01:56:24 » |
Are you sure that has OpenGL 2.0 support? The 6200's I looked up only support up to 1.5 like your 5200. I think you need to go up to at least a 7300 for 2.0 support from what I've been able to find so far.
Grayone
MSIHQ Red Rockets Team Member
Forum God
Offline
« Reply #7 on: 18 November 09, 02:54:14 » |
I agree with Henry. Some 6000 series cards can run Open GL 2.0 but not as well as a 7000 series.
P6N Diamond C2D E6600 @3.0Ghz @1.32v GSkill 2x1gig PC6400 5-5-5-15-1T @1.95v Hanns-g JW199D 19in. monitor 2 80Gig Maxtor SATA HD Lite-On DVD-RW 2x 8800GS & 2x 9600GT video cards Corsair 650TX- 3.3v/24A 5v/30A 12v/52A Folding@Home 24/7 w/GPU2 & SMP clients XP Pro w/SP3 K8N Neo4-F (PCB 3.0) AMD X2 4200+ @ 230x11 @1.38v GSkill ZX 2x1gig DDR400 @2.5-3-2-5-1T@2.6v 8800GT video card 160gig WD HD - Samsung DVD burner Corsair VX450- 3.3v@20amp-5v@20amp-12v@33amp XP Pro w/SP3 Folding@Home 24/7 w/GPU2 & SMP clients
Chris Nicola
« Reply #8 on: 18 November 09, 16:38:14 » |
I appreciate the advice. I checked and the NX6200 was advertised as supporting openGL 1.5. Are there any recommended 7000 series AGP cards that will fit on my board?
Kind Regards Chris
Grayone
Forum God
Offline
« Reply #9 on: 18 November 09, 17:25:11 » |
This costs about the same as a 7300 series card but offers more IMHO. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127366
Mike
aka Frankenputer 備份管理員 Backup Dude
Administrator
Offline
Virginia, USA
« Reply #10 on: 18 November 09, 18:45:32 » |
Greyone, that's a PCI express card. He needs an AGP card. For Nvidia, the 7600GS and GT support OpenGL 2.0 The 2600 ATI AGP cards will perform better: http://global.msi.eu/index.php?func=prodpage2&maincat_no=130&cat2_no=137&cat3_no=173The limiting factor may be your PSU, but either card needs about 25A on a +12V rail for a minimally configured system. You might just squeak by.
#1: MSI X38 Diamond/Bios 1.5; Core2Duo E8400 3.0Ghz; Thermalright Ultima-90HS/120 fan; 2X1GB DDR3 CorsairTWIN3X2048-1333C9DHXG; PIONEER|DVR-215DBK SATA DVD-DL & Lite-on DVD-ROM PATA; FDD; MSI 260GTX-T2D896; 190.62; Seagate 320GB & WD 500GB SATA HDDs; PC P&C Silencer 750 +3.3V/24A~+5V/30A~+12V/60A; X-FI Xtreme PCIe; Antec P182 Case; XP PRO SP3 #2: MSI 865PE Neo2-PFS Platinum/Bios 3.A; P4 2.8C HT; Thermalright XP-90HS; 2GB DDR400 RAM(2x1GB kit Mushkin HP3200 2-3-2-6); Nec ND-3550A DVD-DL & TDK 52X24X48 CD-RW; FDD; Nvidia GeForce 7800GS; 84.21; Maxtor 200GB & Seagate 200GB PATA HDDs; Enermax 465P VE-FMA +3.3V/35A~+5V/35A~+12V/33A; Audigy 2ZS; XP PRO SP3 Dell 2209WA LCD on a DVI KVM switch MSI Wind U100
Grayone
Forum God
Offline
« Reply #11 on: 18 November 09, 22:33:34 » |
OOPS!  Thanks for catching that Mike. Chris, Mike has brought up another possibility for a video card if you want to look at what ATI has to offer in an AGP Open GL video card.
Henry
Offline
« Reply #12 on: 18 November 09, 23:34:46 » |
What Mike links to for ATI and this one for NVIDIA 7600 are it for the latest MSI offers for AGP. http://global.msi.eu/index.php?func=prodpage2&maincat_no=130&cat2_no=136&cat3_no=139 Good luck trying to find anything suitable in AGP in the eastern Med area. Obviously we are only going to recommend MSI but being on that island you have to settle for whatever you can find.
Chris Nicola
« Reply #13 on: 20 November 09, 14:13:25 » |
Thank you everyone for your suggestions.
Kind Regards Chris
Henry
Offline
« Reply #14 on: 20 November 09, 21:58:40 » |
It's either that or move up to a motherboard that has PCIe and then you will have a large selection of VGA cards to chose from.
