Author Topic: MSI A6000-030US Wireless Capability Disabled  (Read 7030 times)
bobnycrr
  • Neo
« on: 10-December-09, 01:33:33 »
I just picked up this product from Fry's last weekend.  I installed a new Belkin N Wireless Router for my ISP connection.  I now have two wireless routers in the house but no signal is displayed so no connection.  I have verified that the device is enabled, both wireless routes have the correct information.  Test shows that the devise is disabled, I see button to press to start WiFi that sets the green LCD is on but the device does not link up to my router.  Help!
WeAreNotAlone
  • Afterburner
Re: MSI A6000-030US Wireless Capability Disabled
« Reply #1 on: 10-December-09, 01:50:46 »
To keep from spending alot of time... I'd visit a couple of wireless spots and see if the unit can connect.
A5000-025US
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #2 on: 10-December-09, 01:55:00 »
What security are you using in the Routers?
#2:
MSI Wind U100
bobnycrr
  • Neo
« Reply #3 on: 10-December-09, 02:43:09 »
I have a number of other wireless routers in the neighborhood that I can see from my other laptop in the house.  I can see both of my wireless from my Sony Vio plus the others, the Sony has Vista on it.  I also have Toshiba wireless that has XP and it works good.
Just seems that the MSI is seeing any signals from any routers.
WeAreNotAlone
  • Afterburner
« Reply #4 on: 10-December-09, 03:10:45 »
Re: I just picked up this product from Fry's last weekend.  Just seems that the MSI isn't seeing any signals from any routers.
1: I think pushing (2 times?) the wireless button toggles unit between Bluetooth, and wireless network.
2: NEW doesn't mean "Good". Keep that in mind. Post on a bad? network card: http://slickdeals.net/forums/showpost.php?p=24802844&postcount=576
On your unit not seeing any networks...  uninstall/reinstall the drivers.
(I would try a unsecured hotspot just for the heck of it to get around issues such as a hidden SSID, security settings. Thing that shoots a hole in that is you say your other units see other networks.)
3: Contact MSI and make them work for their money, be sure to post back what transpires.
« Last Edit: 10-December-09, 03:17:13 by WeAreNotAlone »
A5000-025US
bobnycrr
  • Neo
« Reply #5 on: 10-December-09, 05:55:27 »
great news,   did some checking and did some updating on a number of items including the wireless device, now everything is working.  Thank you for all you assistance.
