Author Topic: Direct download for MS-7222 v 2.0 (or PM8PM-V) driver  (Read 25688 times)
Archimag
  • Neo
« on: 29-January-10, 12:32:26 »
Recently I have updated my BIOS version through windows "Live update tool" and since then my LAN device doesn't work. I have decided to try "USB flash BIOS" tool from this site in order to solve the problem. I am currently using internet by different computer, and from what I understand I need zip or rar file compatible with my motherboard BIOS.
My damaged computer motherboard specs are:
N1996 MS-7222 Ver. 2.0 (product name : PM8PM-V)
OS : windows XP SP3
The BIOS currently installed: W7222VMS V 3.3
I have checked official product page (http://global.msi.eu/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1039), but there is no way of directly downloading BIOS file, only "Live Update" tools, and I don't want to use them since I am using different computer for downloading data.
From available BIOS list (http://tw.msi.com.tw/autobios/VerChk/Listbios.asp?WorkFun=LB&WorkPath=abc) I see that there 2 new supported versions of my BIOS, which are 3.3 and 5.5, all I need is a direct link to download those both versions (just in case).
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
Re: Direct download for MS-7222 v 2.0 (or PM8PM-V) driver
« Reply #1 on: 29-January-10, 12:39:04 »
http://forum-en.msi.com/index.php?topic=134058.0
5.xx is not for your board, you can use only 3.xx
Archimag
  • Neo
« Reply #2 on: 29-January-10, 16:24:42 »
Thank you Svet, it installed the the BIOS but didn't solve the problem, I will try and ask if it is a LAN driver issue.
  • Administrator
« Reply #3 on: 29-January-10, 16:27:49 »
what lan issue you have?
Archimag
  • Neo
  • Administrator
« Reply #5 on: 29-January-10, 23:05:05 »
well you shall told what's your issue from the beginning
