Author Topic: Built-in webcam not working  (Read 5496 times)
Prince-Ali
  • Neo
« on: 07-March-10, 14:24:57 »
Hello, Im new im not sure if this is the right spot to make this thread(sorry)
But my problem is that i have an Msi Wind U100, normally with xp home.
I have installed win7 and now is the webcam not working???
I have tried MSI Q-Face, but is says "Capture device was used or not installed!"
 in control panel i see the cam: http://i47.tinypic.com/11jc4jp.png
Any thing to do? :/
Prince  :hypocrite:
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
Re: Built-in webcam not working
« Reply #1 on: 07-March-10, 14:28:49 »
Does it work in any other program?
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #2 on: 07-March-10, 14:32:09 »
Is SCM installed? http://global.msi.eu/index.php?func=downloaddetail&type=utility&maincat_no=135&prod_no=1474
Did you use Fn+F6?
As Stu states, did you try another program like Skype, MSNM?  The only version of Q-face I see is for XP 32bit.
#2:
MSI Wind U100
Prince-Ali
  • Neo
« Reply #3 on: 07-March-10, 14:37:42 »
What do you mean?
EDIT; Okay, im trying thoses options now. :)
« Last Edit: 07-March-10, 14:41:43 by Prince-Ali »
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #4 on: 07-March-10, 14:44:11 »
Did you install the SCM(System Control Manager) utility.  Here, http://global.msi.eu/index.php?func=downloaddetail&type=utility&maincat_no=135&prod_no=1474 , is the SCM utility for the U100.
Did you hold down the Fn key and then, while still holding down the Fn key, press the F6 key to turn on the Webcam?
I don't know how to make my 3rd paragraph clearer except to explain that MSNM is MSN messenger.
#2:
MSI Wind U100
Prince-Ali
  • Neo
« Reply #5 on: 07-March-10, 14:55:40 »
Ohhh thanks i needed the SCM! ;D
Have a good day!  :biggthumbsup:
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #6 on: 07-March-10, 16:13:41 »
:hat tip:
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #7 on: 07-March-10, 20:36:33 »
 :biggthumbsup:  :hat tip:
#2:
MSI Wind U100
