Author Topic: MSI A6200-206US Webcam issues  (Read 17770 times)
prshack
  • Neo
« on: 06-August-10, 22:51:18 »
I have recently purchased this computer: http://www.officedepot.com/a/products/497949/MSI-A6200-206US-156-LED-Backlit/
During the initial setup, it got to the point where it was installing "Windows Live English" and stalled for about thirty minutes, so I turned the computer off. After running it in safe mode and getting a BSoD once, it works just fine, except for the fact that it does not believe that there is a camera installed. I can't find a driver or anything on this site either.
prshack
  • Neo
Re: MSI A6200-206US Webcam issues
« Reply #1 on: 06-August-10, 23:16:35 »
I figured out the webcam issues (reading works wonders), but I still am curious as to where to find the driver updates, and what else could have gone wrong with the Live thing.
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #2 on: 07-August-10, 03:07:27 »
A6200 is the USA designation.  The rest of the world labels it as a CR620.  The webcam uses the built-in OS drivers be it XP or Windows 7.
http://www.msi.com/index.php?func=proddesc&maincat_no=135&prod_no=1983
#2:
MSI Wind U100
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
« Reply #3 on: 07-August-10, 03:10:15 »
all that you need is to activate the webcam [check your manual about it], OS will install it automatically
prshack
  • Neo
« Reply #4 on: 07-August-10, 03:58:41 »
Ah, thanks. I figured it must have been something like that if it wasn't showing up anywhere on their site.
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #5 on: 07-August-10, 04:16:03 »
Yes, we wish MSI USA would use the same designations that the rest of the world uses--it would save a lot of confusion.  BTW, on the USA, there is a link for downloading drivers and the manual which leads you to the page I linked.
We have a sticky about the differences in designations: http://forum-en.msi.com/index.php?topic=133088.0
#2:
MSI Wind U100
