Win a Z87-GD65 GAMING motherboard with the MSI Forum Wallpaper Design Contest
Author Topic: Remove MSI LiveUpdate  (Read 4055 times)
ccc
  • Cyclone
« on: 15-January-11, 18:46:38 »
hi
I cannot remove MSI LiveUpdate4 on my XP due to the following error:
Code: [Select]
File "C:\Program Files\MSI\Live Update4\unins000.dat does not exist.Cannot uninstall."Is it any removal tool to remove LiveUpdate4?
« Last Edit: 15-January-11, 18:52:56 by ccc »
PM8M2-V, Pentium4 640~3GHz
MSI NX6600 (MS-8989), 256DDR SDRAM
2 x Apacer Technology, DDR-SDRAM, 1GB
RealTek Semiconductor RTL8169, Gigabit Ethernet Adapter
HDD master: SAMSUNG HD400LD, 400GB
HDD slave: WDC WD5000AAKB-00H8A0, 500GB
CD/DVD ROM Master: HL-DT-ST DVDRAM GH24NS70
CD/DVD ROM Slave: LITE-ON DVDRW SHW-16H5S
Power Supply: Raptoxx RT-550W 1.3, 550W
WIN XP, SP3, 32-bit
Linux Debian Squeeze/Wheezy
FreeBSD 8.3
Jack
  • Ex Forum moderator
  • Power Edition
Re: Remove MSI LiveUpdate
« Reply #1 on: 15-January-11, 18:49:43 »
Reinstall the tool properly and then try to uninstall it again.
ccc
  • Cyclone
« Reply #2 on: 15-January-11, 18:57:33 »
Thx, but can someone pls post a link of LiveUpdate4 setup file?
I can find just Live Update Online.
WIN XP, SP3, 32-bit
FreeBSD 8.3
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
ccc
  • Cyclone
« Reply #4 on: 15-January-11, 21:23:10 »
THX, it works now.
WIN XP, SP3, 32-bit
FreeBSD 8.3
JoeG
  • Neo
« Reply #5 on: 23-January-11, 07:12:04 »
I, too, am having the same problem but with Live Update 3.
Trying to delete so I may upgrade.
Would you please post link to this,
Greatly appreciated.
jojodancer
  • Winki
« Reply #6 on: 12-February-11, 09:08:30 »
http://liveupdate4.msi.com/autobios/SERIESEXE/LiveUpdate.exe
hi I have the same problem. but the version from the link is before the 4.0.104 version.
when I tried to install it, it says:
"A newer version Live Update 4.0.104 is already installed in your system !"
I need to install and uninstall this again in order to clean off  the mess  :undecided:
Moderator please direct me to the 4.0.104 version.
i7 870 (4.08GHz) / Crosair H70
4 x 2GB G. Skill DDR3 2200MHz CL7-10-10-26
Gigabyte P55A-UD6
2 x MSI HD5870 Lightning II
Crosair AX1200
4 x OCZ Vertex2 60GB in RAID 0 (OS) / 1 x VelociRaptor SATA3 6GB/s 600GB (games) / 1 x WD SATA3 1TB (storage)
LG 8X Blu Ray rewriter / Plextor 24X DVD rewriter
Lian Li PC-60FNW
Lamptron TOUCH fan controller / Noiseblocker PK-3 / 2 x Xigmatek CLF-F1454
  • Administrator
« Reply #7 on: 12-February-11, 15:32:31 »
http://download3.msi.com/files/downloads/uti_exe/LiveUpdate.zip
  • Administrator
« Reply #8 on: 13-February-11, 00:28:32 »
Doh.. :bonk: that thing crashed instantly :rolleyes_anim: at my machine with [32bit XP with SP3]
And where it can run without the crash, :bonk:
it's advertising and pickup the wrong VBIOS for an user's VGA: :rolleyes_anim: ==> http://forum-en.msi.com/index.php?topic=145738.0
jojodancer
  • Winki
« Reply #9 on: 13-February-11, 02:07:51 »
wow!
Gigabyte P55A-UD6
Crosair AX1200
Lian Li PC-60FNW
