Author Topic: MSI 560 GTX Ti Twin Frozer 2 Problem during startup/boot  (Read 4108 times)
Erik Masters
  • Neo
Hi,I have unusual problem with my 560GTX.It has something to do with fan regulation.During startup and W7 boot they spin far below normal,making loud buzzing/humming sound. After W7 boot Afterburner shows,that fans spins at 800rpm.They return to normal 1800rpm after 1-2min at idle.What can I do about this problem,before I sent the card to RMA?
  • T9246ED, Бивша комета
  • Administrator
  • Online Online
    • MSI BIOS/EC-FW Mods
Re: MSI 560 GTX Ti Twin Frozer 2 Problem during startup/boot
« Reply #1 on: 21-March-11, 18:50:05 »
Possible driver issue or driver mess.. Do this:
Use Driver Sweeper to complete remove current VGA drivers, do this in "Safe Mode"
http://phyxion.net/item/driver-sweeper.html
then reboot and load windows as usual,[in normal mode]
and install latest VGA drivers 267.26 http://www.geforce.com/#/Drivers/Results/27598
Erik Masters
  • Neo
« Reply #2 on: 21-March-11, 19:15:18 »
Ok Ill try that. Also is it possible to somehow reduce fan speeds at idle? Its quite loud at idle-1700/1800rpm 40%.
  • Administrator
  • Online Online
« Reply #3 on: 21-March-11, 20:15:02 »
yes it possible, but see how its goes the main issue 1st
Erik Masters
  • Neo
« Reply #4 on: 21-March-11, 22:15:45 »
Ok,I completely removed drivers with driver sweeper in safe mode,then did clean install of 267.26 drivers in normal mode.No problems so far,but Ill give you definite answer tomorrow.In the meantime what I can do about fan speed at idle?
  • Administrator
  • Online Online
« Reply #5 on: 22-March-11, 01:30:52 »
oki
to read this topic:
http://forum-en.msi.com/index.php?topic=146079.0
Erik Masters
  • Neo
« Reply #6 on: 22-March-11, 12:26:45 »
Hmm I have VBIOS backup from GPUZ but I cant send it to you via PM. Error message says,that I cant view any profile. Is there any other way to send you BIOS backup?
  • Administrator
  • Online Online
« Reply #7 on: 22-March-11, 16:27:29 »
upload it somewhere, like here: http://www.mediafire.com/
or somewhere else
Erik Masters
  • Neo
« Reply #8 on: 22-March-11, 18:47:10 »
  • Administrator
  • Online Online
« Reply #9 on: 22-March-11, 18:51:23 »
check pm
PythonJ
  • Neo
« Reply #10 on: 25-March-11, 17:50:54 »
-Removed-
« Last Edit: 25-March-11, 18:04:52 by PythonJ »
  • Administrator
  • Online Online
« Reply #11 on: 25-March-11, 17:53:03 »
@PythonJ
Do not hijack other people topics. >>Please read and comply with the Forum Rules.<<
