Ok, Ill describe as best I can.
Bought as a 'refurb' from an outlet. Running Win 7 starter edition.Connected via ethernet cable to router to set up router. All ok. Ran microsoftupdate to get everything 'up-to-date'.All ok.Restarted. Pressed Fn and F11 to turn wireless 'on'. It sees the wireless router ok.Asks for the security key. I enter this correctly but it wont connect. Tried an Ipod touch and it connects fine with the key.
To summarise ;
router definitely ok
netbook 'sees' the router but wont connect, even with the security key entered
No specific error message, just 'cannot connect'
Any advice/help appreciated
John
Edit - also this is just 1 day old.
Edit2 - I also forgot to say. I disabled the security from the router so it was 'open' and the netbook still would not connect, but it 'sees' the network
