Author Topic: Manually turn on/off wireless  (Read 1597 times)
LastTemplar
  • Neo
« on: 28-April-11, 15:55:38 »
Hello everyone,
I have an MSI GX630 laptop. The touch sensor bar at the top of the keyboard got smashed recently, and now I cant use touch sensors to enable my wifi or my camera or use any of the buttons that were on that panel. Could someone tell me if there is a method to manually enable/disable wireless on my laptop? because I went to repair it and the told me it can't be done because they don't have these kind of parts for sale.
Thank you.
Ex Forum User 3
  • Hawk
Re: Manually turn on/off wireless
« Reply #1 on: 28-April-11, 16:06:58 »
Contact MSI for repairs.
LastTemplar
  • Neo
« Reply #2 on: 28-April-11, 16:22:08 »
This is the only way to do it?
LastTemplar
  • Neo
« Reply #3 on: 28-April-11, 17:32:41 »
Can I somehow modify the hotkeys in SCM in order to use a combination to turn on and off wireless?
Vogelson
  • Winki
« Reply #4 on: 28-April-11, 18:28:16 »
I believe that the soft key on the display bar is controlled by a start up program.  You could try uninstalling or disabling the program in /msconfig.  Then you might be able to manually control it with the device manager.
I don't know if that will work, but it's an idea...
I hope this post will help in some way,
Travis
Ex Forum User 3
  • Hawk
« Reply #5 on: 28-April-11, 18:59:20 »
The sensor bar is smashed! How on earth does reinstalling help?
LastTemplar
  • Neo
« Reply #6 on: 28-April-11, 19:00:41 »
Tried, it did not work :( I just realized that I can't even turn on my webcam nor my bluetooth, how can there be no other way to enable these devices on a computer?!
LastTemplar
  • Neo
« Reply #7 on: 28-April-11, 20:24:20 »
Come on, is there really no alternative to this, I've searched the internet for this the whole day and didn't find any answers :/
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #8 on: 28-April-11, 20:35:58 »
The broken part will have to be replaced, simple as that. You can send it back to MSI for an 'out-of-warranty' repair, but it will cost you.
