Author Topic: MSI 880 GMA-45 Windows installation issues  (Read 1442 times)
Petha
  • Neo
« on: 02-June-11, 18:21:56 »
Just built a system around the aforementioned motherboard.Other components include :
CPU : Phenom II X4 955
RAM : Corsair XMS3  , 2X2GB , 1333 ( Corsair's site states they're compatible with all Amd and Intel  platforms)
VGA : Twintech  GTX 550 Ti
PSU : Corsair  Gaming GS 600
The issue : While the system seems to boot up fine, i couldn't install any operating system , from XP up to 7 .As soon as it would boot up from the installation cd, it'd either throw a blue screen with  the irq less or equal error message, or a black screen with the letter "H" in a straight  column (weird as it may sound, that's what i got).Moreover , it wouldn't boot up  to the previous window installation.
After trying this and that, i swapped out the 550Ti  with my older 8400 GS ; same issues.Tried the same without any gfx card on, it would boot from the previous installation, and proceed to windows install .
Is there a setting in my  BIOS i am unaware of, or do i have  to  RMA the board ?
Thanks in advance :)
Lithium466
  • Twin Frozr
Re: MSI 880 GMA-45 Windows installation issues
« Reply #1 on: 02-June-11, 18:27:11 »
Have you tried with different hdd, optical drive, or sata cables ?
MSI 890GXM-G65
Phenom II X6 1055T & Zalman CNPS10x Flex
2x 2Go Kingston HyperX 1600Mhz
BeQuiet Straight Power E7 400W (+12V 30A)
Ex Forum User 3
  • Hawk
« Reply #2 on: 02-June-11, 20:08:19 »
Petha
  • Neo
« Reply #3 on: 02-June-11, 23:35:02 »
Indeed  it was a faulty memory stick, ran  memtest which came up with errors, swapped one stick out and everything went back to normal.Thanks for your aid :)
