Author Topic: BIOS update using Msi's Live Update 5 Tool, now blank screen on startup  (Read 3545 times)
sasdas
  • Winki
As topic states, I downloaded an update and installed it in windows mode, once the computer restarted the monitor does not turn on, the mouse flashes its lights once, and thats it. Nothing else pops up, I removed the cmoss to see if that would work, didnt seem to do anything,
My board is Model MS-7599  870A-G54
SeaSonic S12II 520 Bronze 520W ATX12V V2.3 / EPS 12V V2.91 80 PLUS  BRONZE Certified Active PFC Power Supply
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
AMD Phenom II X4 970 Black Edition Deneb 3.5GHz Socket AM3 125W  Quad-Core Desktop Processor HDZ970FBGMBOX
x SAPPHIRE  100283 L Radeon HD 5770 ( Juniper XT) 1 GB 128- bit GDDR5  PCI Express 2.0  x16  HDCP Ready CrossFireX Support Video Card
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual
« Last Edit: 24-June-11, 23:37:07 by sasdas »
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
sasdas
  • Winki
I read the clear the cmoss guide, and nothing changed.
  • Administrator
have you removed the power cord from the PSU 1st?
sasdas
  • Winki
Yes, I removed the cable first.
  • Administrator
leave one memory stick only in 1st dimm close to cpu socket, then try to boot
sasdas
  • Winki
Ok, that worked, right now, I'm looking at the Cmoss setup utility, can u explain to me what I should do from here?
Also, how does removing one RAM card do this?
  • Administrator
Apply 2T Command rate, then save and exit.
the turn it off, and add the second stick again and try to boot
sasdas
  • Winki
I'm sorry, I don't see 2Tcommand rate
  • Administrator
look in your mainboard manual
sasdas
  • Winki
I changed  the command rate to 2T, then added the second RAM, it went to black screen again.
« Last Edit: 25-June-11, 02:10:46 by sasdas »
  • Administrator
Make sure that they run at 1333MHz
sasdas
  • Winki
It says that the frequency is at 1333
  • Administrator
did you use correct DIMM slots when you use both of them?
sasdas
  • Winki
Before I moved it to 1, I had used 2 and 4, and now I'm trying 1 and 3
  • Administrator
sasdas
  • Winki
Nothing, I went and changed the frequency and manually changed it to 1333, but it did not do anything.
  • Administrator
try second memory stick alone in the 1st dimm close slot
sasdas
  • Winki
I had tried it in the 4th one, it worked by itself
  • Administrator
flash back to your old bios where both of them worked fine together
sasdas
  • Winki
Ok, well I don't know which one it was, and also I don't know how to flash it, only doing it from windows
  • Administrator
what is current bios version installed?
sasdas
  • Winki
How do I find out?
  • Administrator
look in bios setup, system information
sasdas
  • Winki
V17.12
  • Administrator
>>Use the MSI HQ Forum USB flasher<<
and flash back step back one by one until it can work with both sticks:
http://www.msi.com/product/mb/870A-G54.html#/?div=Download
start from HA, if no change, go to H9 and so on.
sasdas
  • Winki
I'm trying to boot from flash drive, but all that happens is a flashing underscore
sasdas
  • Winki
Ok, I got it to work, now both RAM was accepted, tyvm.
  • Administrator
no problem
