Author Topic: CX640 Boot issue!  (Read 1430 times)
Zoricus
  • Neo
CX640 Boot issue!
« on: 14-July-11, 15:27:30 »
Hi all, Just found this forum  :biggthumbsup:,
        Anyway I just purchased a CX 640 notebook for my son,loaded with Windows 7 64bit. Shut it down normally and the next morning when we tried to turn it on we got this message "Reboot and select proper boot device and press any key". I tried to reboot a bunch of times and still got the same thing. I did a search online and found that it might be that the master boot record may be corrupt.  :biggthumbsdown:
 I can get into the BIOS and it sees the HDD. I have also used windows 7 disk to run startup repair multiple times. From what I have read it might have to be run multiple times to fix any issues. Ive tried that 4 times so far and it hasn't resolved the issue.
Under the "repair your computer" options on the windows 7 disk i get into the command prompt and It still will not see the C: drive. I have also tried Bootrec /fixmbr, /fixboot etc and still no dice.
I'm out of options and ideas short of manually repairing manually repairing the bootloader. I.E. THE NUCLEAR OPTION! I did not want to open up the back and void the warranty.
Anyone else out there had the same issue with this line of notebook? Maybe the HDD did take a big crap I'm just not sure. Any help ideas or input is appreciated!  :confused2:
Thanks,
         Rich
Ex Forum User 3
  • Hawk
Re: CX640 Boot issue!
« Reply #1 on: 14-July-11, 16:02:11 »
Can you see anything if you boot an Ubuntu LiveCD?
Zoricus
  • Neo
« Reply #2 on: 14-July-11, 18:01:05 »
Thanks for the reply Bas,  I didn't do an install of ubuntu just used the CD. It can see the HDD. Not all that familiar with ubuntu either.
Ex Forum User 3
  • Hawk
« Reply #3 on: 14-July-11, 18:16:25 »
Can you also see the data on it?
If so, something destroyed the boot-sector.
With Ubuntu you can reformat the MBR, and if you do, after reinstalling Windows the machine should work again.
However, it could still be a bad drive, if the bootsector is damaged physical it won't boot ever.
Zoricus
  • Neo
« Reply #4 on: 14-July-11, 19:01:07 »
Oddly enough it says there is nothing on the HDD. Unallocated space 500gig. ??
Zoricus
  • Neo
« Reply #5 on: 14-July-11, 19:04:58 »
Well Bas thanks for the reply's and the help, just got an email back from customer support with an RMA number. Oh well was hoping I wouldn't have to go down that route and it was something I would be able to fix myself.
