Author Topic: Bios for PM8PM-V Board (MS-7222)  (Read 2317 times)
Takx
  • Neo
« on: 20-August-11, 04:53:48 »
Hello There,
Here I'm, just after google couldn't help me anymore.
Well, as the title say, I`m looking for a BIOS for the PM8PM-V motherboard, it is old I know, but I`m having a USB problem (wont recognize mouse, pendrive, on windows xp or 7) and my last shot is updating the bios, maybe it can fix my problem.
I just downloaded MSIHQ Tool for BIOS update, but don`t have the Bios file, need the last one please, mine is Phoenix - Version 6.00 PG Date 11/09/2006, I`m pretty sure there is a 2007 bios release for this board, but couldn't`t find it.
If you guys know a better tool for updating this bios, please tell me.
Thanks for the help in advance
Wonkanoby
  • Lightning
Re: Bios for PM8PM-V Board (MS-7222)
« Reply #1 on: 20-August-11, 10:29:14 »
first disconnect case usb from board header
boot to windows delete all usb in device manager
then reboot and retry rear usb
P5Q Deluxe
Intel QX 6700
4GB OCZ
60 GB Vertex drive
ATI 5850
Wonkanoby
  • Lightning
« Reply #2 on: 20-August-11, 10:32:20 »
P5Q Deluxe
Intel QX 6700
4GB OCZ
60 GB Vertex drive
ATI 5850
Wonkanoby
  • Lightning
P5Q Deluxe
Intel QX 6700
4GB OCZ
60 GB Vertex drive
ATI 5850
Takx
  • Neo
« Reply #4 on: 23-August-11, 00:37:39 »
Hey,
I downloaded that tool.
I'm seeing right on the BIOS right now (boot time), it says:
Phoenix - AwardBIOS v6.00PG
PM8PM W7222VMS V3.1B5 110906
So it is not MS7222 but W7222VMS.
Does someone know how can i get the last version of this BIOS? MSI just don't help by letting we download it from the their website... that really suck, this will make me twice before buying a MSI MB again =(
Thanks guys
Ex Forum Mod
  • Hawk
« Reply #5 on: 23-August-11, 01:04:54 »
 See this topic for BIOS     W7222VMSv330
 http://forum-en.msi.com/index.php?topic=124428.msg938626#msg938626
Takx
  • Neo
« Reply #6 on: 23-August-11, 01:20:59 »
The BIOS from this topic looks like the right one http://forum-en.msi.com/index.php?topic=148163.0
But there is a problem, how can i work with that tool (msi hq usb) if what i'm having trouble with, is the USB ports ? I cant plug a pendrive because windows doesnt recognize it, and the other computer I can use doesnt have a MSI board...
Isn't there a software to update it from windows? I dont believe i have a floopy disk around +_+
« Last Edit: 23-August-11, 01:28:09 by Takx »
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
« Reply #7 on: 23-August-11, 01:42:03 »
It's the wrong one.
Henry show you the correct one
you're issue problably isn't bios related, leave bios update alone
Read >>Posting Guide<<
Takx
  • Neo
« Reply #8 on: 23-August-11, 02:03:14 »
I installed Windows 7 Ultimate, Windows 7 Pro, and Windows XP, all of them detected that I plugged something on the USB but and error occurred and couldn't identify it. (tried mouse, pendrive, webcam)
It can't be BIOS related, but why not upgrading it anyway? It might just fix it (pointer to USB register just corrupted?), or I will just buy a PCI card with 4 USB, but my BIOS will be the last one anyway. And there is a second thing, I want to upgrade the processor, but this BIOS will not recognize the core 2 duo that say it support on the msi website.
Yeah, I think Henry got it right, now I have the BIOS, but the upgrading part is not helping much.
How people did upgrade it back on 2006 / 2007 ? (before this usb software).
Thanks for the help.
Ex Forum User 3
  • Hawk
« Reply #10 on: 23-August-11, 09:20:12 »
If the ports worked before it can't be the BIOS, as a BIOS doesn't go bad over time.
A BIOS works or it doesn't.
What changed in the hardware/software that you can't use USB anymore?
You have to trace your steps back to where it did work.
