Author Topic: MSI CX500 wireless problem  (Read 1833 times)
CanuoPa
  • Neo
« on: 04-September-11, 15:17:48 »
I have a problem with the wireless of my notebook since i bought it. So when it's on 3-4 meters of  the adapter (router)  everything is OK but when the distance is more the notebook is connected to the router but not connected to internet. I returned it to MSI service  where  the wireless card (don't remember the model) was replaced with Atheros AR9285.  I've installed the latest driver for it - 9.0.0.173 but it's still not working properly  and the problem is the same like before .:bonk:
Can you help me or give me any advice pls
Mark
  • Xpower
  • Former Moderator
Re: MSI CX500 wireless problem
« Reply #1 on: 04-September-11, 16:00:16 »
Are you sure it's not a signal problem from your router then? Do you have another notebook/desktop you can connect wirelessly to test? You could buy a better antenna for the router to boost the signal if it turns out to be the issue.
Have you tried updating the firmware on your router?
CanuoPa
  • Neo
« Reply #2 on: 04-September-11, 16:06:55 »
Sure, i tried with another laptop and it worked properly on 20+ meters distance.... Also i tried my laptop with another routers and  the problem is the same ...
Mark
  • Xpower
  • Former Moderator
« Reply #3 on: 04-September-11, 16:13:55 »
Is that actually the latest driver version? I only ask because there are newer versions here: http://forums.laptopvideo2go.com/topic/14833-latest-atheros-wlan-drivers-for-windows-7-and-vista-x86-x64/. Have a look and see if they work.
CanuoPa
  • Neo
« Reply #4 on: 04-September-11, 16:43:05 »
Now i installed the latest driver but the problem is still not fixed
Mark
  • Xpower
  • Former Moderator
« Reply #5 on: 04-September-11, 16:47:17 »
Is it showing as connected to the network and what signal strength is given? (A screen shot might help)
Ex Forum User 3
  • Hawk
« Reply #6 on: 04-September-11, 18:30:03 »
Wifi only goes a long way where there are no things blocking the "view" Walls/doors: stone, iron and concrete block the signal to unworkable after a few meters.
If your signal falls below about 70~80% troubles will start.
CanuoPa
  • Neo
« Reply #7 on: 04-September-11, 19:32:53 »
So here it is a screenshot -  http://imageshack.us/f/833/wlan.jpg/
It shows i'm connected but actually i even cant connect to the router through the browser. It's on   6-7 meters distance  1 wall btw the laptop and the router, but i also tried clear connection (no walls)...
Ex Forum User 3
  • Hawk
« Reply #8 on: 05-September-11, 09:34:12 »
Why is that a public network?
It seems to me something is blocking stuff.
Could be some custom firewall you installed.
Or your router doesn't provide DNS services properly.
Have you checked the parameters with ipconfig /all to see it everything is correct?
