Author Topic: 990FXA-GD80 Memory Question  (Read 663 times)
apem
  • Cyclone
« on: 07-September-11, 13:37:02 »
Im thinking of ordering the above board tomorrow and I would like to know if my Corsair DDR3 Vengance LP memory will work ok with this board?
Thanks in advance
Junior
  • Cyclone
Re: 990FXA-GD80 Memory Question
« Reply #1 on: 07-September-11, 13:45:25 »
Take a look on the MSI test report: >> Memory test <<
Mark
  • Xpower
  • Former Moderator
« Reply #2 on: 07-September-11, 15:08:22 »
It's listed as compatibile if you run the memory finder tool on the Corsair website. It also gives you part numbers to make it easier for you. Take a look here: http://www.corsair.com/learn_n_explore/?utm_source=Corsair&utm_medium=Website&utm_content=MemoryFinder&utm_campaign=FrontPage
Ex Forum User 3
  • Hawk
« Reply #3 on: 07-September-11, 20:22:39 »
Rule of the dump, if the memory is listed at the memory manufacturer as AMD tested (any board or CPU) then it will work.
Except Gskill, they often fail due to weird SPD programming.
