Author Topic: How to use OC Genie 2 - no button on mobo  (Read 3267 times)
brettwier
  • Neo
« on: 27-September-11, 20:22:32 »
I just installed my P67A-C43. I've got an i5 2500k and want to enable the OC Genie 2 function. There is nothing about how to operate it in the documentation that came with the mainboard. Tutorial videos suggest that I simply push a button on the mainboard, but there is no such button on mine!
Any help would be appreciated...
Thanks!
Froggy Gremlin
  • Power Edition
  • Master Air OC'er
Re: How to use OC Genie 2 - no button on mobo
« Reply #1 on: 27-September-11, 20:38:01 »
Excerpt from mainboard description;
Instant OC
• Instant MB info monitor
• Intelligently auto set clock/voltage of CPU and memory
• Smart Mode: 4 instant OC modes
I believe you have to install Control Center. Possibly in the UEFI/BIOS, there is a setting to enable OC function in the Windows environment or OC Genie function.
Life Can Be Very Fulfilling Without Win 8/8.1, SSD's, RAID, Current AMD GPU's, G.Skill RAM, Hackers, Crackers, & Crypto Mining!
IXOYE
Bernhard
  • HydroGen
« Reply #2 on: 27-September-11, 20:43:09 »
The lower end boards do not have the physical button.
Check the BIOS. I believe its one of the functions inside the BIOS as HU16E has already eluded to.
OCGenie will give you a 4,2 GHz OC with very optimistic voltages and normally one would activate it once, then save that as a profile.
After that switch it off/deactivate it again. Start with defaults and the load that profile. From there you then start tweaking the BIOS to improve on it.
1.MSI Z77A-GD65 BIOS10.6B7;i7-3770K@4,5GHz;Noctua NH-C14; Win7-64; Corsair 4X4Gb CML16GX3M4A2133C11B; CorsairTX650; Corsair Neutron 256GB SSD;MSI GTX660Ti PE; ST1000GB;WD300V-R;SonyDVD; Open Test bench.
Testing an Asrock board with i5-4670
"veni vedi doctus"
MSI 미친
brettwier
  • Neo
« Reply #3 on: 28-September-11, 16:01:32 »
Thanks for the tips folks, much appreciated!
