Author Topic: MSI EX630 - Windows 7 x64 Drivers [FINGERPRINTER BROKEN?]  (Read 2138 times)
sseann
  • Neo
Hello!
I've been searching through the forums trying to find the drivers that I need for this laptop. I just re-installed Windows 7, however I can't find drivers for it anywhere! This is a clean install of Windows 7 x64 SP1 - [Version 6.1.7601]
Laptop model: MS-1671
I installed 'Live Update 5' and installed the drivers that are offered there, which worked for a few devices, however there's still 5 devices in Device Manager that are missing drivers. They are:
  • Base System Device
  • Base System Device (yes 2 times)
  • Coprocessor
  • Fingerprint Sensor [Found Drivers - they give an error]
  • Unknown Device
The main devices I want to get working are the webcam and fingerprint reader.
I downloaded the fingerprint reader drivers, and when I attempt to install them I get the error: "To use this product, Windows Biometric Framework must be enabled". Thing is I've enabled it using Group Policy Editor (GPEdit.msc) and I'm still getting this error.
If anyone has some advice, perhaps a working link to some drivers / utilities - it would be much appreciated.
Thank you in advance!  :worship:
« Last Edit: 20-January-12, 23:42:48 by sseann »
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
Re: MSI EX630 - Windows 7 x64 Drivers [FINGERPRINTER BROKEN?]
« Reply #1 on: 21-January-12, 01:15:01 »
The only W7 drivers that MSI has are 32 bit.
http://eu.msi.com/product/nb/EX630.html#/?div=Driver&os=Win7%2032
#2:
MSI Wind U100
sseann
  • Neo
« Reply #2 on: 22-January-12, 17:39:21 »
I got the fingerprinter working just fine now. It took some time - but I had to enable Biometrics using GPEDit.msc - then install the drivers.
I still don't have a working webcam, however, and I doubt anyone on these forums has it working on x64 (or cares to check considering this laptop might be 'outdated' by now), so I'll continue my search elsewhere...
Thanks.
