Author Topic: Z77A-GD65 code B4  (Read 2574 times)
Budje70
  • Winki
Z77A-GD65 code B4
« on: 13-May-12, 13:34:48 »
Just finished building a new pc with the z77a-65 with a i7 2600 CPU and 16 gb corsair ram.
Normal boot Goes ok, but when I restart with an usb stick attached then the mobo gives me code B4. Nothing else works anymore after that. Even reset is stuck. Only a full off/on is giving me a normal boot again....but each time the system does a restart with the usb attached I get this B4. this is ofcourse not workable.
I already updated my bios but no luck.
Update.
After reset:
No USB attached: B2 - system hangs
bootable USB stick attached: B4 - system hangs
nonbootable USB stick attached: B4 - system hangs
So it always hangs with either B2 or B4 after a reset. Only a cold boot goes okay.
Is this a DOA motherboard?
Anyone with similiar faults?
« Last Edit: 13-May-12, 14:20:42 by Budje70 »
MSI Z77A-GD65
i7-2600
Corsair Valueselect 4x4GB (CMV4GX3M1A1333C9)
Crucial M4 128GB SSD
PSU Be-quiet Pure Power 300W
iceman_54
  • Neo
Re: Z77A-GD65 code B4
« Reply #1 on: 13-May-12, 19:20:39 »
yes happend to me wheird but one guy sayed this is not error code this is normal he is say that!??? but strange i dont like seeing any codes on system is when power on
NovJoe
  • Hawk
« Reply #2 on: 14-May-12, 05:11:35 »
Check in BIOS if you have Legacy USB support or similar settings enabled already. If not, try enabling these settings and try again.
MSI HQ Forum USB flasher
Budje70
  • Winki
Re: Z77A-GD65 code B4 ==> now not booting anymore code 55
« Reply #3 on: 14-May-12, 08:23:48 »
Well, it seems that I have much bigger problems now.
After a memory exchange the motherboard does not boot anymore. Only the Power LED on the onboard switch is working but pushing it results in nothing anymore.
Then I put the old memory back, and also then no booting anymore. Dead.
Another powersupply and the mobo came back to life, but only a few seconds, but now at least I got to see code 55, after that it goes rebooting again, and code 55, rebooting, etc. Also no videosignal.
debug-display =>  :worship:
What does that mean, 55, something in the CPU initialisation?
MSI Z77A-GD65
i7-2600
Froggy Gremlin
  • Power Edition
  • Gamer's Series!
« Reply #4 on: 14-May-12, 08:30:39 »
Tested Z77A-GD80 with a 3770k
First MSI was an 845G-Max. Since then, 975X-PUE, P6N SLI Platinum, P7N Diamond, P45 Platinum (3X), X58 Pro, X58 Pro-E, X58 Eclipse Plus (2X), X58A-GD65, X58 Big Bang XPower (2X), P67A-GD65(B2), P67A-GD65(B3), Z68A-GD80(B3), Z68A-GD80(G3) (3X), X79A-GD65(8D), & rounding it all out, X79 Big Bang XPower II. RAM of choice - Corsair. PSU of choice - Corsair. HDD's of choice - WD spinners. CPU cooler of choice - Zalman CNPS9900's. Graphics of choice - nVidia. Audio of choice - Creative PCI X-Fi Elite Pro or PCI-E X-Fi Champion. Optical burners of choice - Lite-On and LG. Platform of choice - Intel chipset based. Mainboard brand of choice - do you really have to wonder?
No RAID, No SSD's, No Windows 8 = No Problems!
Budje70
  • Winki
« Reply #5 on: 14-May-12, 09:01:47 »
>> Codes <<
So
0x55 Memory not installed
But when I remove the only present RAM module, I got a 22 error (and some beeps!)
I presume it indeed has something to do with the absence of memory:
0x2B Memory initialization.  Serial Presence Detect (SPD) data reading
0x2C Memory initialization.  Memory presence detection
0x2D Memory initialization.  Programming memory timing information
0x2E Memory initialization.  Configuring memory
0x2F Memory initialization (other).
So what's the difference between 55 and 22. I am confused  :cry:
Found another topic http://forum-en.msi.com/index.php?topic=158224.0
« Last Edit: 14-May-12, 09:10:18 by Budje70 »
MSI Z77A-GD65
i7-2600
Froggy Gremlin
  • Power Edition
  • Gamer's Series!
« Reply #6 on: 14-May-12, 10:32:07 »
Please post a more comprehensive component list and what you have tried so far in more detail. With power off, removed the PSU power cord, removed the battery for awhile, cleared CMOS and reset?
>> Posting Guide <<
Budje70
  • Winki
« Reply #7 on: 14-May-12, 11:01:42 »
Ok. The components I am using are described in my signature. NOTHING else.
With the Be-Quiet it's not booting anymore. (so the B2/B4 error is not interesting anymore)
With an old Chieftec PSU 360W the system IS booting, but is halting @ code 55. After a few seconds, it's restarting automatically.
Full history.
- Cold boot went ok. Installed Windows
- Restarting Windows, or a hard restart went wrong, code B2 or B4 (starting this thread!)
1. To be sure, I flashed the newest BIOS, and cleared the CMOS as described in the manual.
No difference.
2. To exclude memory problems, I tried other memory (Corsair 2 GB XMS3 CMX8GX3M4A1333C9)
From this time, the system boots no more.
Only the cpufan tries to start but immediate fails. The only LED what stays on is the Powerbutton on the motherboard itself.
3. Tried another memory (Kingston HyperX (KHX1600C903K2/8GX)
4. Tried resetting CMOS again.
5. Tried all combinations DDR1, DDR2 DDR3 DDR4
6. Got the original Corsair memory back in. Clear CMOS. This memory worked before!!!!
Nothing so far
7. Got an old Chieftec PSU360W
Now the system boots but is halting @ code 55.
I repeated all steps descibed before.
But the endresult stays the same, code 55.
This is the current status.
MSI Z77A-GD65
i7-2600
Budje70
  • Winki
« Reply #8 on: 14-May-12, 19:29:12 »
Just checked the MSI website, there is a memory compability file on http://www.msi.com/file/test_report/TR10_2536.pdf
And my 2 GB Corsair is on it ==> CMX8GX3M4A1333C9
So that rules out "buy a compatible RAM"  :nono:
MSI Z77A-GD65
i7-2600
Froggy Gremlin
  • Power Edition
  • Gamer's Series!
« Reply #9 on: 15-May-12, 00:17:24 »
From reading various posts in other threads, beginning to suspect the PSU's being used are not of adequate quality, amps or something. Recommend to test with a modern +12V single rail.
Budje70
  • Winki
« Reply #10 on: 15-May-12, 10:57:35 »
The used PSU is capable of 18A on a single 12V line. That's a lot more than really nesessary.
How can that be a problem?
Review with a core i7 965 extreme, FULL load (all 8 cores) and just 204 Watt consumption:
http://www.au-ja.de/review-be-quiet-pure-power-l7-9.phtml
Full load is a lot more then just booting the system...
No, it's defintely not the PSU
What I really don't understand is the fact that the "no more boot code 55" problem began after I changed the RAM to the Corsair 2 GB XMS3 CMX8GX3M4A1333C9 one from the compabilitytest.
After that I have a non booting motherboard with just code 55.
Tried everything.
It just makes no sense.
Even returning the system to the previous working hardwarestate didn't work. That's not cool.
« Last Edit: 15-May-12, 11:14:17 by Budje70 »
MSI Z77A-GD65
i7-2600
Budje70
  • Winki
« Reply #11 on: 16-May-12, 15:11:04 »
Switched motherboard, again code B4. So I thought, the ONLY component I haven't checked was the CPU.
Changed the i7-2600 (Pins were all okay, so were the imprents) for a i3-2100....and my problems are away  :biggthumbsup:
Well, my i7-2600 now apparently has a problem and I don't know why so suddenly.
But this problem is "solved".
MSI Z77A-GD65
i7-2600
Budje70
  • Winki
« Reply #12 on: 18-May-12, 16:03:21 »
After some tests...
The 2100 worked fine. No issues. But I was frustated. Called Intel, the gave me a tool to check the i7-2600.
All pass! Strange...
So I tried this time to DISABLE the Legacy USB.
And now the board boots fine. No more B2 or B4 error.
How is this possible?
Small problem - Okay now my USB mouse does not work anymore :bonk: seems logical
But that's no real problem since this a to become a server
« Last Edit: 18-May-12, 16:14:06 by Budje70 »
MSI Z77A-GD65
i7-2600
Froggy Gremlin
  • Power Edition
  • Gamer's Series!
« Reply #13 on: 19-May-12, 06:05:32 »
So I tried this time to DISABLE the Legacy USB. And now the board boots fine. No more B2 or B4 error. How is this possible?
As in the codes linked in Reply #4, B2 and B4 are USB related. With the Legacy USB disabled, it makes perfect sense it boots fine, as the offending USB device is not a problem any longer. Most likely the mouse used?
Budje70
  • Winki
« Reply #14 on: 20-May-12, 14:24:44 »
Doesn't make much sense because the 2100 cpu doesn't give me any errors at all.
It's sad to say but I think the i7-CPU is faulty.
Now I have another fault. Beside the fact that I cannot enable Legacy USB, I still sometimes get an A2 error (manual restart then necessary)
But the bigger problem now. When I try to install the supplied Intel VGA driver (from the MSI cd), the system hangs after tryling to load the logon screen. The only video-output that works is the BIOS....after that (Windows) no signal anymore.
Loosing my mind here.  :bonk:
Found related:
Problem with Intel graphics driver for i3-2100 on a DH67GD using HDMI
http://communities.intel.com/message/143304#143304
New i3 2100 can't load windows (fresh install) with latest intel GMA driver
http://communities.intel.com/thread/24018?start=0&tstart=0
--SOLVED--HD 3000 graphics fail - 3 dead mobos? - Are you an expert?
http://forums.anandtech.com/showthread.php?t=2172165
Loading Intel HD graphics driver causes Win 7 to hang in boot up.
http://communities.intel.com/message/145691#145691
« Last Edit: 20-May-12, 14:28:44 by Budje70 »
MSI Z77A-GD65
i7-2600
Bernhard
  • HydroGen
    • My Forum Home
« Reply #15 on: 20-May-12, 15:41:40 »
What screen connection are you using ? HDMI ? Have you tried with a standard VGA connection ?
Have you tried with another known working PSU ?
Have you eliminated all possibilities of a short somewhere by removing the board from the case and placing it on a non-conducting surface, i.e. unprinted cardboard or untreated piece of wood?
1. MSI H55M-ED55 WiFi; BIOS1.7; i3-540 ;Corsair 2 X 4GB CML8GX3M2A1600C9W; Corsair CX430;Bravia 32"; ST250GB Win7-64; WD2TB Data; LG DVD; Antec 200 case;
2.MSI Z77A-GD65;i7-3770K@4,5GHz;Noctua NH-C14; Win7-64; Corsair 4X4Gb CML16GX3M4A2133C11B; CorsairTX650;MSI N580GTX XE; ST1000GB;WD300V-R;SonyDVD; Open Test bench
3.Z77E-ITX media server;i3-3225;Corsair 2 X 4GB CML8GX3M2A1600C9;CorsairCX500;ST120 Win7-64; ST500 + ST1TB;LG DVD; CM Elite120 Advanced
"veni vidi voro doctus"
MSI 미친
Budje70
  • Winki
« Reply #16 on: 20-May-12, 17:46:58 »
Tried VGA and HDMI. Also tried booting without VGA or HDMI but the system still freezes (for example I can't start RDP session)
Tried three different PSU's, all the same.
Board is removed from the case and on a wooden table since then but also here no difference.
MSI Z77A-GD65
i7-2600
NovJoe
  • Hawk
« Reply #17 on: 24-May-12, 05:03:08 »
Now that with the i3 working fine with the USB devices, it does not give you the video output issue as well, right?
Do note that i3 processors have built in video processors in their chips so you will get to utilize the GPU only when it comes to intensive graphics processing.
If so, it does make sense to have Intel to replace your i7 processor.
Budje70
  • Winki
« Reply #18 on: 02-June-12, 12:23:51 »
Yes the i3 cpu did not gave any errors. So the i7 was very likely to be faulty and I did a RMA at Intel.
Good news:
This week I received the new i7 from Intel (VERY fast, just a few days)
All reset-problems now are gone, So no more strange USB problems or codes B2, B4, or A2  :agrees:  :biggthumbsup:
The VGA output after install Intel or MSI GMA driver still didn't work, so as a last resort I tried to select and install the *.inf file manually, from within the Device Manager. That worked!
MSI Z77A-GD65
i7-2600
NovJoe
  • Hawk
« Reply #19 on: 04-June-12, 06:21:08 »
Great! Glad to know that you have sorted it out now.
