Author Topic: BIOS update available for P67A-G43 but not P67A-G45  (Read 355 times)
guuuuuuuud
  • Neo
The latest BIOS update for my motherboard (P67A-G45) is version 1.D on MSI's website (msi.com/product/mb/P67A-G45--B3-.html#/?div=BIOS), but the latest update for the P67A-G43 is much newer (version 1.I) on MSI's website (msi.com/product/mb/P67A-G43--B3-.html#/?div=BIOS).
From downloading the P67A-G43 1.I update, it appears that the two motherboards use the same BIOS. Does this mean it is safe for me to flash the P67A-G43 BIOS to my P67A-G45 and if so, why hasn't the MSI website been updated?
Froggy Gremlin
  • Power Edition
  • Gamer's Series!
Re: BIOS update available for P67A-G43 but not P67A-G45
« Reply #1 on: 27-May-12, 21:28:41 »
Looks like the UEFI/BIOS's are not intended for both boards. Unless a new revision addresses a direct compatibility problem or feature that you have trouble with or need, a flash is not recommended at all.
Tested Z77A-GD80 with a 3770k
First MSI was an 845G-Max. Since then, 975X-PUE, P6N SLI Platinum, P7N Diamond, P45 Platinum (3X), X58 Pro, X58 Pro-E, X58 Eclipse Plus (2X), X58A-GD65, X58 Big Bang XPower (2X), P67A-GD65(B2), P67A-GD65(B3), Z68A-GD80(B3), Z68A-GD80(G3) (3X), X79A-GD65(8D), & rounding it all out, X79 Big Bang XPower II. RAM of choice - Corsair. PSU of choice - Corsair. HDD's of choice - WD spinners. CPU cooler of choice - Zalman CNPS9900's. Graphics of choice - nVidia. Audio of choice - Creative PCI X-Fi Elite Pro or PCI-E X-Fi Champion. Optical burners of choice - Lite-On and LG. Platform of choice - Intel chipset based. Mainboard brand of choice - do you really have to wonder?
No RAID, No SSD's, No Windows 8 = No Problems!
Ex Forum Mod
  • Hawk
« Reply #2 on: 27-May-12, 21:43:54 »
 If Jacks beta BIOS thread is any indication these MBs all use the same BIOS:
 P67A-C45/C43, P67S-C43, P67A-G45/G43
