Author Topic: Big bang marshal b3  (Read 357 times)
tvk1371
  • Neo
Big bang marshal b3
« on: 27-May-12, 21:37:19 »
Hello!
I have a little problem,i buy this mobo last week.And the problem is i dont know which memory modules can i use in 32GB kit in this mobo. :( Can I use corsair or g.skill 32 GB 1866 or 2133 kit? Does anybody have any experiance of this configuration?(*or kingston,corsair,g.skill 16GB 1866 kit is perfect to for me)
Sorry for the language im not english!
Please help!  :cry:
Froggy Gremlin
  • Power Edition
  • Online Online
  • Feed Me A Newbie Froggy, Feed Me!
Re: Big bang marshal b3 memory
« Reply #1 on: 27-May-12, 21:49:37 »
I have had excellent results with both Corsair 1866 'and' 2133 RAM kits. Having said that, all systems react differently, so results are never guaranteed. Since the CPU IMC only natively supports DDR3 1333, you may or may not be able to reach the 'rated' speed of the RAM.
Test: Z87 MPower Max v1.2B8, 4770k, Zalman 9900B-Max
First MSI was 845G-Max, since then, 975X-PUE, P6N SLI Platinum, P7N Diamond, P45 Platinum (3X), X58 Pro, X58 Pro-E, X58 Eclipse Plus (2X), X58A-GD65, X58 Big Bang XPower (2X), P67A-GD65(B2), P67A-GD65(B3), Z68A-GD80(B3), Z68A-GD80(G3) (3X), X79A-GD65(8D), & rounding it all out, X79 Big Bang XPower II. RAM of choice - Corsair. PSU of choice - Corsair. HDD's of choice - WD spinners. CPU cooler of choice - Zalman CNPS9900's. Graphics of choice - nVidia. Audio of choice - Creative PCI X-Fi Elite Pro or PCI-E X-Fi Champion. Optical burners of choice - Lite-On and LG. Platform of choice - Intel chipset based. Mainboard brand of choice - do you really have to wonder?
No Liquid, No RAID, No SSD's, No Windows 8 = No Problems!
tvk1371
  • Neo
Big bang marshal b3
« Reply #2 on: 28-May-12, 18:27:38 »
Hello!
I buy this motherboard last week and I have 3 questions about the big bang marshal motherboard!
1.:Can I use the 3770K in this motherboard or I should stay whit the 2700K?
2.:Can I use the HD7950/70 or GTX 680 vga card's in this motherboard?
3.:Can I use the g.skill  16GB ram (F3-17000CL9Q-16GBZH)  :confused2:
Please help  me guys!! :(
Bernhard
  • HydroGen
    • My Forum Home
« Reply #3 on: 28-May-12, 18:45:01 »
Topics merged. No need to start a new thread.
1. MSI H55M-ED55 WiFi; BIOS1.7; i3-540 ;Corsair 2 X 4GB CML8GX3M2A1600C9W; Corsair CX430;Bravia 32"; ST250GB Win7-64; WD2TB Data; LG DVD; Antec 200 case;
2.MSI Z77A-GD65;i7-3770K@4,5GHz;Noctua NH-C14; Win7-64; Corsair 4X4Gb CML16GX3M4A2133C11B; CorsairTX650;MSI N580GTX XE; ST1000GB;WD300V-R;SonyDVD; Open Test bench
3.Z77E-ITX media server;i3-3225;Corsair 2 X 4GB CML8GX3M2A1600C9;CorsairCX500;ST120 Win7-64; ST500 + ST1TB;LG DVD; CM Elite120 Advanced
"veni vidi voro doctus"
MSI 미친
tvk1371
  • Neo
« Reply #4 on: 28-May-12, 20:11:54 »
Hello!
Bernhard
  • HydroGen
    • My Forum Home
« Reply #5 on: 28-May-12, 22:25:30 »
1. It does not currently support the Ivy bridge CPUs, so stay with your 2700K. You can check with MSI technical if the board is destined to get an Ivy supported BIOS. >>How to contact MSI.<<
2. It will support any one of those cards as they are backwards compatible for PCI-E 2
3. I would recommend a DDR3-1600 or 1866 Corsair Vengeance kit as they have been proven to work on these boards. This is not to say that your kit won't work.
MSI 미친
