Hi all, i'm new here. I have a "little" problem with my z77a gd65... (bios V10.5)
i have set my bios for overclock my i5 2550k @ 4,5Ghz
in idle i have 1,304 volt, in full load 1,280/1,288 volt
this is normal? i don't think so...
This is my setting, thanks for any help !!
cpu base frequency - 1000
cup ratio - 45
Internal PLL overvoltage - Enabled
EIST - Enabled
Intel Turbo Boost - Enabled
Enhanced Turbo - Disabled
Dram Frequency - Auto
Extreme Memory profile (X.M.P) - Enabled
Spreed spectrum - Disabled
Vdroop offset Control - Auto
Digital compensation level - Higth
Cpu core ocp expander - Enhanced
cpu core engine speed - Auto
cpu voltage - 1,3250
Limit cpuid maximum - Disabled
Execute disable bit - Disabled
Intel virtualization tech - Disabled
Power technology - Custom
C1E Support - Enabled
Overspeed protection - Disabled
Intel C-state - Disabled
Long duration power limit - 255
Short duration power limit - 255
1-core ratio limit - 48
2-core ratio limit - 47
3-core ratio limit - 46
4-core ratio limit - 45
EuP 2013 - Enabled
cpu phase control - Auto
