Pages: [1] 2  All   Go Down
Author Topic: P67A-GD65 (B3 ) & Windows 7 64Bit Boot Issue  (Read 4177 times)
thegilpins
  • Easy OC
« on: 04-June-12, 13:08:21 »
I feel the need to revisit this old forum post as I do not believe it has been fully resolved:
http://forum-en.msi.com/index.php?topic=156082.0
In summary the issue is "Most times the machine boots and performs flawlessly for hours, but often it boots with the Windows-7 “need to repair” screen and after running repair for a while Windows says: “Windows cannot repair the problem”…….but when I press the Reset button, the PC boots and runs just fine".
I only had the problem since updating from 1F beta 2 to the latest BIOS version. On the original forum thread there are some that had the view that the issue was introduced around BIOS version 1.F (full release, non-beta) and 1.G. Just to confirm this issue NEVER happened for me on 1F beta 2 or earlier BIOS releases. The original forum also has some people saying the issue did not exist on earlier BIOS versions as well.
Most people seem to have solved the issue by either resetting the CMOS or loading default BIOS settings. I tried this and it did initially solve the problem for me.
BUT when I installed new drivers (such as nvidia v301.24) or added new hardware (e.g. Bigfoot PCIe network gaming card) the problem came back.
This implies to me that there is an issue with the BIOS and that resetting the CMOS is a workaround rather than a true fix.
This leaves me with two choices:
- use an older BIOS, which is ok but limits me from the new functionality in the BIOS (including not being able to use certain hardware that the BIOS updates support)
- resetting the CMOS after loading new drivers or installing new hardware and then configure my settings (which is very tedious)
Neither option is ideal to me.
The main purpose of raising this issue is to ask whether MSI Support know of this issue and have it on their bug list to fix?
I am concerned it is not being addressed as other forum entries talk about BIOS version 1.K3 being the last version.
My system details are P67-GD65(B3), Windows 7 64bit, 16GB Gskill 2133Mhz memory, 2 SSD, 2HDD, Nvidia 570 GTX, Bigfoot network gaming card.
« Last Edit: 04-June-12, 13:22:31 by thegilpins »
momosala
  • Platinum
Re: P67A-GD65 (B3 ) & Windows 7 64Bit Boot Issue
« Reply #1 on: 04-June-12, 14:51:23 »
I have the same problem, not solved by CMOS Clear.
MSI, thank you for the quality of this Forum
_______________________________________
Motherboard : MSI P67A-GD55 Rev B3
Processor : INTEL i7 2600K sandy bridge
Memory : CORSAIR 4 GB x 4 XMP 1600
NVidia GeForce GTX 570
OCZ Vertex 3, CRUCIAL M4, WD Caviar Black
SONY DVD/CD RW
MICROSOFT Windows 7 64 bits
momosala
  • Platinum
« Reply #2 on: 04-June-12, 16:29:31 »
On my PC, Intel management Engine wasn't installed.
I install it. Perhaps this will correct the problem.
SONY DVD/CD RW
thegilpins
  • Easy OC
« Reply #3 on: 04-June-12, 18:16:39 »
I have IME installed and it doesn't make a difference, does not solve the re-boot problem.
Froggy Gremlin
  • Power Edition
  • Online Online
  • Gamer's Series!
« Reply #4 on: 04-June-12, 20:55:28 »
Might try UEFI/BIOS version v1.H. If OC'ing, it may not be completely stable.
Unless users report to MSI Technical, the answer may be no. Also, they may also need to duplicate any problems to come up with a resolve. Please report any findings to MSI Technical;
>> How To Contact MSI <<
Tested Z77A-GD80 with a 3770k
First MSI was an 845G-Max. Since then, 975X-PUE, P6N SLI Platinum, P7N Diamond, P45 Platinum (3X), X58 Pro, X58 Pro-E, X58 Eclipse Plus (2X), X58A-GD65, X58 Big Bang XPower (2X), P67A-GD65(B2), P67A-GD65(B3), Z68A-GD80(B3), Z68A-GD80(G3) (3X), X79A-GD65(8D), & rounding it all out, X79 Big Bang XPower II. RAM of choice - Corsair. PSU of choice - Corsair. HDD's of choice - WD spinners. CPU cooler of choice - Zalman CNPS9900's. Graphics of choice - nVidia. Audio of choice - Creative PCI X-Fi Elite Pro or PCI-E X-Fi Champion. Optical burners of choice - Lite-On and LG. Platform of choice - Intel chipset based. Mainboard brand of choice - do you really have to wonder?
No RAID, No SSD's, No Win8 = No Problems!
thegilpins
  • Easy OC
« Reply #5 on: 05-June-12, 11:18:44 »
I will contact MSI and post any response that I get.
Thanks
jackal12
  • Afterburner
  • have a nice day
« Reply #6 on: 05-June-12, 20:52:31 »
i have this problem but only since i installed a ssd drive as boot drive ,it never happened with my hard drives , so my soltution is when it say it needs to repair i just sellect "boot windows normaly"  and it loads up fine
msi p67a-gd55-b3
intel i5-2500k cpu
crucial-m4-128gb sata3 and western digital 500gb sat3
asus 560 ti 1g  graffics card
creative sb xfi-go usb card
16 gig crucial xms3 1333mhz ram
1 lg22 sata dvd and 1 samsung tssw sh-s223b
>psu 850watt
windows 8 pro 64 bit
acer p225hq hdmi monitor
thegilpins
  • Easy OC
« Reply #7 on: 06-June-12, 19:58:10 »
Hi all,
MSI support suggested trying the latest BIOS 1K3. I am on 1K2, has anyone tried 1K3 and solved this issue?
Froggy Gremlin
  • Power Edition
  • Online Online
  • Gamer's Series!
« Reply #8 on: 06-June-12, 20:07:53 »
Here's the modded version;
>> Beta Mod <<
thegilpins
  • Easy OC
« Reply #9 on: 09-June-12, 13:38:51 »
I updated to the latest BIOS 1K3 as suggested by MSI Support and all good for a few days.
BUT once again after do firmware update to an SSD the double Windows reboot is back.
This issue still remains for me in the latest BIOS.
momosala
  • Platinum
SONY DVD/CD RW
momosala
  • Platinum
« Reply #11 on: 12-June-12, 10:30:38 »
No one tried 1.K3 modded2 bios ?
SONY DVD/CD RW
thegilpins
  • Easy OC
« Reply #12 on: 12-June-12, 21:10:20 »
Not yet but may try it at the weekend
thegilpins
  • Easy OC
« Reply #13 on: 17-June-12, 11:56:36 »
Hi, have now tried the new mod. The first few boots were ok. Did a cold boot today and got the double boot problem again.
Seems the latest bios (mod and official) still have this problem.
stevetski
  • Neo
« Reply #14 on: 17-June-12, 13:45:15 »
I have the same problem on my P67A-G45 with latest bios & Patriot Pyro SE 60gb SSD boot drive.
momosala
  • Platinum
« Reply #15 on: 17-June-12, 15:02:20 »
Thank you The gilpins for testing 1.K3 modded2 bios.
Many users have the same problem.
I pointed to the MSI customer service. No results.
Hope that a future bios will solve the problem
SONY DVD/CD RW
Zlip
  • Easy OC
« Reply #16 on: 18-June-12, 12:26:10 »
I myself is victim of this weird issue. Please do solve this issue.
Mutt
  • Winki
« Reply #17 on: 19-June-12, 19:51:58 »
After updating/installing your new hardware/software and restarting after each event, did windows restart normally on every instance?
Have you tried to disable the setting for automatic restart for system failures? Control Panel>System>Advanced System Settings>(System Properties) Advanced tab> Startup and Recovery, click settings button - in system failure: uncheck "automatically restart"
Have you had any BSODs and if so, have you checked your dump files for clues?
Have you tried CCCleaner...Registry scan? If you run the registry tool take notice of what it is fixing.
i5-2500k
Zalman CNPS9900A CPU Cooler
Z68A-GD80 (G3)
Corsair Vengeance CMZ8GX3M2A1600C9B (2X4GB)
XFX R7950 Black Edition, Double Dissipation, 900mhz, 3GB
Corsair Force GT 120 GB SATA 3
Corsair TX750 V2, 750w
Corsair Carbide 300R case
Lightscribe DVD+R/CD+RW
Microsoft Windows 7 Pro, 64 bit
thegilpins
  • Easy OC
« Reply #18 on: 19-June-12, 20:04:02 »
Thanks for your suggestions. Yes Windows has failed on restart of new hardware / firmware updates. The only way I get a boot every time is to disable errors via bcdedit. Not had any bsod's so no errors to look at. I have not used a registry tool since I have used an SSD.
This periodic boot problem only occurs on the newer versions of the BIOS. Under older versisons the problem was never seen.
thegilpins
  • Easy OC
« Reply #19 on: 19-June-12, 20:10:23 »
Have just got a response from MSI Support as follows "we have tested the problem many days,but we are very sorry,we tested the bios 1.F/1K3 with the hard disk and the OCZ SSD,the computer boot normally,of course,we installed the NVIDIA drivers and other drivers, but we can not find the problem. We have reflect to the relevant departments, if we can copy this problem, we will fix it in future bios. Sorry for any inconvenience caused. Best Regards, MSI Technical Support Team".
Whilst I am pleased they have tried to recreate the problem there is obviously differences between my and their PC builds and so this remains unsolved. I will go back and ask what the next steps are and repoprt back what I get.
So far I have counted about a dozen people that have responded to this thread or the original one but are there others out there that also have the problem? It would be good to go back to MSI Support with a long list of people affected, so if you are cvan you please say so on this forum topic. Thanks!
Mutt
  • Winki
« Reply #20 on: 19-June-12, 21:12:27 »
If after you made your upgrades and didn't get a clean restart you could have some corrupt files which could give you the repair message.
From Microsoft website: "Disable automatic restart on system failure
 Prevents Windows from automatically restarting if an error causes Windows to fail. Choose this option only if Windows is stuck in a loop where Windows fails, attempts to restart, and fails again repeatedly."
From what I've read about CCleaner, you can use it for cleaning up your system and registry, just not something you should do over and over again for an exteneded period of time. It is not advised to use any of the other options/tools.
Searching the net for a cure to my problem, seems this type problem is more widespread and not just confined to MSi products...but what do I know, just a dumb dog.
i5-2500k
Z68A-GD80 (G3)
jerrywall
  • Cyclone
  • Online Online
« Reply #21 on: 20-June-12, 09:49:51 »
I have had exactly this boot issue with Win7 64  and the P67A-C45 (B3) since the last two BIOS for my board. Didn't have it before. I have an Intel SSD 510 120 GB as boot disk. It started with the last but one BIOS and as the current BIOS 1.I came it became so rare that I at first thougt it had gone away. Now it shows up at perhaps only every 20 boot or so, cold or warm.
The latest thing I have changed is to disable the automatic reboot and stop forcing swap file to zero on the SSD. I now have set a 512 MB swapfile at the SSD and the rest is handled by Windows, in my case it puts the main part on a normal HDD.
I will get back if the problem seems to go away.
Am I right in thinking that this only affects SDD users?
MB: MSI Z77A-S01
CPU: i7 3770K, COOLER: Noctua C12P SE14
VGA: Asus HD7950 DCU2 3 GB, COOLER: Arctic Accelero Xtreme 7970
PSU: Corsair TX750 V2
HDD1: Intel 510 SSD 120 Gb
HDD2: WDC 2 TB WD20EARS
MEM: Corsair Vegeance LP 16 GB (CML16GX3M2A1600C10R) 8 GB X 2
momosala
  • Platinum
« Reply #22 on: 20-June-12, 12:26:08 »
I have the swap file and the temp directory on my SSD Vertex 3, and I have the boot issue with the last bios version.
I also think it's a bios problem with SSD.
SONY DVD/CD RW
some body
  • Afterburner
« Reply #23 on: 27-June-12, 04:54:17 »
Glad to see this issue revived.
I had originally posted that resetting the CMOS and manually reconfiguring appeared to work for me...
It took a while, but I've had the issue reappear again very sporadically.  I haven't tried another CMOS reset, but probably will.
I'm still running that last official Sandybridge 1.J0 bios - I haven't tried the 1.K betas or Modded version (altough I'm tempted to try the 1.K3 Modded) or the newer v.4.1 Ivy BIOS (looks like a one-way street if you go that route..I'll wait to see if current issues are resolved, etc.).
I don't have an SSD drive installed and experience this problem - I'm still inclined to think it relates to USB.
« Last Edit: 27-June-12, 04:56:56 by some body »
MSI P67A-GD53 (B3) w/ i5 2500K @ 4.3GHz, Corsair H50
MSI GTX 570 (N570GTX-M2D12D5/OC)
G.Skill F3-12800CL9D-8GBSR (4Gx2)
XFX Black Edition 850W
WD Blue WD6400AAKS 640GB SATA3
LG BH10LS30 BD-R
Antec 300
Logitech G15 (2nd gen) Keyboard + G500 Mouse
Win 7 Pro 64
Zlip
  • Easy OC
« Reply #24 on: 27-June-12, 16:49:21 »
I am on 1.19 aka 1.J UEFI version and still facing this issue myself also I am not on SSD rather on HDD. Please fix it with new BIOS Update.
Ex Forum Mod
  • Hawk
« Reply #25 on: 28-June-12, 01:02:56 »
 We users of this forum do not make nor have anything to do with BIOS updates. If you have a problem with the  BIOS for whatever reason then notify MSI HQ and give them a good description of your problem.
      >> How to contact MSI <<
Zlip
  • Easy OC
« Reply #26 on: 28-June-12, 08:22:43 »
Thanks a lot for your guidance, I posted two questions.. I am sure they will help me as much as they can. Thanks once again for your guidance. :agrees:
animefan
  • Neo
« Reply #27 on: 28-June-12, 23:19:24 »
I had this problem for many months. After I replaced my mouse (Logitech MX620 Cordless Laser Mouse) and my keyboard with the Logitech Cordless Desktop MX 5500 Revolution (and upgrading the bios to 4.0 and then to 4.1 - including IME 8) the problem went away. Upgrading to bios version 4.x was probably not required to fix the problem though.
I think it was the wireless mouse that caused the random boot failures.
jerrywall
  • Cyclone
  • Online Online
« Reply #28 on: 03-July-12, 18:06:59 »
I think I have found the culprit of the boot failure. Since it appears so early in the boot sequence it most likely is a low level I/O driver and I suspect the Renesas/NEC USB3 driver. I managed to find an update for the driver (2.1.36.0) released by another hardware company.
Renesas/NEC does not bother with end users and MSI does not bother with this problem as it is too complicated to pinpoint. Anyway, I installed the driver and have now booted more times than I ever did with the older driver (2.0.34.0) without boot errors.
The thing that convinced me was that I at one point had forgotten that sometimes a conflict shows up in that the same drive letter might be given to two different USB hard drives. In this case you will not see the drives in Windows until you reassign two different letters to each of the drives in the Disk Administration app. Anyways, I panicked and thought the newer driver had stopped working and I reinstalled the original MSI driver.
And, boom, right away the boot error at first reboot with the MSI USB3 driver! So back in with the newer version and no boot error. I will have to test a bit longer to be on the safe side. At first boot error now I will flash the ME8 BIOS!!
MB: MSI Z77A-S01
thegilpins
  • Easy OC
« Reply #29 on: 03-July-12, 19:47:30 »
jerrywall what version of the BIOS are you using?
jerrywall
  • Cyclone
  • Online Online
« Reply #30 on: 03-July-12, 20:04:14 »
I am still at the last ME7 BIOS for P67A-C45 (B3), 1.I. The error started two revisions back, before that I never had this problem with this board. I had other problems, like unable to overclock and with 1.H this got better. BTW loading optimized defaults and not overclocking will NOT make the boot problem go away.
Any problem now and I will flash 5.1 ME8 as some say the problem goes away with that version. Since I have a SandyBridge CPU I will try to avoid it.
« Last Edit: 03-July-12, 20:10:21 by jerrywall »
MB: MSI Z77A-S01
thegilpins
  • Easy OC
« Reply #31 on: 03-July-12, 21:40:29 »
Hi, I tried what you suggested with the latest USB driver and all worked ok for a few boots. I then installed Samsung Kies and the double boot is back. It seems on my system that certain dirver/firmware updates trigger the issue on the first boot after install and then it can be ok for a few days before the problem resurfaces. It may be that your re-install of the old USB driver caused the same issue as me rather than there being a problem with it. I have used new and old USB drivers on 1.F beta 2 bios without any issues, which is why I still think the root issue is a bios bug rather than a driver issue.
If you do flash to bios 4.1 and it works for you please post back to the forum.
jerrywall
  • Cyclone
  • Online Online
« Reply #32 on: 04-July-12, 13:43:16 »
The boot error came at last so I flashed the 5.1 BIOS for my p67a-c45 using the DOS method and the board went dead. Should have used the Windows method. Installed a new board Z77A-S01 and it works like a charm! The old p67-bord is sleeping in the city dump!  :sleep:
MB: MSI Z77A-S01
Froggy Gremlin
  • Power Edition
  • Online Online
  • Gamer's Series!
« Reply #33 on: 04-July-12, 18:23:41 »
Don't see how. The DOS method is more safe than Windows will ever be.
jerrywall
  • Cyclone
  • Online Online
« Reply #34 on: 04-July-12, 18:56:44 »
Well this is not true for me. I have made the earlier flashes with this mb from Windows and they all went well and this time I thought I should heed your warnings and the flash failed fatally. I spent several hours trying to bring it to life but there was no response whatever I did. I striped components and ran it in the free trying all kinds of bios revival tricks, amiboot.rom on USB stick and CD but nothing happened so I went to the shopping mall and bought me a new board instead.
Way back in the olden times there always was the simple trick to boot from floppy.
This is the first time since I got my first PC back in 1994 that a flash has gone bad on me.
MB: MSI Z77A-S01
Froggy Gremlin
  • Power Edition
  • Online Online
  • Gamer's Series!
« Reply #35 on: 04-July-12, 19:13:03 »
So basically, the flash failed attempting an Ivy update. It could have also possibly failed using the Windows method as well. Since this thread is about a P67A-GD65(B3), there is no point in going into details on the procedure of the failed flash for a P67A-C45. There are too many variances in the features and hardware of the two anyway. Having purchased a shiny new Z77A-S01 that is made for Ivy, your problems should be solved. :-))
« Last Edit: 04-July-12, 19:38:07 by Ex Forum User 2 »
jerrywall
  • Cyclone
  • Online Online
« Reply #36 on: 04-July-12, 20:48:16 »
Yes you are quite right there HU16E, it´s a bit unfair to blame the method. It's nice to have a new board, no regrets. And above all, no boot hickups!!  :)
MB: MSI Z77A-S01
Boldie007
  • Winki
« Reply #37 on: 04-July-12, 21:51:39 »
I have flashed my P67A-GD55 (B3) with 4.1 IB BIOS using the windows method and it has fixed this issue for me.
momosala
  • Platinum
« Reply #38 on: 04-July-12, 22:16:07 »
Please Boldie007,
Have you a Sandy Bridge (P67 ...) or an Ivy Bridge chipset.
I have a i7 2600K Processor and I have the 1.I I firmware for my P67A-GD55.
I dare not do the bios update to version 4.1 because some users of Sandy Bridge P67 chipset has had serious problems with it.
Thank you for your response.
SONY DVD/CD RW
Boldie007
  • Winki
« Reply #39 on: 04-July-12, 22:34:25 »
Sorry i5 2500K, given what I know now I wouldn't flash to IB BIOS if you want to OC a SB CPU, my system is no longer able to OC anywhere near as well as previously. If there was a way of putting it back to pre IB BIOS I would.......
momosala
  • Platinum
« Reply #40 on: 05-July-12, 16:55:20 »
Thank you for your response Boldie007.
However, I note that the 4.1 bios version solve the double boot problem of Win 7 64 bits.
Perhaps, MSI will use this data for future 1.X bios ?
SONY DVD/CD RW
momosala
  • Platinum
« Reply #41 on: 19-September-12, 16:29:15 »
The problem of incomplete boot followed by a reboot and windows repair menu is not yet solved for the P67A-GDXX motherboard.
Is anyone has solved it ? And How ?
SONY DVD/CD RW
_Melk_
  • Easy OC
« Reply #42 on: 25-September-12, 14:50:50 »
Not sure if this will help, but I myself having been a 1.14 BIOS user for 1+ year without any reboot problems, installed 1.19 a few days ago after purchasing a new Vertex 4 drive.   I've been trying to figure out why I had intermittent boot/repair issues and figured it was the Intel RST drivers I had newly installed (never used them before either on Vertex 1).
So after reading tons on Intel forums & here, I'm reverting back to 1.14 BIOS and NO Intel RST... let's hope it fixes it for me... I don't mind a bit less speed vs more reliability :)
MSI P67A-GD65 (B3) BIOS 1.19, Intel i7 2600k @ 4.0 GHz (1.200v), EVGA 580 GTX OC, 16GB Mem (Corsair Vengeance XMP 1600), 3.420TB SDDx2 (Vertex 4, Vertex 1), HDx3 (WDs), Corsair TX850W PSU, Logitech G510+G600/G5, BenQ G2400W, Windows 7 Ultimate 64 bit SP1, Windows 8 x64 Pro,  Avast! 8.x, SAS 5.x
momosala
  • Platinum
« Reply #43 on: 25-September-12, 16:19:54 »
Thank you _MELK_ for bringing us your experience.
 It was already reported that this bug did not appear with older firmware versions.
 It is interesting to know that version 1.14 does not have this bug.
 This information should help the MSI support team to create a 1.K reliable firmware.
In my opinion, I do not think that Intel RST is the cause of this bug.
SONY DVD/CD RW
_Melk_
  • Easy OC
« Reply #44 on: 04-March-13, 04:16:28 »
Sure thing momosala..
An update to this issue is as follow...
BIOS 1.14 fixed this issue completely. NO errors since I flashed back to it.   I also reinstalled Intel RST without any issue either.
Note that I wanted 1.19 for another reason as well (fix for USB 3.0 port issues).  I wound up flashing the chipset for the USB ports themselves instead  :biggthumbsup: .    Now the MB works as intended!  :D
WARNING: use the info below with CAUTION (not simple to do, and not provided/supported by MSI afaik)
INFO on USB 3.0 firmware/drivers -- again, use CAUTION and do your research before proceeding!
Note that it took me a few hours to complete the flash since I had to research which version of the chipset I had (hardware ID helped, LOTS of reading on the subject as well to find out HOW to flash my board properly).
You can find the drivers/firmware for the "Renesa USB 3.0 Host controller" by searching google for
Driver: Renesas/Nec Usb 3.0 Version 3.0.23.0/2.1.39.0 WHQL.
I used the 2.1.39.0 drivers -- you'll find the firmware at the same place and an explanation on how to flash the chipset we have on the P67A-GD65 (which has TWO identical chips to flash).  The new firmware updater doesn't work on those, so you need to download an older firmware to use the older DOS program to flash with the newer .MEM files.
« Last Edit: 04-March-13, 04:19:54 by _Melk_ »
momosala
  • Platinum
« Reply #45 on: 04-March-13, 11:43:54 »
Thank you _Melk_
1.14 bios + flashing USB 3 ports firmware in DOS solve the problem.
This is interesting.
My USB 3 ports are already flashed with the last version.
My bios is modded 1.K5.
Do you think that If I return to 1.14 bios, the boot problem will be solved ?
SONY DVD/CD RW
_Melk_
  • Easy OC
« Reply #46 on: 04-March-13, 12:14:34 »
My pleasure momosala.
Note about USB 3 flash.   It was NOT related to my boot problem at all so it's not required for this thread issue.
As for 1.14, after looking at the MSI website, your board (P67A-GD55) seems to be using the same BIOS as my board (P67A-GD65) so it *might* resolve your issue indeed.
I'm not sure about 1.K5 though since after looking at the MSI website, the bios numbers went from 1.19 (1.J) to 4.x ( are those 1.K bios?).   I never installed one of those since I read that they're used mostly if you have a .22m Ivy CPU (I don't).
If you are comfortable with flashing BIOS (as you seem to be), I'd certainly give it a try if this boot issue gets on your nerve... it sure did for me!  Also, 1.19 didn't bring anything new to my setup that I was able to notice, so I'm perfectly happy with 1.14.  Everything works and is OC (Memory XMP, CPU but only to 4.0-4.3Ghz, GPU)
Good luck friend.   I really hope you get to fix this as I did.   Also hope MSI reads this.  I reported it once (ticket) when I realized that 1.19 caused Boot issues, but the more that report this, the better -- Specially since it seems the issue still exists for many.
_Melk_
P.S. The **only** weird issue I noticed with BIOS 1.14, a long time ago (too lazy to retry now), is that XMP NEEDS to be activated in BIOS for my memory.   If it's not, sometimes I'd get boot errors -- so XMP is required for my Vengeance Memory (8GB or 16GB) -- with it activated, NO Errors in the last 2 years :)
edit: typos
« Last Edit: 04-March-13, 12:24:49 by _Melk_ »
momosala
  • Platinum
« Reply #47 on: 04-March-13, 15:19:21 »
_Melk_
1.K bios is a beta bios after official 1.J bios.
Like you, I do not use the 4.X bios because I have a sandy bridge processor. I tried it but OC didn't work well.
I'll try 1.E bios like you because the boot loop problem is always here.
I'll give the feed back in this thread.
Again, thank you.
SONY DVD/CD RW
thegilpins
  • Easy OC
« Reply #48 on: 05-March-13, 20:48:18 »
Melk, are you able to provide detailed instructions on how to flash the USB3 chips via DOS? Thanks
xmad
  • Salisbury MD
« Reply #49 on: 05-March-13, 20:49:21 »
You can do this from windows using the batch files I included.
Look here: >>Beta BIOSes<<
Otherwise, you need to type the syntax that you see in the screen shots from dos.
Edit: Look at the bottom NEC/ Reaneses Firmware
New:
Board MSI Z77 Mpower
Bios: Latest Official
VGA   MSI GTX 560 PE OC
PSU:  Corsair GS700
Intel Core I7-2700K
MEM: Corsair 2133 2x4gb CL: 9 Dominator Platinum
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Board: Big Bang X-Power II
CPU: Intel 3930k Hexa-Core
Ram: Corsair Dominator Platinum 4x4gb 2133 CL:9
Vid: GTX 680 Lightning
PSU: Corsair AX1200I
Cooler: Zalman 9900 Max-B
SSD: Intel 520 120GB (OS); Intel 520 60GB (Cache)
HDD: 2x Seagate 1tb 7200 in Raid 0
OS: Win 8 Pro in UEFI mode
Pages: [1] 2  All   Go Up
