Win a Z87-GD65 GAMING motherboard with the MSI Forum Wallpaper Design Contest
Author Topic: G41M-P28, Temp2 Overheating  (Read 358 times)
Tarouka
  • Neo
« on: 05-June-12, 05:56:13 »
I have bought an MSI G41M-P28 motherboard to create a mini-computer which was supposed to be mostly used for video encoding. I installed Fedora Core 15 on it, then avidemux to proceed with the video encoding. However, the computer would hang at times. I suspected an overheating, but I thought if the CPU overheat the computer would actually restart instead of just hanging for a few seconds. I quickly installed lm-sensors, and what did I noticed? After running avidemux for a while and monitoring lm-sensors, I noticed the second sensor sitting at 58~64C, and its crit being at 64. So it would basically go up to 64, halt the CPU until it reached 58, and do that over and over again. I installed Windows Server 2008 for more accurate testing, as linux was a brand new thing for me. SpeedFan reports the same thing, under Temp2. I've tested and it also happens with Prime95, so avidemux isn't the culprit. I also put the computer outside its case, to ensure it isn't related to that, but it failed running Prime95 without halting. So what/where is the Temp2 sensor exactly on that motherboard?
TL;DR:
I have a sensor on my motherboard labeled as Temp2 on SpeedFan that keeps "overheating". Where is that sensor exactly?
EDIT: Oops, forgot the specs somehow...  :undecided:
Tested with Fedora Core 15, Windows Server 2008 (SpeedFan, CPUID HWM, CoreTemp, lm-sensors)
Corsair 2x4GB KVR1066D3N7K2
Rosewill 350W PSU
MSI G41M-P28 Motherboard
SAMSUNG HD204UI 2TB Hard Drive
Core 2 Quad Q9550 Stock Speeds
CNPS8900 EXTREME Zalman CPU Cooler
« Last Edit: 05-June-12, 06:09:55 by Tarouka »
caffeine_storm
  • Neo
Re: G41M-P28, Temp2 Overheating
« Reply #1 on: 03-July-12, 16:55:29 »
I was experiencing what seems like the same issue.
As far as I could tell, it seemed like some piece of the mobo was overheating and tripping a failsafe
(at what seems like a too low a threshold). In my attempts to change this threshold I was using
the MSI Overclocking Center to try and mess with the 'System Temp Threshold' but none of the tweaking
seemed to take hold. In that program there was a 'System' readout (iirc) that was fluctuating between
similar temps with the slow-down you experienced.
My fix (as ghetto as it sounds, it worked) was to take off the back panel of my case and blast a fan
(of the oscillating room-fan variety) onto the front of the mobo; it keeps the temp down below that threshold
of pain and I can play games again.
HTH and if you have a better (a.k.a. real) solution, I'd love to hear it.
Cheers
