Pages: 1 [2]  All   Go Down
Author Topic: Hello friends, RAM problem here.  (Read 2884 times)
HideLater
  • Easy OC
Re: Hello friends, RAM problem here.
« Reply #50 on: 23-June-12, 02:16:37 »
answer? qq
xmad
  • Salisbury MD
« Reply #51 on: 23-June-12, 03:19:21 »
It says that 16 gig are installed and that is correct, the 12 usable probably means you are currently using 4gig. If everything is working don't worry.
Did you get your temperature problem solved?
New:
Board MSI Z77 Mpower
Bios: Latest Official
VGA   MSI GTX 560 PE OC
PSU:  Corsair GS700
Intel Core I7-2700K
MEM: Corsair 2133 2x4gb CL: 9 Dominator Platinum
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Board: Big Bang X-Power II
CPU: Intel 3930k Hexa-Core
Ram: Corsair Dominator Platinum 4x4gb 2133 CL:9
Vid: GTX 680 Lightning
PSU: Corsair AX1200I
Cooler: Zalman 9900 Max-B
SSD: Intel 520 120GB (OS); Intel 520 60GB (Cache)
HDD: 2x Seagate 1tb 7200 in Raid 0
OS: Win 8 Pro in UEFI mode
HideLater
  • Easy OC
« Reply #52 on: 23-June-12, 03:59:08 »
Ok, I decided to just ignore it, and I'm about to get uh.. thermal compound.  I'm gonna clean off the thermal compound on my processor in a bit and reapply.
badboy2k
  • Online Online
« Reply #53 on: 23-June-12, 20:12:02 »
good! your current cooler more then likely was miss installed and has a poor contact between the heatsync base and cpu! its ment to be nice and level as it goes on and that should work much better as it will give a clean contact!
Cooler: corsair H100 cooler
HideLater
  • Easy OC
« Reply #54 on: 24-June-12, 11:54:04 »
Haha yeah thanks
The temperature went down to around 30 degrees celsius, the lag stopped, and no more shutting down.
I'm satisfied with my MSI computer as well, somewhat.
The only problem is that it still generates some lag in combat arms...
It skips frames pretty often... and crashes a lot.
Any idea about it? I'm gonna go look back on some of your previous responses and see what I can do.
« Last Edit: 24-June-12, 11:58:45 by HideLater »
badboy2k
  • Online Online
« Reply #55 on: 24-June-12, 17:19:29 »
see my advice why your computer was crashing was correct that you had a poor thermal conatct on the cpu!
ok what graphics card are you using? as its more then likely going to be one of 3 things!
either the card doesnt have enougth ram to work as a frame buffer
or the gpu itself isnt fast enougth
possibly outdated graphics drivers (download the latest ones for your card)
if its a slow GPU or not enougth graphics ram the only thing you can do is lower the graphics settings or resolution in game and see if it improves.
HideLater
  • Easy OC
« Reply #56 on: 24-June-12, 21:51:19 »
Just to make sure that you know... I have two computers.  The one with the heating problem was the GIGABYTE one, and now the one with the Combat Arms problem is the MSI one.
I have 16GB of RAM installed in the MSI one along with a 1GB ATI Radeon HD 5750 which is DDR5.
The drivers for that Graphics Card are from the CD that it came with.
Another note: The GIGABYTE computer has 6GB of RAM with a 2GB DDR Pny GPU and it has no lag whatsoever.
I already tested out both cards and have determined that the ATI runs faster.
« Last Edit: 24-June-12, 21:56:05 by HideLater »
Bernhard
  • HydroGen
    • My Forum Home
« Reply #57 on: 24-June-12, 21:57:44 »
>>Please read and comply with the Forum Rules.<<
If you are here to get support for your MSI products, then you are very welcome.
The other product is not open for discussion and is best addressed in a general forum or on the Gigabyte forum.
1. MSI H55M-ED55 WiFi; BIOS1.7; i3-540 ;Corsair 2 X 4GB CML8GX3M2A1600C9W; Corsair CX430;Bravia 32"; ST250GB Win7-64; WD2TB Data; LG DVD; Antec 200 case;
2.MSI Z77A-GD65;i7-3770K@4,5GHz;Noctua NH-C14; Win7-64; Corsair 4X4Gb CML16GX3M4A2133C11B; CorsairTX650;MSI N580GTX XE; ST1000GB;WD300V-R;SonyDVD; Open Test bench
3.Z77E-ITX media server;i3-3225;Corsair 2 X 4GB CML8GX3M2A1600C9;CorsairCX500;ST120 Win7-64; ST500 + ST1TB;LG DVD; CM Elite120 Advanced
"veni vidi voro doctus"
MSI 미친
badboy2k
  • Online Online
« Reply #58 on: 24-June-12, 21:58:05 »
get the ones off AMD not off the cd!
they will be very old drivers indeed on the supplied cd (6 months minimum age)!
download catylist 12.3 as that is more stable then 12.4 it will be in the older drivers section!
HideLater
  • Easy OC
« Reply #59 on: 25-June-12, 03:44:41 »
Cool thanks.
I'll install it straight from the site.
And for one of you previous answers, you told me to download CPU-Z and compare the timings to the ones on the box.  I couldn't find it on the box, but there was an installation guide.  In it where it says "DRAM Timing Control", the only numbers given to me are from the last sentence which is:
"So 5-5-5-15 settings will translate to the following: tCL=2     tRCD=3     tRP=2     tRAS=5"
Should I change the timings accordingly?
HideLater
  • Easy OC
« Reply #60 on: 29-June-12, 08:40:37 »
I was messing around with the ram settings, and now the monitor stays blank when I turn the computer on. I turned the computer on and off several times... yet it still does not show.
How do I fix that?
Bernhard
  • HydroGen
    • My Forum Home
« Reply #61 on: 29-June-12, 08:43:26 »
Do a full CMOS clear. >>Clear CMOS Guide<<
MSI 미친
HideLater
  • Easy OC
« Reply #62 on: 29-June-12, 08:55:50 »
Cool thanks.
And for manually adjusting timings for my RAM which numbers do I refer to?
5-5-5-15 or
tcl=2
trcd=3
trp=2
tras=5
Bernhard
  • HydroGen
    • My Forum Home
« Reply #63 on: 29-June-12, 09:04:46 »
Your CPU-Z SPD profiles will guide you which timings you need to address if your timings are not automatically set correctly.
Maybe you can post the SPD and memory tabs of CPU-Z
MSI 미친
HideLater
  • Easy OC
« Reply #64 on: 29-June-12, 09:11:37 »
I'll do that in just a bit, hold on.
I can't quite find the correct timings to put in since my RAM came in a 4x4 kit.  PC3-12800 and 1600mhz, the ones I've come across while trying to google it are 10666 12800 that are 2GB versions.
HideLater
  • Easy OC
« Reply #65 on: 29-June-12, 09:14:29 »
Oh! I think I've found it to be 9-9-9-24.. but I'm booting up my computer and I will post the CPU-Z readings before I start messing with the settings again.
HideLater
  • Easy OC
« Reply #66 on: 29-June-12, 09:28:20 »
Do I need to change anything, or is it fine?
« Last Edit: 29-June-12, 09:34:44 by HideLater »
Froggy Gremlin
  • Power Edition
  • Gamer's Series!
« Reply #67 on: 29-June-12, 09:40:46 »
I would recommend to change CL from 7 to 9, and tRAS from 25 to 24 and call it good. :-))
Tested Z77A-GD80 with a 3770k
First MSI was an 845G-Max. Since then, 975X-PUE, P6N SLI Platinum, P7N Diamond, P45 Platinum (3X), X58 Pro, X58 Pro-E, X58 Eclipse Plus (2X), X58A-GD65, X58 Big Bang XPower (2X), P67A-GD65(B2), P67A-GD65(B3), Z68A-GD80(B3), Z68A-GD80(G3) (3X), X79A-GD65(8D), & rounding it all out, X79 Big Bang XPower II. RAM of choice - Corsair. PSU of choice - Corsair. HDD's of choice - WD spinners. CPU cooler of choice - Zalman CNPS9900's. Graphics of choice - nVidia. Audio of choice - Creative PCI X-Fi Elite Pro or PCI-E X-Fi Champion. Optical burners of choice - Lite-On and LG. Platform of choice - Intel chipset based. Mainboard brand of choice - do you really have to wonder?
No RAID, No SSD's, No Win8 = No Problems!
HideLater
  • Easy OC
« Reply #68 on: 29-June-12, 09:43:19 »
To do that in the BIOS, I would change the column that says "auto" to "7t" and "24t" correct?
Froggy Gremlin
  • Power Edition
  • Gamer's Series!
« Reply #69 on: 29-June-12, 09:50:03 »
The 'Auto' setting changed to 9 and the other to 24, yes.
HideLater
  • Easy OC
« Reply #70 on: 29-June-12, 09:52:01 »
Oh yeah I meant 9, thanks.
Pages: 1 [2]  All   Go Up
