Author Topic: Request: MSI GT60 Unlocked/Custom BIOS  (Read 1543 times)
squishface
  • Winki
« on: 17-June-12, 17:34:29 »
Hi Svet, hoping you can help me or at least let me know if it's possible. I am trying to run a RAID 0 on Solid States and I'm having an issue with the controller picking up both drives at 6Gb/s, anything a custom BIOS would fix?
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
Re: Request: MSI GT60 Unlocked/Custom BIOS
« Reply #1 on: 17-June-12, 17:51:52 »
can't tell, but i can unlock the BIOS with wanted options, so you can have a try.
squishface
  • Winki
« Reply #2 on: 17-June-12, 18:40:41 »
Let me do some more independent testing with the drives to ensure I don't have a botched drive. If I can't make any headway I will most likely donate and give the custom BIOS route a try.
  • Administrator
« Reply #3 on: 17-June-12, 18:41:35 »
oks
squishface
  • Winki
« Reply #4 on: 17-June-12, 20:05:55 »
Donation made, let me know when it's complete  ;D
  • Administrator
« Reply #5 on: 17-June-12, 20:09:29 »
Received it, your current BIOS version installed is.. 1.xx or 3.xx?
squishface
  • Winki
« Reply #6 on: 17-June-12, 20:14:46 »
BIOS version E16F3IMS.308
EC Version 16F3WMS1 Ver 4.03
  • Administrator
« Reply #7 on: 17-June-12, 20:17:48 »
Ok, works in progress.
Will e-mail you when its done
  • Administrator
« Reply #8 on: 17-June-12, 20:18:33 »
squishface
  • Winki
« Reply #9 on: 17-June-12, 20:43:38 »
Sorry I also meant to request the Fn/Windows key swap a previous user had requested as well.
  • Administrator
« Reply #10 on: 17-June-12, 20:45:49 »
okey, don't flash anything in such case.
will do this as well and will reply when its done
squishface
  • Winki
« Reply #11 on: 17-June-12, 20:47:56 »
Darn it just completed the flash to 4.06, scratch the request for the key swap
  • Administrator
« Reply #12 on: 17-June-12, 20:51:43 »
Ok, np. My last telling to do not flash anything in such case, was to avoid double re-flashing.
But it wont matter, we will still do the wanted stuff just one extra reflashing will be done.
squishface
  • Winki
« Reply #13 on: 17-June-12, 20:53:39 »
Sounds good, you're freakin awesome svet!
  • Administrator
« Reply #14 on: 17-June-12, 21:33:14 »
You mean Left control with the Fn or Windows key?:
http://media.msi.com/main.php?g2_view=core.DownloadItem&g2_itemId=75458&g2_serialNumber=1
Cause if its windows key like you said, its some strange swap, have a clarify.
squishface
  • Winki
« Reply #15 on: 17-June-12, 21:34:52 »
I want to make the Function key on the left side the windows key and the windows key on the right side the function button.
  • Administrator
« Reply #16 on: 17-June-12, 21:38:54 »
Oki, check attached image. I've draw it, please confirm that you wanted this change:
[click to enlarge]
squishface
  • Winki
« Reply #17 on: 17-June-12, 21:39:47 »
Exactly :-)
  • Administrator
« Reply #18 on: 17-June-12, 21:42:19 »
oks, work in progress :svet:
EDIT:
Check PM
« Last Edit: 17-June-12, 22:31:59 by Svet »
squishface
  • Winki
« Reply #19 on: 18-June-12, 00:53:45 »
Got the custom BIOS in place but doesn't seem to have any feature to force the other drive to be detected at 6Gb/s. I think it's a limitation of the ports on the main board. It seems Port 0 and 1 are 6Gb/s while the remaining four sata ports are 3Gb/s. Is there any way to swap those ports or is that restricted to hardware?
  • Administrator
« Reply #20 on: 18-June-12, 00:59:04 »
There is a option to force the Sata gen speed, but dunno for which ports is related.
this looks like 2 of the ports are controlled by one controller, while remaining 4 by different with lower sata gen capability.
[if that's the case, its hardware limitation]
squishface
  • Winki
« Reply #21 on: 18-June-12, 01:00:26 »
Yea that's what I'm assuming, I do have it forced to Gen3 so for whatever reason Port 1 is the only 6Gb/s port available to the HDD bays. I wish I would've known that before purchasing two SSD's thinking I would get full 6Gb/s performance.
  • Administrator
« Reply #22 on: 18-June-12, 01:06:42 »
isn't it possible to connect them at gen3 ports?
also i doubt that there is any or its very minimal difference between gen2 and gen3 in speed.
its like theoretic speed, etc even connected to gen 3 ports the will not run at  6Gb/s speed,
but down to the SSD's speed itself, which i think gen2 bandwidth should enough not to slow down them
If possible to test, connect one of the SSD drive on gen2 speed and test his performance.
then connect it to gen3 port and retest, then compare their transfer rate.
squishface
  • Winki
« Reply #23 on: 18-June-12, 01:13:40 »
The laptop board uses special adapters for the SATA connection to the drive, it would likely require me tearing the whole machine apart to locate Port 0. Even after locating it I would have to rig a custom wire from Port 0 to the correct location in the chassis which I'm not very interested in doing. I test @ 525MB/s read speeds currently but know with full 6Gb/s that number should be double in RAID0
« Last Edit: 18-June-12, 01:16:33 by squishface »
  • Administrator
« Reply #24 on: 18-June-12, 01:17:04 »
aha..
the keys are working like wished?
squishface
  • Winki
« Reply #25 on: 18-June-12, 01:18:38 »
Yes, that seems to be working great. Thanks again for the custom BIOS :-)
  • Administrator
« Reply #26 on: 18-June-12, 01:20:19 »
you're welcome :hat tip:
