Author Topic: Z68s-g43 impossible to update bios 5.0  (Read 759 times)
lolobibop
  • Neo
« on: 12-July-12, 20:04:03 »
I want to use an ivy bdrige, so i need to update my bios.
So i take this package : http://w ww.msi.com/product/mb/Z68S-G43--G3-.html#/?div=BIOS
I'm running Windows 7 64 Bit. When I try to run the executable (afude238.exe) I get this message:
"The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then content the software publisher."
-> So i try to flash with m-flash in bios : it find my usb key but any bios file ...
--> Ok. So i go to msihq usb bootable. I have read the guide. But after reboot, the bios always fail. It say that the file ID do not correspond to my MB.
So help me or just update this f*ckin package with the good file !!
Thank you.
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
Re: Z68s-g43 impossible to update bios 5.0
« Reply #1 on: 12-July-12, 20:42:42 »
what's your current bios version and what version you are trying to install?
lolobibop
  • Neo
« Reply #2 on: 12-July-12, 21:03:20 »
Current version is : 4.1
Version i try to install : 5.0
The only version purpose by live update : 4.3
  • Administrator
« Reply #3 on: 12-July-12, 21:06:51 »
lolobibop
  • Neo
« Reply #4 on: 12-July-12, 21:39:36 »
I've read the MSI's sop but
In the package : AFUDE238.exe and E7750IMS
I can't lunch AFUDE238 : "The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then content the software publisher."
I have just update to 4.3 with MSIHQ -> flash ok.
I have retry to flash the 5.0 with MSIHQ -> the same error during the flash : "Rom file ROMID is not compatible with existing bios".
So i think there is a problem with the bios package 5.0.
I have try to lunch AFUDE238 since the recovery console of windows : no succes, can't open the file.
Froggy Gremlin
  • Power Edition
  • Gamer's Series!
« Reply #5 on: 12-July-12, 22:03:34 »
I take it you are trying to udpate in Windows? :nono: Read further into the SOP at around Page 15 and use the DOS method. First, you will have to make a USB stick bootable. You can't use the forum's USB flasher or it's key for the Ivy update.
This is what the file (example) should look like that you put on the bootable USB stick;
Boot to DOS, type the file name exactly as it is written, press the keyboard Enter key and let it do it's thing. DO NOT RETRACT THE USB STICK EARLY!
Tested Z77A-GD80 with a 3770k
First MSI was an 845G-Max. Since then, 975X-PUE, P6N SLI Platinum, P7N Diamond, P45 Platinum (3X), X58 Pro, X58 Pro-E, X58 Eclipse Plus (2X), X58A-GD65, X58 Big Bang XPower (2X), P67A-GD65(B2), P67A-GD65(B3), Z68A-GD80(B3), Z68A-GD80(G3) (3X), X79A-GD65(8D), & rounding it all out, X79 Big Bang XPower II. RAM of choice - Corsair. PSU of choice - Corsair. HDD's of choice - WD spinners. CPU cooler of choice - Zalman CNPS9900's. Graphics of choice - nVidia. Audio of choice - Creative PCI X-Fi Elite Pro or PCI-E X-Fi Champion. Optical burners of choice - Lite-On and LG. Platform of choice - Intel chipset based. Mainboard brand of choice - do you really have to wonder?
No RAID, No SSD's, No Win8 = No Problems!
  • Administrator
« Reply #6 on: 12-July-12, 22:06:03 »
let me check and will reply when its done, don't try anything in meantime
  • Administrator
« Reply #7 on: 12-July-12, 22:17:54 »
Ok, its MSI's error, msi will be noticed to update the BIOS archive as they upload the wrong stuffs. So be patient and wait some time.
lolobibop
  • Neo
« Reply #8 on: 12-July-12, 22:19:40 »
Ok thank you man.
There is the same problem on Z68A-G43 (G3) archive ;)
  • Administrator
« Reply #9 on: 12-July-12, 22:25:50 »
Ok thank you man.
Thanks, notice them about that one too, which seems to use the same BIOS archive.
  • Administrator
« Reply #10 on: 13-July-12, 21:07:28 »
ok the issue is now fixed, you can follow the MSI's sop to update to the 5.0 IV BIOS & ME8.
