Author Topic: Z77A GD65 - Error "d7"  (Read 482 times)
Le_Frog
  • Neo
« on: 03-August-12, 15:46:59 »
Hello
     I have MB MSI Z77A GD65 with Intel 2500K. It worked fine, but I was on vacation for one week and after my return, it dont want to boot. (During vacation, I turned off my PSU and unplugged electric cable from wall.)
After I push power on button, monitor signs no signal and MB stuck with code "d7". After it, I need to push power button for 5sec and it shut off. It will eventually boot up on third - fifth attemp everytime. I tried to unplug everything from board, leaved only PSU, CPU and one ram module, but still same result, it will boot 1 time from 5 attempts (average). Is it clearly for RMA or what should I try?
Thank You for any suggestions.
Board: MSI Z77A-GD65
Bios: Version 10.5
VGA:   Gigabyte 580GTX SOC
PSU:   Corsair HX650 (52a 12v rail)
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W
MEM: Kingston 16GB KIT DDR3 1333MHz CL9 (KVR1333D3N9K4/16G)
HDD: Intel 520 256gb SSD
COOLER: Noctua NH-D14
OC: CPU at 3.8Ghz Stock voltage, only multiplier raised to 38x.
OS: Windows 7 64bit Professional
  • T9246ED, Бивша комета
  • Administrator
  • Online Online
    • MSI BIOS/EC-FW Mods
Re: Z77A GD65 - Error "d7"
« Reply #1 on: 03-August-12, 15:55:41 »
0xD7  No Console Input Devices are found
have you tried to >>Clear CMOS Guide<< with power cord removed?
and to try to boot again with just one memory stick, but to use your second memory stick instead alone?
Le_Frog
  • Neo
« Reply #2 on: 03-August-12, 16:07:56 »
I tried to clear it, but i will try it again according to that manual to ensure it is completely clear. Yes, I tried three modules as one.
What exactly means that error, that no keyboard found?
I have Logitech K350 keyboard through Unified receiver (wireless) and wired Logitech G5 mouse.
  • Administrator
  • Online Online
« Reply #3 on: 03-August-12, 16:11:10 »
not sure
you can try with regular PS2 keyb.
make sure that power cord is removed from the PSU before proceed, else its done nothing
Le_Frog
  • Neo
« Reply #4 on: 05-August-12, 18:59:55 »
So, I cleared Cmos, after first attempt it shows debug "dE" and freeze, after second attempt I was able to switch to second bios and boot, I reflashed bios and it seems it works correctly. So it seems to be damaged bios.
Thanks for help. Btw, when can I get full debug code list for this board?
  • Administrator
  • Online Online
Le_Frog
  • Neo
« Reply #6 on: 05-August-12, 19:06:20 »
Thanks one more time, man.
