Author Topic: drivers for MS-1671  (Read 1802 times)
ivana
  • Neo
drivers for MS-1671
« on: 26-August-12, 12:30:02 »
Hi, please j need some help. Where j  can find all drivers for MS-1671, OP is XP? Thanks in advance.
  • Lightning!
    • event.msi.com/vga/lightning/
Re: drivers for MS-1671
« Reply #1 on: 26-August-12, 13:34:37 »
On the MSI site MS-1671 shows up as EX630 notebook. This is meant for Windows Vista or 7:  http://www.msi.com/product/nb/EX630.html#/?div=Driver&os=All
There are no XP drivers so you won't find any
MSI Z87 MPOWER MAX (MS-7815) Bios 1.7B4
Core i7 4770K (C0) @ 4300.54 MHz, 1.216V
2*4GB ADATA AX3U2000GC4G9B-2G (1:8) 1066.8 MHz (DDR3-2133) @ 10-11-11-28-2T 1.54v
2*MSI GTX 780Ti GAMING 3G @ 1210/3500 (SLI)
256GB Samsung 830 SSD + 250GB Samsung 840 EVO
Corsair HX1050 +12V: 87.5A • +3.3V: 30A • +5V: 30A
Windows 8.1 Pro
ivana
  • Neo
« Reply #2 on: 26-August-12, 13:51:56 »
 flobelix, thank you a lot :)
  • Lightning!
« Reply #3 on: 26-August-12, 14:01:09 »
 :hat tip:
Windows 8.1 Pro
ivana
  • Neo
« Reply #4 on: 11-September-12, 15:06:25 »
Sorry, j need help again. Everything is installed now, except microphone. Where j can find drivers? Windows 7, 64 bit. Thanks in advance,
  • Lightning!
« Reply #5 on: 11-September-12, 17:50:53 »
Windows should find automatically if you let it search. Also it only requires the Realtek HD Audio driver.
Windows 8.1 Pro
ivana
  • Neo
« Reply #6 on: 11-September-12, 17:52:26 »
Thank you, again.
  • Lightning!
« Reply #7 on: 11-September-12, 17:53:14 »
 :hat tip:
Windows 8.1 Pro
