http://www.msi.com/service/product-comparison/mb.htmlAdvantages:
Dr Mos:In order to provide customers stable and high quality products, starting from P45 series mainboards, MSI is leading the industry to introduce the world's most advanced power supply component, DrMOS (Driver-MOSFET), which integrates Driver IC, Top MOSFET and Bottom MOSFET into one chip. Except for its outstanding performance in power saving, DrMOS possesses switch frequency which is 400% faster than traditional MOSFET and has great improvement in stabilizing power supply and voltage control. Even under heavy loading and overclocking conditions, DrMOS can still provide the most stable and efficient power supply and quality.
More PCI LanesSideport Memory(Useful you buy a vga that support hybrid SLI or use onboard vga): is used by ati tech. as dedicated buffer memory for integrated
graphics,located on the motherboard.It is usually higher clocked ddr2 or ddr3 memory
which is faster than usual system memory providing better performance for integrated graphics.
Motherboards claim for an increased >10% performance by using sideport memory.
3 way sliAPS:Active Phase Switching, APS, technology is an intelligent design that helps to save energy on MSI’s mainboards. The underlying idea is to switch off the power supply as soon as no electricity is needed, and when the system needs more resources again, APS will automatically adjust electricity supply accordingly. APS will automatically detect your processor’s loading at any given time and save energy accordingly. This is only possible by means of a very advanced power controlling technology. Other than software-based solutions, APS technology stands out from MSI's own research. The specially developed IC chip can operate automatically depending on the demands of the power supply, which is to reduce the total power usage.
Generally speaking with MSI boards, the first part of the model indicates the chipset ie 990fxa or z77 and the last set the tier. ie gd 65 / gd 80
Generally the higher the number at the end the higher end the motherboard.
