Author Topic: z77 mpower problems.  (Read 2018 times)
Griff7520
  • Winki
« on: 08-October-12, 09:21:15 »
Hello all
Just bought this board and I must say it is a good looking board.
I have a few issues.
1) The wireless adaptor does not work. I have installed latest drivers but it shows up in device manager as not active
2) I can not get my memory to run at 1600 mhz....every time i change it in bios it changes back to 1333 mhz after reboot......any one know what I am doing wrong?
3)  I successfully connected to my mobile via bluetooth but when i look in the folders for my pictures there are none there, any idea what this is caused by
thanks in advance.
Mpower Z77-i5 2500K @ 4.4-MSI GTX 660 OC-Averix MSI Z77 Mower 16Gb Ram-2 x Agility3 raid 0- WD Green 1 Terrabyte- Antec Kuhler 920- PC P&Cooling 600 Wt PSU- Coolermaster HAF 932
Froggy Gremlin
  • Power Edition
  • Master Air OC'er
Re: z77 mpower problems.
« Reply #1 on: 08-October-12, 09:27:59 »
Might try updating the UEFI/BIOS to the newest Beta found here;
>> Z77 MPwr Beta's <<
Life Can Be Very Fulfilling Without Win 8/8.1, SSD's, RAID, Current AMD GPU's, G.Skill RAM, Hackers, Crackers, & Crypto Mining!
IXOYE
xmad
  • Salisbury MD
« Reply #2 on: 08-October-12, 13:44:55 »
Keep checking back as well, the mpower is new and there will be allot of updates I think.
in regards to the memory, did you enable xmp?
New:
Board MSI Z77 Mpower
Bios: Latest Official
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
MEM: Corsair 2133 2x4gb CL: 9 Dominator Platinum
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Board: X79A-GD65 (8D)
Bios: 4.6
CPU: Intel 3930k Hexa-Core
Ram: Corsair Dominator Platinum 4x4gb 2133 CL:9
Vid: GTX 780TI 3GB in SLI
PSU: Corsair AX1200I
Cooler: Corsair 80I
SSD: Corsair Neutron GTX 240 GB SSD
Startech Raid Controller Card
HDD: 2x Seagate 500gb 7200 in Raid 0
HDD: 2x Seagate 1tb 7200 in Raid 0
OS: Win 8.1 Pro in UEFI mode
Corsair Link
Corsair H-100I Cooler
Griff7520
  • Winki
« Reply #3 on: 08-October-12, 18:54:20 »
Hi all
Managed to fix the wifi issue...not sure what i did though :)
Installed the latest bios and tried to set memory to xmp and it worked but when booted into windows it was back down to 1333 again...any other sugestions?
an no joy with the bluetooth issue
thx
xmad
  • Salisbury MD
« Reply #4 on: 08-October-12, 20:53:45 »
So you enabled xmp and it worked, but when you re-booted, it was disabled?
What memory are you using?
New:
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Bios: 4.6
Cooler: Corsair 80I
Corsair Link
Griff7520
  • Winki
« Reply #5 on: 08-October-12, 21:40:57 »
tried manually setting it as well.....but in windows it shows 670 mhz as opposed to 800 mhz via cpu-z.
it is crucial balistics tactical 4x2gb in dual channel mode.
xmad
  • Salisbury MD
« Reply #6 on: 08-October-12, 21:45:25 »
Do you have some different memory that you can test with?
Also, do a full cmos clear and retest: >>Clear CMOS Guide<<
New:
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Bios: 4.6
Cooler: Corsair 80I
Corsair Link
Froggy Gremlin
  • Power Edition
  • Master Air OC'er
« Reply #7 on: 08-October-12, 23:49:57 »
Is this a matched 4 stick kit? Often even RAM with the same part number but mixed will not work correctly together for a number of reasons. With RAM showing it's running at 1340, there must be a slight OC in place? Maybe bclk up a step above 100?
IXOYE
Griff7520
  • Winki
« Reply #8 on: 09-October-12, 03:12:57 »
it is 2 seperate sets of dual channel kits which ran in my Ga-Z68-UD7 without any issues......and my cpu is oc to 4.2 at the moment....memory changes in bios and says it is set at 1600mhz but boots and it has dropped down. Also noticed that my cpu frequency is at 100.5....cant see anywhere in bios to set it back to 100
photo sharing websites
« Last Edit: 09-October-12, 03:20:50 by Griff7520 »
xmad
  • Salisbury MD
« Reply #9 on: 09-October-12, 03:28:23 »
Also, for giggles test it with just 2 sticks installed in dimms 2 & 4
New:
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Bios: 4.6
Cooler: Corsair 80I
Corsair Link
Froggy Gremlin
  • Power Edition
  • Master Air OC'er
« Reply #10 on: 09-October-12, 08:28:29 »
The CPU is being OC'd. The 100.5 bclk is fine.
If the bclk is set to 100, then you are getting a bit of a built in bonus boost. :biggthumbsup:
Could you also post a screenshot of the CPU-Z SPD Tab please?
IXOYE
Griff7520
  • Winki
« Reply #11 on: 09-October-12, 10:35:39 »
morning all
a few more pics....yes I may have another set of ram somewhere....will try and find it...moved house recently and am still unpacking etc etc
xmad
  • Salisbury MD
« Reply #12 on: 09-October-12, 13:55:06 »
Go into bios, hit f6 for optimized defaults. Make sure OC Genie is disabled, and enable xmp everything else on auto and stock.
Change XMP in the regular section of bios no the "My Oc Genie" section.
New:
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Bios: 4.6
Cooler: Corsair 80I
Corsair Link
Griff7520
  • Winki
« Reply #13 on: 10-October-12, 11:33:42 »
well i just about given up here.....half the time you cant change the settings you want to change in bios because nothing happens when you click on something. after hours of messing around yesterday I decided to unistall all bios/control progs from windows in case it was those that were interfering with the settings i was putting into bios. Then could not find any where to disable oc genie as you said so I manually set cpu to 4.2 and memory to 1600 mhz. It booted up ok...ran a benchmark and memory was running at correct speed. Rebooted and now the memory is down to 670 mhz again.....anyone know what it is...does this board not like crucial memory....or maybe not like running 4 sticks of memory?
HELP! :)
Griff7520
  • Winki
« Reply #14 on: 10-October-12, 12:02:33 »
Problem solved.
seem this board likes all rams to be members of the same dual channel kit. I removed one 4gb kit and immediatley the xmp profile button was accessable...now running at correct speed and in dual channel. :)
xmad
  • Salisbury MD
« Reply #15 on: 10-October-12, 15:22:20 »
Yes, matched memory is essential, sometimes down to the same bacth of the same model.
New:
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Bios: 4.6
Cooler: Corsair 80I
Corsair Link
